Question about Dryers
Our dryer won't turn on, nor does the light come on when we open the door. It was working just fine up until that point.
  • bwhawkins2 Mar 08, 2009
    We already checked the circuit breaker, and reset it and it didn't change any thing...
    220 voltage
    Scholar:
  • 124 Answers
Check breaker box may have tripped house breaker.
Posted on Mar 08, 2009
  • Mark Van Skiver Mar 08, 2009
    What voltage 110 or 220?
    I would check to make sure you have 220 across outlet.
    IF YOU DO NOT KNOW ANYTHING ABOUT ELECTRICAL SYSTEMS DO NOT ATTEMPT Yourself!
    Try pushing the door switch with your finger it should click. No click switch may be out can cause motor not to start & no light in dryer.
THE LIGHT WILL NOT COME ON WHEN THE DOOR IS OPENED AND THE DRYER WILL NOT STOP WITH THE DOOR OPEN
The dryer has a switch in the door that is activated when the door is opened/closed, replace this switch or check the connector to it or the wiring.
Oct 25, 2016 | Kenmore Dryers
Timer on Maytag dryer will not move.
Sounds like timer motor is bad. Most likely will have to replace timer.
Nov 06, 2017 | Dryers
Frigidaire electeic dryer won't turn on.
Have you checked the door switch to make sure it is closed when the door is closed?
Jan 21, 2013 | Frigidaire Dryers
Dryer won't turn off
Relay stuck closed in control circuit, usually the door interlock. Slam the door shut a couple of times to see if it frees the contacts.
May 15, 2012 | Washing Machines
Kenmore 70 Series Dryer won't turn on. I don't think it is a door switch problem because when I hold down the door switch to make the dryer light turn off, the dryer still won't start. I...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 19, 2011 | Kenmore Dryers
My Dryer won't stop drying until I open the door.
If it does this in a Timed Dry setting the timer is bad. If it does this in an Auto dry setting it could be a bad moisture sensor or a bad timer.
Aug 21, 2011 | Crosley Dryers
My dryer ran fine with my last load of only 3 towels. I haven't had any problems with my dryer before. I went to "wrinkle release" my towels and nothing happened. No lights, no 18min. showed...
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore 80 series electric dryer Model - 110-60882990 The dryer won't turn on. Once the start button is pushed it makes a single clicking noise. If I open/shut the door and push the start button...
check the actual door switch,, you can jumper it to see if this is the problem, Just connect the 2 wires together , if this cures the problem replace the switch
May 25, 2011 | Dryers
I have a Kenmore Elite dryer model #11087872602 that would not start or light up the panel on the front of the dryer. I had a general appliance repair man come out to look at it. He took both computer...
the start switch needs replaced, as far as the front panel light not lighting you will need to open the back top panel of the dryer and find the wiring diagram and trace it out, it may something as simple as the connector is unplugged. Hope this helps Tim
May 03, 2011 | Dryers
Dryers Logo
Top Dryers Experts
