Question about Dell Precision Mobile M70 Notebook
Dell M70 laptop won't boot up
I turn it on and it goes through the main screen, then a blinking cursor shows up on the upper left hand screen and doesn't do anything beyond that
  • aullah70 May 07, 2009
    I have done the repair procedure. Now its showing funny characters on the top left side of the screen. and freezes there with the cursor blinking after the funny characters.
    Please help.
    Scholar:
  • 54 Answers
If you have a Windows installation CD, you can use the Recovery mode to attempt to fix the problem.
Turn on computer, insert CD into drive.
Press any key to boot from CD
Windows installation process will start
After a few minutes, a screen will come up telling you to hit ENTER to install Windows, or to press R to enter the Recovery Console
Press "R"
You will be asked which operating system
Most times there is only one option, select 1
At command prompt, type "fixboot" and press ENTER, if it asks if you're sure, type "Y" press ENTER again
Then, at command prompt, type "fixmbr" and press ENTER, again, type "Y" and press ENTER if it asks.
Type "exit" and press ENTER to exit recovery console and reboot.
Give that a try and see if it will boot for you.
Posted on Mar 08, 2009
Emachines Em250 has a blinking cursor after bios menu
May be a bad HDD. Can you access the recovery software at boot? Remove ALL media, DVD, CD, USB. Shut down, unplug, remove battery, plug in, with one habd push the on/off button, with the other press the Alt and F10 keys repeatedly. Here's the procedure: http://support.gateway.com/emachines/desktop/2009/gateway/dx/dx4300/DX4710faq6.shtml
Jan 17, 2013 | eMachines eM250-1915 Netbook
When I push the power button, the main dell start up screen comes on followed by a black screen with a blinking cursor in the upper left corner. It uses Windows 7
Remove any CD's or USB drives 1st.
Sound like its trying to load and can't find hard drive, CD, or USB device. You need to go into BIOS by pressing an F key during boot. Look on the screen for correct Function key to press during boot. Make internal hard drive first. Save and restart. Reseat hard drive if it does not show up in BIOS.
Oct 05, 2012 | Dell Inspiron 560 PC Desktop
ASUS EeePC 900A- black screen blinking cursor
The hard drive has issues, or the window files are corrupt. I suggest a computer repair store to retrieve files and test hardware.
Aug 05, 2012 | ASUS Eee PC 900 Notebook
It wont boot, goes to black screen with whit blinking dash
Yes, this sounds like the traditional black screen issue, but it's different! This machine is a Dell Dimension 3000 with XP. System won't boot. After Blue Dell BIOS splash screen with F2 & F12 options, it just goes black. There will ultimately be a white cursor in the upper left hand corner. I can edit BIOS with F2, I can get in to the boot menu with F12, but I can't do anything after that. I can even get in to the Safe Mode menu (F8), but it never boots.
Aug 14, 2011 | Gateway LT2001u Netbook
Will your assistance cost me anything? I turn the laptop on, the DELL word shows on the screen, and then the screen goes BLANK (cursor line shows at the upper left hand side of the screen). There is an...
This is a freebie
The system is not booting to the hard drive, the #9 indicator is an indication that the number lock is enabled.
Try holding the Fn key while powering on the system, see if diagnostics run (The works on newer Dells, not sure about the D610) If you don't have that function, if you have the resource cd, try and boot to it and run diagnostics.
Generally, the issue you describe is a problem with the hard drive, if it passes diagnostics, then see if you can repair the windows install booting to the XP Cd
Jul 08, 2011 | Dell Latitude D610 Notebook
Screen is black and only shows cursor blinking in upper left hand corner. Keyboard not responding. Changed the keyboard 3 times.
Start the computer up and repeadetly keep pressing DELETE to access BIOS menu, Once BIOS menu is aquired make sure that BIOS can see your main harddrive, If that checks out then you may need to set your booting device order to boot the harddrive that contains your Operating System. If that still does not work then you may have a bad motherboard.
Jan 04, 2011 | Dell Computers & Internet
Black screen with blinking cursor upon start up
You don't say what Windows are you using.
Anyways, it seems like you have a corrupted BOOT problem.
On Windows Vista and Windows 7, you can insert your Windows installation CD, and choose the "Repair my pc" option.
Windows will do it automatically fro you, and you'll be up and running in a couple of minutes.
Dont forget to rate this answer if it helps.
Jul 18, 2010 | Dell Inspiron 531s Desktop Computer
Gray screen on laptop, cursor in upper left wont go to main program screen
Did the HDD light flash ? also check battery may be bad, CMOS need info to talk to the drives before booting up, also is your copy of windows legal? XP and later Microsoft gives you 5 tries and windows goes bye bye, also no antivirus prog. master boot record may be corrupted. and only other thing back to O/S is linux( open source) . unles CMOS chip died.
Apr 16, 2009 | HP Pavilion dv6000z Notebook
Dell D410 Latitude won't boot up when connectd to docking station
That blinking cursor is the way in which the BIOS is telling you that Windows is missing - its most critical, core files have been corrupted beyond repair. The only thing you can do is to reinstall using the recovery cd or your own Windows install disk.
Apr 11, 2009 | Dell Latitude D410 Notebook
Dell Precision M70 PC booting problem
There’s probably an issue with your boot-up files or the hard drive. Suggest you start backing up all your documents, pictures and anything else that you don’t want to lose. Press and hold the <Fn> key while powering the system on. This will run the Dell Diagnostics. If no errors are detected, your software has a problem.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Oct 26, 2008 | Dell Precision M70 Notebook
Dell Precision Mobile M70 Notebook Logo
348 people viewed this question
Alun Cox
