Question about Bruder Cat Skid Steer Loader
863 stops in tracks
Traction control and hydraulic stop working ligts blinks three times i have to turn off engine to try it again
    Problem Solver:
  • 9 Answers
When all movement of the machine stops the B.I.C.S controller ( under your right elbow )is detecting a " safety " problem. When you get in the machine, turn the key switch to " on , turn and look at the B.I.C.S controller lights. They need to come on in sequence. Only lamp lit now is the seat, pull down seat bar, and that lamp should light. After you push the button to operate, the other 2 lamps should light. Once in the machine, bar down and it ready to travel, use your arms and raise yourself OUT of the seat about a couple of inchs, if the seat light goes out, replace the seat switch. Also ( will need to raise the cab ) check that the seat switch plunger bolt it tight. If it is loose and not holding the magnet in a fixed poistion, now lighned up with the switch that detects where the magnet is, the B.I.C.S controller thinks the OPERATER bounced out and WILL stop the machine. I think it takes aprox 3-10 seconds to make the ecm re-act to the " NO OPERATER " signal Good luck..
Posted on May 19, 2009
CODEFOR PENSONIC TV
Hold down the TV power and power buttons together until the indicator blink twice. Key in 9-9-1. The indicator should blink twice again. Press the TV power BUTTON, Aim the remote at the decoder and press the CH+ channel up button and wait for three seconds again. Repeat the steps until the TV turns off. You`re basically iterating through the TV codes in the remote`s database. Press the OK button once you find the correct code.
Also try codes 0067, or 3778, or 863 for Pensonic. Some people have reported that these codes worked for them. Good luck!
Sep 28, 2014 | Televison & Video
2003 mustang when traction control light comes on the car lose power almost like shutting down, when it goes off it pick up speed.
The traction control system DOES cut your engine power when the tires spin. That is by design. The system cuts engine power to stop the wheels spinning and restores power once the wheels regain traction. It feels odd when the tires spin and power cuts out. It's good practice to lift off the accelerator when the system kicks in. Otherwise, if you are on gravel or slick streets the tires may spin, stop when traction control kicks in, and then spin again when power is restored. It is not an "elegant" solution but it does work for the most part.
Apr 03, 2014 | 2003 Ford Mustang
My traction control is off after replacing the battery, how can I turn i back on...the button isn't doing it
try driving it around the block or down the street then stop, turn off engine then start up again. should reset after that
Nov 04, 2012 | 2004 Mazda RX-8
Vsc, engine and track off light are on the dash board, what could this indicate?
VSC is for "Variable Slip Control" and TRAC is for "Traction Control". Your car is equipped with an antilock brake control system that is also equipped with VSC and TRAC. If these lights are staying on all the time, it is an indication that there is a malfunction in the system and your car will not function properly in the event that you get into a situation where evasive maneuvers are needed and/or slippery conditions could cause you to lose control of your vehicle.
SYSTEM OUTLINE
The vehicle could be in an extreme over steering or under steering tendency due to unexpected accidents, road conditions, vehicle speed, or by other external factors. In such a case, this system automatically controls the engine output and the braking to each wheel, to decrease the extreme over steering and under steering.
  • To decrease extreme over steering tendency When the system determines that the over steering tendency is large, the system applies brakes to the outer wheels according to the degree of over steering, and creates a moment towards the outer side of the vehicle, to decrease the tendency of over steering. Also, when the brakes are applied, the vehicle speed decreases while the stability increases.
  • To decrease extreme under steering tendency When the system determines that the under steering tendency is large, the system applies brakes to the front or rear wheels according to the degree of under steering, to decrease the tendency of under steering.
  • VSC OFF SW The SW to send the VSC system into OFF mode. When the SW is pushed after starting the engine, the system will be in OFF mode, and the VSC off indicator light will turn on. When the SW is pushed again, the system will be in standby mode. When the engine is stopped and re-started, regardless of the VSC OFF SW, the system will be in standby mode.
Information to the driver
The VSC system informs the driver when the tire grip is about to exceed its grip capacity, by blinking the slip indicator light and turning on the buzzer. Accordingly, the driver is informed to drive more gently.
Diagnosis of this problem needs to begin with a scan of your VSC and Traction Control and ABS control modules to retrieve fault codes. It could be anything as simple and painless as a malfunctioning Wheel Speed Sensor, or something as expensive as a damaged Hydraulic Control Unit.
Nov 23, 2010 | 2003 Toyota Avalon
Check engine light and TC light came on and car lost engine. Still had power steering and brakes. Have attempted to restart but will not. Any ideas?
I am more familiar with Ford products. If you have a cutoff for the traction control on your dash you want to remove a battery cable to get the Engine light to clear.
Reattach the cable after 10 minutes and turn off the traction control. Then try starting the car. If that does not work disconnect the fuse to the traction control and then try starting again.
All the traction devices interrupt the engines as part of stopping the wheels from spinning. The Traction Control on yours is stuck. If you can eliminate that feature you may get your engine to run again.
Apr 13, 2010 | 2005 Chevrolet Equinox
What does the master warning light mean? (triangel with ! and the three lights points to the car).
This light shows operational status of traction control system. If it is constantly lit when engine is running, this means that traction control system is off. If the light flashes during driving, it means the loss of traction at the wheels, and traction control system is operating- decreasing engine torque to stop exessive wheelspin.
Good luck.
Mar 21, 2010 | 2003 Toyota Prius
Traction control light
sounds like maybe a wheel speed sensor or a broken wire to the speed sensor.
Dec 06, 2009 | 1998 Ford Crown Victoria
What does the TCS Off button do?
TCS stands for Traction Control System.
The traction control system works in conjunction with your Antilock Brake System (ABS) and your Engine Control Module (ECM) or Powertrain Control Module (PCM) or Electronic Control Unit (ECU) (Note that ECM, ECU, and PCM all mean the computer that controls your engine, depending on make.)
Anyway, the traction control system can apply one or more of the brakes and control engine RPM in the event that a wheel slip has been detected by the traction control system.
Pushing the TCS button on most models will light a lamp in the instrument cluster that usually says "Trac Off" Pressing it a second time will turn this light back off.
When the "Trac Off" light is illuminated, the Traction Control System is disabled and will not work in the event of a wheel slip.
Also note that when the Traction Control System is working and a wheel slip is detected, The Traction Control Module will usually illuminate a light that says "Trac" as it is taking control of your brakes and engine. It can feel really strange when this occurs and some people think that their transmission is slipping or that their engine has a misfire problem.
The chances are that if it occurred on wet, slippery pavement, the Traction Control System may have just saved your life.
If this is happening on dry pavement and normal driving conditions (starting, stopping, or turning), there may be a problem with the system. "False Traction Control" can happen just like a bad wheel sensor causing "False Antilock Mode".
Also check your Owners Manual for more specific information pertaining to your particular vehicle.
Oct 18, 2009 | 2004 Honda Accord
Skidloader stops in it tracks
check out for the hydraulic oil filter
Mar 08, 2009 | Bruder Cat Skid Steer Loader
TRACTION CONTROL.
that is what it is desgined to do - reduce acceleration and apply the brakes intermittently when the wheels spin. You have a switch you cn push to disable it. You need to disable each time you start car. See owner manual.
06-10: Traction Control 1996 Contour, Mystique Workshop Manual
DESCRIPTION AND OPERATION Traction Control System The optional traction control system is designed to control wheel spin when accelerating on slippery or loose surfaces. Traction control system is available only with anti-lock brakes. The traction control system includes the following components:
  • Hydraulic control unit.
  • Throttle control actuator (9N825).
  • Traction control switch.
  • Traction control warning indicator.
  • Front brake anti-lock sensor (2C204).
  • Rear brake anti-lock sensor (2C190).
The traction control system operates as follows:
  • System functions by transferring torque from the spinning wheel to the wheel with the most traction.
  • This is achieved by applying the brake at the spinning wheel through the hydraulic control unit or reducing the throttle opening.
  • Traction control braking and throttle control occur at vehicle speeds up to 50 km/h (30 mph).
  • At vehicle speeds above 50 km/h (30 mph), only throttle limiting control is used.
  • If speed control is operating when traction control system engages the traction control system will disengage speed control through the use of a speed control relay. This action is the same as applying the brake pedal with speed control engaged.
1996 contour
Traction Control Switch The traction control switch is located on the instrument panel, left of the steering column.
Oct 22, 2008 | 1995 Ford Contour
Bruder Cat Skid Steer Loader Logo
600 people viewed this question
Top Bruder Toys Experts
Colin Stickland
Colin Stickland
J.D. Browning
J.D. Browning
Are you a Bruder Toy Expert? Answer questions, earn points and help others
