Question about Eureka 4700A Maxima Bagless Upright Vacuum
My Eureka Maxima isn't working right. The belt is spinning fine until I lower the handle to start to vacuum and then the belt stops spinning. As soon as I put the handle back in the upright position the belt spins again.
    Scholar:
  • 124 Answers
Sounds like belt is worn try changing belt.
Posted on Mar 08, 2009
Eureka burning smell
Hi, it's Cindy from Crucial Vacuum.
Since you have replaced your Eureka 4870MZ 9200 Proheat 2x vacuum's belt, the issue may either be caused by your roller or the position of your belt. It sounds like as soon as your vacuum is lowered, the belt is either slipping or wear on the end caps is causing your roller to stop. This will cause the burning smell since your motor is now straining against the abrupt stop. Try taking off your roller and checking the conditions of the end cap or try to reinstall your belt. I have included an instructional video: http://youtu.be/rji0fl9hytY
You can purchase direct your replacement brushroll from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com viewers, use code: FIXYA10
http://www.crucialvacuum.com/eureka-smart-vac-roller.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
Apr 20, 2013 | Eureka The Boss SmartVac Upright Vacuum...
I have a Eureka Altima and not sure how to change the belt?
1) Use handle release to lower handle
flat onto floor
2) Remove 2 screws from the front side of
brush roll cover
3) Lift and remove brush roll cover .
4) Remove brush roll and belt. Thread
new belt around motor shaft and
brush roll
5) Insert left end of brush roll first. Make
sure square on brush roll cap is in
place. Pull right side of brush roll to
stretch belt. Secure right end cap into
base.
6) Rotate brush roll 2 turns to center belt.
7) Replace brush roll cover
8) Replace 2 screws
And you can get the maual here.
http://www.eureka.com/service/manuals/80244.pdf
Good luck
Sep 27, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Brushes stopped spinning
I would guess the beater bar is still jambed or the belt burned in two.
Apr 25, 2009 | Eureka 2903A Maxima Bagged Upright Vacuum
Eureka 4870 roller only spins in upright
if the belt has been slipping it may have pollished the moteror brush shaft and it just slips. take a small piece of sand paper or enery cloth and ruffen up the shaft to give it some grip.
if the metal shaft of the motor has been heated up due to slippage it will take some doing to ruffun it as the shaft will be hardend due to heat
Mar 28, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
How to change belt on Eureka maxima 4700a
hey i had the same problem with mine, (standing over it and looking straight down) there should be two screws on the top of the yellow cover, one on each side, take those out and the yellow cover should easliy pop off. if the white ink is off the belt or the belt isnt tight than replace, once off just pop the wheel brush (which has the belt around it) up out of its socket and take off of the belt from the wheel brush and motor's metal pole, then put on the new one just like the old one was. let me know how it works out, redsox_belcher@yahoo.com
Jan 17, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
Eureka Atlantis Stopped Working
I would contact eureka for warranty repair. sounds like it there is something wrong with the mechanis of the unit. could be that water is making its way into the motor pump housing and causing damage to the pump
Aug 09, 2008 | Eureka Atlantis 2595A Upright Wet/Dry...
Eureka Altima is smoking!
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618889&thid=606496
Posted by saysay on May 18, 2008
Help! My vacuum is smoking. It won’t work anymore and starts to smoke as soon as it gets turned on.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Eureka Altima Upright Vacuum Model #2996AVS – it is probably doing 2 things, it could be the belt and or brushroll and the easiest ay to check is to remove the belt and see if the motor smokes, if the motor is fine then buy a new belt and check the brushroll to see if the brushroll spins freely, there are bearings in the brushroll and thread and hair get bound up in the ends and needs to be cleaned out. So #1, check the belt – no smoke from the motor then check the brushroll to see if it spins freely then changed the belt. If the motor smokes check your purchase date it may still be under the one year factory warranty from the dop. #2. Either clean or replace the brushroll and belt. If you have any further questions, feel free to contact your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don The Vac Man
Go Ahead. Use Us.
May 18, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Low suction on Eureka spinduster vacuum cleaner
The belt has stretch enough so as to not drive the brush roll under load. Try a new belt.
May 10, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
Vacuum roller stops at half tilt.
You need a new belt. Belts will stretch to the point that they won't turn the brush roll under load, they will just slip. Check the brush when you change the belt to make sure the ends turn easily, if not, then replace it also.
Apr 22, 2008 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka Maxima Bagless brush not spinning in vacuum position
belt doesnt have to be broken, check the metal arm on the vacuum, see if there is build up of old rubber from previous belts, clean the arm that spins the belt and double check to make sure u have the correct belt
Jan 19, 2008 | Eureka 4700A Maxima Bagless Upright Vacuum
Eureka 4700A Maxima Bagless Upright Vacuum Logo
416 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
