Question about Bissell 6595 Lift Off Bagless Upright Vacuum
Bissell lift off, brush won't move smell burning rubber belt fine
I have the bissell lift off, bagless (no idea of model number), and i replaced the belt b/c it was torn.  now when i turn it on, the belt starts to melt? burn? i don't know - but the brush won't move, and i can see the belt moving very slowly and it seems to be burning or melting? ugh - terrible smell....HELP its practically new!
  • Anonymous Mar 15, 2014
    I smell a burning smell and the brush doesn't turn. The belt is not broken. 1697, 8804 series
  • Anonymous Mar 29, 2014
    Belt getting hot and melting seems brush isn't turning freely. Don't have original receipt but have original manual and box. Only had for about a year but has a three year limited warranty. Can I get a replacement?
    President:
  • 389 Answers
OK - so your brush roller is jammed. And yes, the belt is melting! Unplug the machine, remove the belt (you will need another new one anyway) then see if you can turn the roller by hand. If it turns freely without you doing anything else, then you may have put the new belt in incorrectly. However, you will probably find you can't turn it, or it's hard work (it should rotate freely). Remove the roller and check the bearings - there may well be something tangled up at one end of the roller. If you can get the roller rotating freely, all should be well.
Good luck
Posted on Mar 08, 2009
Bissell bagless 6583 brush won't turn after new belt
Sorry to hear about the difficulty with the brush. If your brush does not turn by hand freely, then your brush needs to be replaced.
Here is a quick link to order a new brush:
http://www.bissell.com/parts/?id=9143&sc=part&partid=17048&cid=ccsocial
Mar 20, 2013 | Vacuums
Bissell powerforce brush won't turn when powered
Hey, you may want to have check if the brush turns by hand without the belt in place. If the brush doesn't turn manually, you'll need to replace the brush.
Here's a quick link to the BISSELL website to assist you.
http://www.bissell.com/default.aspx?cid=ccsocial
Feb 12, 2013 | Vacuums
I have a Bissell pet hair eraser model #3920. It's been working great until last night. I went to use it and the brush won't spin. It also smells like it's burning. I checked the belt and it looks fine,...
- Remove the access panel, which is on the bottom of the machine. There are 4 tabs to lift on the access panel to remove. Start with tab 1 then 2-4 tabs.
- Check the brush, and belt for any damage. Clean off any debris on the brush.
-The belt may not be broken but may show signs of wear. If belt is broken or shows signs of wear, replace belt.
Aug 04, 2010 | Bissell 3920 Bagless Upright Vacuum
Bissell lift off bagless making high pitched noise, fan seems to run for 30 seconds after shutting off, and a burning rubber smell, is it the belt, and how easy are they to change
The burning rubber smell is usually the belt. Be careful not to use it on your carpet as the rubber belt can get hot and liquify and really mess up your carpet (if you have one). Here's a link to some instructions for replacing the belt.
http://www.ehow.com/how_4550054_replace-drive-belt-bissell-powerforce.html
Mar 15, 2010 | Vacuums
I replaced the belt on my bissell model number 3576-2, but when i put it back together, the brushes wont move...the belt tries to move, but the rubber just burns..
something is binding ... i dont know what ... you will have to remove all parts and reinstall again. Make sure the bearings spin on the brush when it is out ... remove all hair and string.
good luck ... im sure it is someething simple.
Nov 10, 2009 | Bissell 6595 Lift Off Bagless Upright...
Brush bar wont turn, Bissell smells like burning rubber
The belt just goes from the motor shaft to the brush roll. Do the ends of the brush trun freely, or is one of them froze up, if so replace the brush roll. If it is ok, try to turn the brush roll by hand, maybe the belt got pinched and won't move.
Aug 25, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Main Brush Failure
first check if the brush motor is turning before you spend money on a new brush roller and belt. remove the belt by unscrewing the screws holding the brush cover ( the part touching the floor ) and slip the belt of the rotor. turn the vacuum on, and the brush on while the vacuum is in a reclined position. if the motor is not moving, you need a new motor.
Jul 31, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell Lift-Off(R) Revolution(R) Turbo Upright.
If you have a rubber smell, then the belt is slipping, does the brush roll turn freely while holding the ends? If not then replace it, part #2036619, if it is ok, then the belt has strectched and is slipping under load, part # 2106679, Style 8.
Jan 20, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell Cleanwell II Bagless uprighht vacuum
Hi Pmob20,
Remove the brush and clean all the string or whatever may be trapped at the end edges of the brush.  This is usually the case with Bissel vacs, that string or fiber gets trapped at the ends of the brush assembly.
Oct 10, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell 6595 Lift Off Bagless Upright Vacuum Logo
1,401 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
