Question about Nintendo Wii Console
It won't read the disk! I tried cleaning it off, but it did not work!
  • mikem12 Mar 10, 2009
    when starting console the disc will not read and says to refer to instructions. if i try 2 or 3 times it will finally read. this happens for sport disc and the fit disc. PLEASE HELP
    Problem Solver:
  • 18 Answers
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Posted on Mar 12, 2009
Vw beetle cd player wont read
The player may need replacement, especially if you have used it for more than a few years
May 08, 2013 | Car Audio & Video
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
May 10, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
try a DVD cleaning kit and follow instructions, if that won't work! clean lens with a Q-Tip and rubbing alcohol genly, and allow several minutes to dry, if no result it is cheaper to replace the player than replacing the laser pickup assembly.
Mar 19, 2012 | Panasonic DMR-EZ47V DVD Recorder/VCR
Won't read disc on Wii
try to get another copy of the disk or just try to clean it
Dec 25, 2011 | Nintendo Video Game Consoles & Games
My pioneer avic d3 will not read the map softwear disc or any cd /dvd any ideas
I am having the same problem. Mine has been working fine for several years and then all of a sudden this summer it just decided that it won't read the NAV disk any longer or any other disk. I have tried cleaning with compressed air as suggested by someone and still no luck.
Oct 08, 2011 | Pioneer AVIC-S1 GPS Receiver
The dvd player side doesn't want to read all discs. Some it just flashes the loading and makes a clicking sounds, sometimes it loads up and freezes on dvds, it does this when i try to put in a cleaning...
The clicking is made by the laser head as it moves across the surface of the disk repeteadly trying to pick up the data signal and failing.
If it has used to work then it's clearly a dirt problem. If a cleaning disk has failed to work then the dust has gone all the way to the reading sensor. To clean it you will need top completely dismantle the unit access the optical mechanism, take off the cover and access the reading head - there blow with the can between the lens and the sensor then with a q-tip wipe the surface of the lens.
Sep 17, 2011 | Philips Magnavox DVD/VCR Dual Player
Gateway m-1625 CD/DVD-rom won't read any disc. Its spinning but no read. any thoughts?
you might try taking a q tip and some alcohol and clean the eye ( a little glass looking circle ) that reads the disk. Do not touch it with your fingers. Sometimes dust or dirt can get on it and it will not read the disk. This also works on cd players as well as dvd players.
Aug 30, 2011 | Gateway T-1625 Notebook
None of the games will load,it says ''disk cannot be read,go to wii manual for troubleshooting''. i dont have a manual.
I have had that same problem with a game of mine. I believe that something may have gotten on the disk. Try to clean the disk and then try again. If it still won't work, you probably need to replace it.
Aug 05, 2011 | Nintendo Wii Console
My DVD player won't read, keeps saying disk error
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Jul 12, 2011 | Televison & Video
My RCA RTD317 has problems recognizing most DVD movie disks. It will play some disks most of the time and all audio disks, so I figure the lasers are working. What could be the problem?
If you've tried cleaning the Laser with a Lens Cleaner Disk or directly with Lens Cleaner Fluid and a QTip without any improvement then the Laser is Failing.
It takes less power to read some DVDs than others and a lot less power to read an Audio CD. The Laser will continue to deteriorate until it won't play anything.
May 08, 2011 | RCA RTD317 Theater System
Nintendo Wii Console Logo
48 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
