Question about HP Photosmart M415 Digital Camera
Nikon Coolpix S60 is the camera. The problem is
Nikon Coolpix S60 is the camera. The problem is as above. Took photos and apparently memory card was not in place. Now all pictures are in the internal memory. How can I transfer them to a memory card?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
Put the memory card into the camera, then use the "Copy" command in the Playback menu.
Posted on Sep 14, 2012
  • kakima Sep 14, 2012
SOURCE: How do I transfer pictures onto the memory card?
Take the memory card out and then hook up to your pc.
Posted on Jun 22, 2007
  • 3 Answers
SOURCE: hp photosmart m415 digital camera
You can do that. In the camera setup menu scroll down to the last option "move images to card"
Posted on Jul 01, 2008
  • 3 Answers
Go to the camera's "setup menu" and scroll down to the last option, "move images to card" That should put the images onto the memory card.
  • 76 Answers
SOURCE: transfering pictures from computer to camera memory card
my computer open whatever pops in there when your camera plugs in comp then copy n paste
Posted on Dec 02, 2008
Basti
  • 1447 Answers
SOURCE: What to do, I forgot to put memory card in HP R707?
Hi
Do you want the pictures transferred to your memory card? that depends on the option available on the camera, try inserting the memory card. select a picture then check options if you can move it to a memory card. if not, download it to a computer and transfer it to the memory card folder.
Hope this help
Posted on Jan 11, 2009
My coolpix l19 isn't showing up on my laptop screen when i connect my camera to it, and i wanted to download videos i took. is there a specific nikon transfer that i need to download first? that's what it...
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program, such as Nikon Transfer or Picasa.
Current versions of Nikon software Nikon Knowledgebase
Organize edit and share your photos
May 20, 2014 | Nikon COOLPIX S60 Digital Camera
How to get photos off a nikon coolpix internal memory
Two alternatives: Remove the memory card before connecting the camera to your computer, or use the Copy command to copy the pictures from the internal memory to the memory card and then download from the memory card.
Dec 21, 2012 | Nikon COOLPIX S640 Digital Camera
I have a nikon coolpix s60 and when i go to view the pictures, the screen turns black and i cant turn the camera off unless i pull the battery
What name brand memory card do you use? I recently discovered myself that Nikon only supports SanDisk, Toshiba, Panasonic and Lexar. Try taking out the memory card and take pictures without the memory card inside the camera. If you can view the picture saved onto the camera memory then you will know that all you need is a new memory card, with one of the above mentioned name brands. Hope this helps.
Mar 01, 2011 | Nikon COOLPIX S60 Digital Camera
How do i access the photos stored in the internal memory, not on the memory card?
If you remove the memory card, the camera will show you the photos stored in internal memory and allow you to delete them.
If you want to copy the pictures from internal memory to a memory card, put in a memory card and then select "Copy" from the Playback menu.
Nov 12, 2010 | Nikon COOLPIX S60 Digital Camera
I downloaded my pics off my memory card to my laptop now the memory card is reading when i turn on my camera memory card is write protected what does that mean? i have a nikon coolpix s60. when the memory...
Look at the memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 22, 2010 | Nikon COOLPIX S60 Digital Camera
Coolpix Camera getting hot
It sounds like you are shooting in RAW..try shooting in Fine or less. RAW format, demands more from the cameras battery, and it can heat up.
Jul 18, 2010 | Nikon COOLPIX S60 Digital Camera
My chip fell out, I took some pictures they are saved in the camera how can I transfer them to the chip?
If you're calling the SD memory card a chip, then you need to transfer the images with a USB cable to your computer. Once that's done put the memory card back in the camera and all subsequent photos will record on the card.
Nov 03, 2009 | Nikon COOLPIX S60 Digital Camera
My camera won't save pictures to my memory card.
memory corrupted need re-format that it or reset the camera .
Oct 12, 2017 | Nikon COOLPIX S60 Digital Camera
Troubleshooting
Sir i have a nikon s60 the flash will not fire i have reset the camera tried everthing some body told me i had a 8 gb memory card it is a super talent card not the correct card any ideas thanks
Jun 10, 2009 | Nikon COOLPIX S60 Digital Camera
HP Photosmart M415 Digital Camera Logo
69 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
