Question about Creative Labs ZEN Vision:M Digital Media Player
Recovery Mode My MP3 is in recovery mode every option it give me i have tried numerous times, I've also reset it quite a few times nothing works
  • Anonymous Nov 02, 2007
    My mp3 has a loose hard disk and its in recovery mode right now.
    President:
  • 4,402 Answers
· 1. remove all creative software from your pc (do this from start menu/settings/control panel/add or remove programs)
2. Uninstall Windows Media Player 11 and Windows Media Player 11 runtime. This will rollback the pc to an earlier version of WMP.
3. Download the latest version of the zen driver from this location:
http://us.creative.com/support/downl...ame=Windows+XP
4. Make sure the zen is not connected to the pc and install run the exe file to install the software on your pc. at some point, the install will tell you that the unit is not connected. Connect the unit to proceed. it will also notify you that you are replacing an existing software, or something to that effect. I accepted or said OK to this popup. Once the firmware is installed, my started to work fine. You can now reinstall WMP from microsoft website. Hope this works for you.
All else failes download the recovery tool from creatives website.
Posted on Dec 20, 2007
SOURCE:
My brother's MP3 player is messed up. When you boot it, it automatically goes to recovery mode. Here, it tells you the firmware and gives me a couple options: Recovery Mode Creative Zen Micro...
Couple things to try.
Let the battery drain completely, then do a full charge and try again.
When turning it on, don't hold the ON slide, just slide it to ON then let it go. Holding it will send it into recovery and reset mode.
Jan 25, 2011 | Creative Labs Zen Micro MP3 Player
Hard disk problem?
hi mark,I have same problem..recovery mode nothing works .. i live in australia and not sure yet who fixes it telss you about firmware download..have not tried yet..this is only something new.will try more things and post again Good luck Helen
Aug 04, 2008 | Creative Labs Zen Touch MP3 Player
Creative Zen Touch stuck in "recovery mode"
Hi! I think you should try this (i've already tried it and it works):
1- Unplug your Zen from your Computer.
2-Turn off your Zen (if you can't do it, press the "Reset" button)
3- BEFORE turning on your Zen, press your "Play" button and hold it while you turn on.
4-When a format menu appears, select the "Format All" option (you'll loose all your Zen data).
5-When the format menu reapears, select the "Reboot" option and listo! You have your Zen as new and should not have problem. Good luck!
Jun 30, 2008 | Creative Labs Zen MicroPhoto MP3 Player
Have you tried to load the firmware? First you'll need to download the firmware to your PC from Creative's website: Click here. After you've downloaded it, connect your Zen via USB to your PC and open the firmware icon, then click "Upgrade."
For more detailed instructions on how to troubleshoot your Zen, click here
Jun 03, 2008 | Creative Labs Zen Touch MP3 Player
Load main image failed Switch to Recovery mode
Use the Sansa Recovery Tool on the Sandisk website
Jun 01, 2008 | SanDisk Sansa e250 MP3 Player
Creative zen recovery mode
I tell you how to go into recovery mode, but taking apart the mp3 player may have caused ireeparable harm.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
May 28, 2008 | Creative Labs ZEN SLEEK MP3 Player
Recovery Mode
I agree, use the Reload Firmware tool on recovery mode and then upgrade the firmware from the website. If you get "firmware failed!", then try it from a different computer.
May 08, 2008 | Creative Labs Zen Digital Media Player
My Nomad zen xtra 40gb is stock !!!
It sounds like the hard drive may be damaged. Have you tried to put it in recovery mode?
Put a paperclip in the reset hole while holding down the play button until you see the screen go to recovery mode. Then try the format option; this will erase all your files but it will tell you if you need a new hard drive.
Mar 24, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Creative Labs ZEN Vision:M Digital Media Player Logo
42 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Marvin
Marvin
Peter Dragonetti
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
