Siemens WK61420GB Front Load All-in-One Washer / Dryer
Problem for Siemens WK61420GB Front Load All-in-One Washer / Dryer
Problem with Siemens C35 + Psion Revo + Easyfax
By M0nica L - usenet poster
Hi!
Using the hard- and software combination mentioned above I have a
problem:
When sending a fax the receiving fax machine answers correctly, but
during the handshake the connection fails. In Easyfax there appears an
error message saying "modem error -122. test the connection and try
again".
By the way, Easyfax does not use the settings in the control panel but
you can configure a modem init in the program settings. Default is
AT&D2.
Who can help me?
Many regards,
Thomas
Solution #1
posted on Aug 02, 2007
Not Rated)
pandamama
Rank: Apprentice
Rating: 0%, 0 votes
Thomas,
<< Sorry, if you did not understand me correctly, but I already fail in
SENDING a fax
That's, indeed, possible. The fax protocol is an old one, predating the
use of mobile phones by quite a number of years. It has a few timing
constraints a mobile phone connection isn't always able to meet.
Siemens' implementation of a Fax Class 1 computer interface doesn't
help in this respect.
Another aspect is that fax machines, fax-modems and mobile phones don't
always operate that well with each other. There are combinations which
prove to be more troublesome than others. One of the fax machines at
our offices is rather selective, for example. Using my Nokia 8810 there'
s a chance of one in four of the fax getting through. While there's no
problem in using a Psion Dacom V.34 Gold Card Global.
<< I do know that my C35 only supports Fax Class 1. But as Easyfax
supports Class1, too, it should work with the right init string
I'm afraid that's not the case. To cut a long story short, with Fax
Class1 there's a higher chance that repeated time-outs occur between
C35 and remote fax device. Resulting in the call being dropped when the
maximum number of time-outs has been exceeded.
Kind Regards,
Rolf Brunsting - Delft - Netherlands
Was this helpful?
Yes
No
Solution #2
Not Rated)
Duke
Rank: Apprentice
Rating: 0%, 0 votes
Am Sun, 25 Mar 2001 09:47:08 GMT schrieb Kevin BSC:
Yes, it is.
Thank you very much for your detailled explanations, Kevin.
Yes, I have just tried sending a fax to our office, because there is a
"fax only" machine. But, no success. The same error message appeared
at the same time. :-((
What now?? Any idea?
Many regards from Germany,
Thomas
Was this helpful?
Yes
No
Solution #3
Not Rated)
Rogers
Rank: Apprentice
Rating: 0%, 0 votes
Thomas Kranenberg < <-online.de
Thomas,
I had the same problem trying to send faxes from my Series 5mx + Nokia
6210 to fax machines at offices in work. Is the machine you are sending
to, one of those combination machines - fax, phone and answerphone, all
in one unit?
Nearly all of the machines in my workplace are, and most are left in
"auto" mode to detect who/what is calling. When a call is made, if this
type of machine doesn't hear a fax "ready to send" tone being sent, it
will switch to the phone/amswerphone after about 5 seconds. I have to
make sure someone at the receiving end, manually sets the machine to
"fax only" so I can send a fax to it!
As the 6210 modem doesn't appear to send the "ready to send" fax tone
(it waits for the equivalent "ready to receive" tone from the _other_
machine), sending _always_ fails, with the 5mx fax program just "timing
out". The fax machine in my office is just a fax machine, so will send
the "ready to recive" tone when you ring it, and the 6210 starts
sending.
Have you got a "fax only" machine you could try sending to?
Just a thought?
Cheers,
Kevin.
Was this helpful?
Yes
No
Solution #4
Not Rated)
herself
Rank: Apprentice
Rating: 0%, 0 votes
Am Sat, 24 Mar 2001 17:35:39 -0000 schrieb Mike McConnell:
Mike, thank you very much for your answer!
SENDING a fax. Yes, I have tried the AT&F string, but the problem kept
the same: the receiving fax machine on my desk answers the call, I can
see the fax identity of Easyfax in its display, my C35 reads FAX on
its display, the machines both try to connect baut fail with the error
message above.
supports Class1, too, it should work with the right init string.
Unfortunately the modem commands by SIEMENS (*.PDF) do not say
anything about fax.
Please, could you give me more hints??
Please see my email.
Many regards,
Thomas
Was this helpful?
Yes
No
Solution #5
Not Rated)
Beresford
Rank: Apprentice
Rating: 0%, 0 votes
The C35 phone only supports Fax Class 1 which is not ideally suited to use
over GSM networks. I have normally managed to send faxes with my S35i but
receiving them is extremely unreliable. I don't know what intialisation
options are in Easyfax but the usual setings for Siemens phones are a reset
string of "AT&F" with the fax string left blank.
Do you have the URL to download Easyfax as I have been unable to find it in
the downloads for either S5 or Revo on Psion's site? Alternatively, could
you email me a copy and I'll put it on my website. Thanks.
Mike [Dundee, Scotland]
Was this helpful?
Yes
No
Popular Solutions for Siemens WK61420GB Front Load
Questions and Unsolved Problems for Siemens WK61420GB Front Load
Do you recommend Siemens WK61420GB Front Load All-in-One Washer / Dryer?
Answer
Answer
noise at the beginning of spin cycle and vibration
Answer
my washer leaks a bit on the soak cycle and it has a knocking sound on the spin cycle
Answer
My Kenmore elite washer flashes f11 immediately after startup. I tried unpluging unit , moving... (More)
Answer
Is it still possible to get parts for a Hoover Model 0617 portable washing machine?
Answer
I have a 9 year old siemans washer/dryer which has recently developed a mind of it's own. It stops... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Siemens WK61420GB Front Load...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14911
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
