Question about LG DLE5955 Dryer
Items in dryer are not quite dry, cool down cycle is real short, heat is maintained in dryer when it stops and wrinkles clothes. Cool down cycle went from 4 minutes down to one, skipping 3 and 2. Same thing after 5 loads. I think the durations of the cycles aren't long enough.
  • w4570shooter Mar 08, 2009
    checked vent when being installed last week, no blockages and vent was as per diagram of installation.
  • mbt40 May 02, 2009
    The clothes in my dryer don't get all the way dry. I put them in for a little while longer and the sensor gets in the way shutting it off before they are dry.
  • 163 Answers
Check and make sure it has a clear clean vent.no kinks in vent hose.if yours vents thru roof then you may want a chimney sweep to come and sweep your vent out.if it goes thru a wall check and make sure know blockage.
Posted on Mar 08, 2009
How do i use the dryer
my dear
Clean the lint filter or screen before each load.
Inspect washed items before placing them in the dryer. The dryer's heat will set in stains that have not been removed.
Shake each garment before transferring it from the washer to the dryer.
Choose a dryer cycle. Opt for the regular cycle if most of the load is all-cotton fabrics, or set it on permanent-press cycle if the load consists mostly of synthetic or permanent-press fabrics (a cool-down period prevents wrinkling).
Add a fabric softener sheet,
Remove the clothes once they're dry and hang them immediately...
you can still watct this video for some tutorials..
http://youtu.be/HJqvvL2G9WY
Nov 22, 2011 | Dryers
How do i do drying only
From the document I see, it is only a matter of pressing the "Dry" button. This is from the manual, available at http://www.lg.com/us/appliances/washer-dryer-combos/LG-WM3431HW.jsp and selecting the "Support" tab. On the right, there will be a "Washer/Dryer Combos Manual" link, which will download to your computer. Listed under "Dry" in Section 9 is the following.
• Drying options are easily selected with the Dry button. • For most even drying , make sure all articles in the clothes load are similar in material and thickness. • Do not overload dryer by stuffing too many articles into drum. Items must be able to tumble freely • If you open door and remove load before dryer has finished its cycle, remember to press the Start/Pause button. • By pressing the Dry button, you can select "Normal" - "More" - "Time" - "Off" - "Low Temp" - "Less" • Your dryer can handle a load of up to 9 lbs. (4 kg) dry weight of articles. • When drying cycle is completed, [Cd] (Cool Down) is displayed on the Multi display. • Cool Down is set automatically when the drying cycle is complete. • If clothes are not removed promptly when the drying cycle ends, wrinkles can form. • The Cool Down feature periodically tumbles, rearranges and fluffs the load to avoid wrinkles for up to 4 hours. • The message [Cd] will continue to display until the clothes are removed or the Start/Pause button is pressed
Hope this solves your problem. I highly recommend downloading the users manual, it is a wealth of information and will prove useful in many circumstances.
Please rate and comment Thank You Joe
Sep 06, 2011 | LG WM3431 Front Load Washer / Dryer
MDG4000BWW gas neptune dryer The timed dry/air fluff doesn't work until it gets to damp dry or wrinkle release. Works on the other cycles. Have removed lint screen & 4" hose cleaned and vacuumed.
on a timed dry cycle u are selecting the time it will dry
only after the time has run out will it tumble with no heat
on other setting the machine is stopping the heat and putting the machine into a cool down or air fluff mode
sounds like it isworking normally
(solv ya prob)
Oct 17, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Blinking AD
AD is auto dry you may need to clean the sensor or you may have a fauilty one ...Auto Dry Loads dried using the Towels, Heavy Duty, Normal, Perm Press, and Delicates cycles will dry automatically at the selected temperature to the desired dryness level. The dryer uses sensing bars to sense the moisture level of the load as it tumbles through heated air. Auto Dry cycles save time and energy and protect fabrics. The estimated drying time will be displayed for about 5 minutes, then the outside of the display will light up in a circular track to indicate the drying time is automatically being determined by the sensors. When the load has reached the selected dryness level, it will continue to tumble, unheated, during a Cool Down period. This helps reduce wrinkling and makes items easier to handle during unloading. The estimated Cool Down time will be displayed. Drying time varies depending on size and dampness of load and fabric type. If the load is too small or almost dry, the sensing bars may not detect enough moisture to continue the cycle and the cycle may end after a few minutes. Select a Timed Dry setting to dry such loads. Room temperature and humidity, type of installation and electrical voltage or gas pressure can also affect drying time. For cycle selection turn the knob on the front of the dryer control panel. The light will illuminate next to the cycle selected. The following is a brief description for what cycles should be chosen for certain items and materials to be dried.
Sep 18, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer will start to heat up and then the heating element will stop and it will cool down and then it will start again. It is taking a long time to get clothes dry.
Some of these have a knob setting for "wrinkle free" and they can malfunction to the point that they do not allow the heater to stay on long enough. I personally do not like the wrinkle free features for even another reason.....if you do not remove the clothes at the end of the cycle then it will sit there a few minutes and then automatically turn on for a few minutes to remove the wrinkles and then rest again and repeat this cycling on and off indefinitely for hours or days until you completely remove the clothes...wastes energy and a bit scary to have it come on by itself. So...look to make sure you are not using the wrinkle free settings and then see if it works ok. If not then you may have a bad timer control.
Aug 21, 2009 | Roper Dryers
Clothes and sheets come out wrinkled and twisted
Try not to wash large items with small items the large items like sheet will twist around the small item. causeing twisting and wrinkling. Also If you are overloading the clothes or underloading the clothes they will come out wrinkled. I would try to do some testing wash a load of only towels then wash a load of only t-shirts and other light weight items that you may have. Then do just a load of your jeans. What happens? Please let me know
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Our LG dryer doesn't get completely hot until the clothes are mostly dry.
heated air enters the dryer at 140 degrees farenheit,
a portion of the heat energy raises the temperature of the water in the clothes.
When the clothes are cold and wet, the difference is large transfer is rapid
a lot of heat transfers to clothes and the exhaust air is damper and colder
As the clothes get warmer and dryer, proprtionally less heat is extracted from the incoming air, and the exhaust air is warmer and dryer.
When the clothes are dry, and at 140 degrees, the same temperature as the incoming air. no heat is removed from the incoming air
the dryer should then stop heating, draw unheated air through the drum and clothes to cool, and reduce wrinkling
then switch off
the dryer appears to be operating correctly
Oct 31, 2008 | Dryers
Wrinkles!!!!!!!!
This is a frequent complaint with the following known  solutions:
  • You might be drying them too long. back the time down so that the cool down cycle happens right as the clothes are dried.
  • Try smaller loads.
  • You should dry heavy fabrics and light fabrics separately.
  • Fabric softener in the washer may help to prevent wrinkles from forming in the dryer.
Feb 27, 2008 | Frigidaire GLTF1670A Front Load Washer
Cooling light
The cooling light should be blinking. Mine did the same thing. It ended up being the fuse that was going to the dryer from the circuit breaker itself. I ended up replacing the whole heating element thinking that was the problem. Turned out to be a $17 fuse and problem solved. Hope this helps.
Oct 07, 2007 | LG DLE2514 Electric Dryer
Dryer tripping electricity saftey switch
You probably have a shorted heating element.
May 15, 2007 | Miele T1322C Electric Dryer
LG DLE5955 Dryer Logo
200 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
