Question about Dewalt 7,000 Watt 13 Hp Portable Generator With Electric Start #DG7000E
Add electric start to dg7000 generator by Dewalt
Hi folks I have a dg7000 generator that I would like to add a battery (electric start) to. Is this possible and what is needed. Presently the unit is recoil start only. I am away now and my wife is having a hard time starting it when we need it. Thanks in advance. D.Watson
    President:
  • 1,723 Answers
This is really not an option. The engine would need a starter motor and battery and starting key switch. You will probably have to replace the unit with an electric start option.
Posted on Jul 02, 2009
Why does my dewalt dg6300b not generate electric?
Or only the Circuit breaker is or even a damaged capacitor gs0748 40 uf 370 v pos 260 to find by the electric stator(magnet field) or electronic control modul , try to control first the slide contacts on it, If there is enough clamping tension on it.
Aug 06, 2014 | Dewalt Dg6300b 6300 Watt Commercial...
Output voltage adjustment
Output voltage is based on 3600 rpm @ 60Hz. Sounds like your generator is over speeding slightly. Put a Frequency meter on the output of the generator and tune it to 61.5 Hz, that will get your generator in the 3600 RPM range.
Jul 17, 2014 | Dewalt DG7000 Heavy-Duty 7000 Watt Gas...
Dewalt 7000 generator will not stay on
Oil level switch that protects engine is activated. Check your oil level.
May 22, 2014 | Dewalt 7,000 Watt 13 Hp Portable Generator...
DEWALT DG6300B NO POWER OUTPUT
Hello avid.....
If there is no power to the receptacles:
1. Turn the circuit breaker switches off and disconnect all electrical loads from the generator.
2. Turn the circuit breakers on and test the GFCI's by following the procedures in this manual
on page 1 -
TO TEST A GFCI:
Start the generator. Turn the auto idle switch off. Push in the TEST button (A) on the receptacle.
The RESET button (B) will pop out. Power is now off at the receptacle.
If the RESET button does not pop out, the GFCI is not working. Do not run
generator until the problem can be corrected. To restore power to receptacle,
push the RESET button in. If the RESET button pops out during operation,
stop the generator and check the generator and equipment for defects.
3. Place the voltage selector to the 120 Volt only positions (unless you are using a tool that
requires 240 Volts).
4. Turn the idle control switch off.
5. Turn the circuit breaker(s) off and reconnect the electrical loads. Be sure that the plugs are
securely connected to the receptacles.
6. Turn the circuit breaker(s) on.
7. If there is still no power at the receptacles, take the generator to an authorized DEWALT
service center. To locate a DEWALT service center nearest to you, call 1-800-4-DEWALT
Joe
Thanks for choosing Fixya!
Nov 27, 2010 | Garden
Generator stars fine outlets don't produce electric
check
avr / brushes if it has them
if not capacitor and diodes on the end of the armature
Feb 17, 2010 | Dewalt 7,000 Watt 13 Hp Portable Generator...
Product Specs
It is important to find out what does and does not come with the generator you are purchasing e.g. Transfer switch, composite pad (if not, cement slab may need to be poured, which may require a building permit being pulled), battery etc.
Aug 27, 2008 | Dewalt 7,000 Watt 13 Hp Portable Generator...
Dewalt 7,000 Watt 13 Hp Portable Generator With Electric Start #DG7000E Logo
622 people viewed this question
Top Dewalt Electrical Supplies Experts
JOHN LAPIER
Jay Plesset
Are you a Dewalt Electrical Supply Expert? Answer questions, earn points and help others
