Question about Air Tools & Compressors
I have a Mac 3/8 drive air ratchet that does not work. I would like to take it apart to see if I can get it to work but I need a diagram to make sure I can put it back together. Where can I get a diagram? THANKS!
  • 65 Answers
Hi there sould be no need for a diagram all i do if i strip something im not sure about is use my digital camera or phone u will find that there is only 5 or six components in your gun and they are quite simple in operation hope this helps ian
Posted on Mar 25, 2009
  • rick maddox
    rick maddox Oct 29, 2013
    what if the previous owner put it back togather wrong
  • rick maddox
    Add a Commentwhat if the previous owner put it back togather wrong
Need to replace he a/c heater blend door actulator what tools do I need to get the dash apart
Quarter inch air ratchet, 1/4 extensions,1/4 sockets from5.5 to 15 mm.8mm ratchet wrench, 13mm and 15mm 3/8 drive socket.flat head screw drivers, pick set.push clip remover.this is not a hard job, well ive done well over 500 so it takes me about 30 mins. .just make sure you disconnect battery, make sure power seats are all the way back and when lowering the steering column, be sure to disconnect p.r.n.d.l cable from steering column..
Mar 09, 2014 | 2009 Mercury Grand Marquis
Powermate3/8drive gear twisted or unable to work due to the ratchet came loose at the middle threaded assembly since then it sounds ok but is sorta kinda froze//except going through motions
Go to this web site and click on service/ support scroll down to the bottom of the page and click on Product Manuals and Parts Diagrams: http://www.powermate.com/service.php
Dec 15, 2013 | Chicago Pneumatic 3/8" Heavy Duty Air...
Mac air ratchet repair diagram
What is the model number of the tool
Dec 05, 2013 | Air Tools & Compressors
I have a benchtop ratchet wrench, taken apart to be cleaned, but im not sure were the spring and the ball bearing goes
There is a hole that goes down inside the handle that the spring goes in. The ball goes on top of the spring. The trick is compressing the ball
Sep 03, 2010 | Chicago Pneumatic 3/8" Heavy Duty Air...
I need diagram and directions to change the ratchet on the drivers seat in a 1996 ford bronco. the bottom frame is broken and need to take it apart to weld the frame as you can not find a decent seat to...
Follow these steps to easily remove the driver's seat from ford bronco 1) Lean under the seat and unclip the harness that connects the seat belt sensor to the seat. You may need to use a small flathead screwdriver to pull the release open. 2)Attach the Mac Tools SC620B socket to the 3/8-inch ratchet and unbolt the seat from the floor. 3)Attach the 3/8-inch ratchet to the extension and then the socket. Unbolt the two bolts towards the center of the vehicle. These may be difficult to remove from the channel, but they will eventually come out. Then lift the seat out of the vehicle. 4) Now if you want to replace only ratchet then remove the ratchet from the seat and place new ratchet and reverse the procedure.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Mar 24, 2010 | 1996 Ford Bronco
When you put a socket on my 3/8 air ratchet you can hold it and it doesnt turn the socket
Make sure your tank is pressurized before using, Also, ratchets have an air adjustment knob that you can adjust how much pressure and power the ratchet puts out. Make sure you oil ratchet before each use with air tool oil
Aug 24, 2009 | Air Tools & Compressors
Does anyone know who manufacture MAC air impacts, in paticluar the AW434. My impact has little rpms.
mac does not design thier own my mac AW480O is a aircat and so is the new one i bought today and along with my 3/8 and my 3/8 air ratchet and the other stuff is IR ask your ask your mac guy he should know and to answere the ? you need to rebuild it or oil it
Mar 06, 2009 | Air Tools & Compressors
Replacing timing belt on daewoo nubira 2000 model
Instructions Difficulty: Moderate Things You’ll Need:
  • Set of ¼-inch drive sockets ¼-inch drive ratchet Set of ½-inch drive sockets ½-inch drive ratchet Set of 3/8-inch drive sockets 3/8-inch drive ratchet Set of metric wrenches Floor jack Jack stands
Step1 Raise and support the vehicle on jack stands. Remove the intake air temperature wiring, the breather hose and intake air hose. Take off the air cleaner assembly. Step2 Remove the right wheel. Remove the accessory belts. Remove the crankshaft bolt and the crankshaft pulley. Remove the power steering bolts and the timing belt covers. Temporarily install the crankshaft bolt and turn the engine clockwise until the mark on the crankshaft pulley, which is a triangle stamped into the crank sprocket, is aligned with the corresponding triangular mark on the block. Step3 Make sure that the timing marks are aligned on the camshaft sprockets. These are a line on each sprocket that runs through a tooth on each sprocket. These lines should line up in the middle between each sprocket and point toward each other. If they do not line up, turn the crankshaft one more time and they will line up. It takes two turns of the crank to one complete revolution of the cam. Step4 Loosen the water pump bolts; using the 3/8-inch ratchet, turn the water pump clockwise away from the belt and loosely tighten the bolts to keep it there. Remove the timing beltmag-glass_10x10.gif. Make sure the timing marks are aligned and install the new belt starting on the right side from the crank sprocket and working counterclockwise. Keep all the belt tension on the right side away from the tensioner. Step5 Loosen the bolts in the water pump and rotate the water pump counterclockwise to apply tension to the belt. Watch the tensioner, which is above the water pump, and apply tension with the water pump until the pointer on the tensioner lines up with the notch above it. Lightly tighten the water-pump bolts. Step6 Turn the engine two more times and align the timing marks perfectly. Loosen the water-pump bolts and, using the ratchet, apply tension to the belt until the tensioner pointers are aligned. Tighten the water-pump bolts. Step7 Install the timing-belt covers and the bolts in the power-steering pump and tighten. Remove the crankshaft bolt and install the crank pulley and the bolt, then torque the crankshaft pulley bolt to 70 foot pounds of torque. Install all components in reverse order of removal.
Mar 02, 2009 | 2000 Daewoo Nubira
Serpentine belt diagram for a 5.9 diesel with air and 9 pulleys
5.9L DIESEL
196759.jpg The 5.9L diesel engine accessory drive system (with a/c) consists of :
  1. Generator Pulley (1)
  2. Water Pump Pulley (2)
  3. Idler Pulley (3)
  4. Power Steering Pump Pulley (4)
  5. Radiator Fan Pulley (5)
  6. Crankshaft Pulley (6)
  7. Automatic Tensioner (7)
  8. A/C Compressor Pump Pulley (8)
CAUTION: When installing the accessory drive belt, the belt must be routed correctly. If not, engine may overheat due to water pump rotating in wrong direction. Refer to or for correct engine belt routing. The correct belt with correct length must be used.
1. Position drive belt over all pulleys except water pump pulley. 2. Attach a 1/2 inch ratchet to tensioner.
196757.jpg The 5.9L diesel engine accessory drive system (without a/c) consists of :
  3. Idler Pulley (3)
3. Rotate ratchet and belt tensioner clockwise. Place belt over water pump pulley. Let tensioner rotate back into place. Remove ratchet. Be sure belt is properly seated on all pulleys.
Sep 13, 2008 | 2008 Dodge Ram 3500
1997 vw golf
u need an air compressor ( prefferably) an air gun or really good ratchet, a VERY long extension for ur ratchet/ air gun and a torx bit. Cant remember which size bit it is by heart.
Need an air gun to remove the wheel lug nuts, and then the center bolt from the axle. (think its 32mm)
Then with ur torx bit, remove the 6 bolts around the axle, they are about 4 inches from the tranny.
The extension for ur ratchet needs to be about 30 inches long.
Good luck.
Jun 13, 2008 | 1997 Volkswagen Golf
Air Tools & Compressors Logo
1,342 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
