Question about GE WBSE2090A Top Load Washer
GE model number wdsr2080daww, machine will not agitate. How do you remove agitator?
  • 1,543 Answers
You should be able to just grab the agitator and hank it straight up and off. Sometimes you might have to slip a belt or rope under the agitator and fasten the rope to a 2x4 or similar and then hank up on the board. Remove the plastic part under where the agitator was (one 1/2 inch head bolt) . If it does not come off, break it off with a chisel. If the metal spline shaft under that turns freely by hand, you have a bad transmission. If it does not turn by hand, just install a new WH49X10042 air bell (agitator drive) and replace the agitator.
Posted on Mar 08, 2009
How to remove agitator
That is a very old GE model. There may be a screw under the agitator cap which needs to be pried off. Even with the screw removed the agitator usually rusts or bonds to the transmission top. GE had a special pulling tool that was a metal ring that fit over the agitator with 3 set screws in it that you had to screw into the outer plastic of the agitator. A gear puller was then needed to pull the agitator off. Don't know if its worth it considering the age of the machine.
Apr 14, 2016 | GE WBSR3140DW Top Load Washer
Wdsr2080daww wont spin till turned by hand
It's very likely you need to replace the agitator dogs; it's easy to do if you're handy. I have done it twice and it only took about 40 minutes from start to finish (once you have the parts of course). Be sure to get the correct ones for your make and model and opt for OEM parts if you can.
You can find them with an internet search:
Oct 14, 2014 | GE WDSR2080D Top Load Washer
Remove agitator from a GE G129 I think, it is model number gtwn4000m0ws
Agitator just snaps into place. If you can get your fingers under the bottom edge of agitator, one hand at 3 o'clock and the other at 9, quickly and firmly pull up. It should come off. It takes a little force to do it though, so be sure to pull up quickly and firmly.
Sep 06, 2017 | Washing Machines
NEED TO REMOVE AN AGITATOR FROM A WASHING MACHINE
  • 1 First you must determine the brand of washing machine you have.
  • 2 To remove agitator on a whirlpool washer, remove top cap from agitator, Next you will find a translucent cap, remove this with your pliers. Then you will see a 3/8 inch nut, Back this nut out and you can then remove the agitator. Be Careful though, inside the agitator where the bolt has been removed is a white piece of plastic that holds the "dog ears". These dog ears are what lets the agitator move in one direction and locks when the transmission moves back in the other direction.
    Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts.
  • 3 Remove agitator, repair or replace and reset, GE just push on, you will be able to see the groves to line up the agitator to the hub. For whirlpool place bolt into dog ear guide, and set down on top of transmission post and tighten, be careful that dog ears, do not get out of alignment. That's it.
    Buy F150 parts.
    Jun 03, 2012 | GE Washing Machines
    GE model WWA8320GAL How to I get the agitator to come off. Thanks for any advice art
    Please read this link below first before you try to remove the agitator.
    http://www.geappliances.com/search/fast/infobase/10002927.htm
    This link below will tell you how to remove the Agitator on the ge washer.
    http://www.wikihow.com/Remove-a-Stuck-GE-Washer-Agitator
    Jul 07, 2011 | Washing Machines
    Tie wrapped around the agitator. How to remove to agitator? model 267A3088P405
    could not find the model number but this link may help you
    May 27, 2011 | General Electric Washing Machines
    How to remove agitator from GE washer? Model WHDRR418G1WW.
    how to remove agitator from GE hydrowave washer machine?
    Feb 27, 2010 | GE WBSR3140DW Top Load Washer
    Agitator does not turn in my GE washer, it is 3 years old
    Sounds like the agitator dogs have aged and broken apart. these are easy fixes at about 5.00- 10.00 and require the removal of the one bolt that holds the agitator down. After confirming this, take your washer model number and make to parts store and get replacement dogs. Hope this hepls..
    Oct 27, 2009 | GE Washing Machines
    AGITATOR REMOVAL GE WASH MACHINE, MODEL WPSR3100
    If you remove the top cover to the agitator, inside you will see a I believe 9/16" nut.  Remove this to take the agitator off the shaft.
    Mar 12, 2009 | GE Profile WPSR3100W
    GE WBSE2090A Top Load Washer Logo
    830 people viewed this question
    Top GE Washing Machines Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
