Question about Sanyo Microwave Ovens
Sanyo Microwave EMP415W DON'T WORK
NO SOUND NO TURNTABLE MOVEMENT LIGHT AND CLOCK OK WAS WORKING THEN STOPPED ..... FUSE?
MicrowaveSvc
  • 9098 Answers
SOURCE: danby microwave m # 1153
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 23, 2007
SOURCE: Microwave oven does not heat anything
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Posted on Aug 14, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Sanyo Micor/Oven/Grill EMG2553S Clock
You can download your owner's manual here.
Posted on Sep 01, 2008
tiway1
  • 100 Answers
SOURCE: Turntable motor - Sanyo Microwave Model EM-S8000W
There are actually two, both Panasonic motors...
Here are the full links...
http://microwaveglasstrays.com/shop/120v-microwave-turntable-motor-253w-b6326408ap-p-215.html
http://microwaveglasstrays.com/shop/120v-microwave-turntable-motor-6rpm-f63265g60ap-p-217.html
Here's the link to their main page for motors...
www.martinmicrowave.com
Posted on Sep 06, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: have a Whirlpool microwave oven, model MH3185XP. Just stopped wor
In some Whirlpool models, there are more than one fuse, and two or more thermal devices which can interrupt power to the oven.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Please write back with more details if you need further help.
Posted on Mar 02, 2009
My ge microwave spacemaker profile model # JVM1860BF001 stopped while in use. Interior light, clock and timer work. Door vent opens. turntable doesn't work. Won't heat.
check the breaker, or check if the wall socket works. If there is power, then you need to take it for service. There are no user service options for microwaves as they are so dangerous for both super high voltage and also microwave emission. Some models do have a pull fuse on the rear, so check for that first.
Oct 04, 2016 | GE Microwave Ovens
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
No Light and the turntable is not working
Open your microwave completely unscrewed but make sure it is disconnected from the power; check all the other fuses inside, if it doesn't fix the issue then take it to a pro to get this fix.
Jan 03, 2014 | Emerson MW8102SS 1100 Watts Microwave Oven
My Sharp Model R-520LW microwave will not cook. The timer, light, clock all work. The turntable, fan and microwave do not.
Hi! the problem you have mentioned indicates that your microwave magnetron is not working. check for busted fuses.
Sep 15, 2009 | Sharp R-520LW Microwave Oven
Panasonic Microwave NN-S935BF turntable and light do not work. Microwave still works. Bulb and turntable motor okay. No power to light or turntable. Any ideas?
Your description seems to be confusing turntable and light do not work
Bulb and motor OK
Which is it?
They could be separate incidents. The drive motor could be fused and the globe just blew its life away..
Aug 15, 2009 | Microwave Ovens
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
NN-A574SBBPQ - Microwave fans & turntable not working
2 fuses in a panasonic does not sound enough.
have you checked the main incoming power protection fuse normally 10amp or higher.
most panasonics have approx 4 fuses so keep on looking
Feb 10, 2009 | Panasonic NN-S961 Microwave Oven
Microwave Ovens Logo
184 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
robert landry
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
