Question about Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
Blinking "0" -- Doesn't Shoot
My Maxxum 5 has film in, blinks "0" and won't let me take pictures or change any of the lighting settings. Please help, I miss this camera!
    Scholar:
  • 124 Answers
Try new battery.
If still not working try opening back cover in dark environment see if camera film will reset.
Posted on Mar 08, 2009
    Problem Solver:
  • 12 Answers
There is no contact with the film cartidge.
Posted on Nov 12, 2009
I recently put film into my camera and it was all loaded up and working but today when i turned it on, it made this weird sound and then the film count went back to 0 and the word that said film was...
Try changing the film,I own a Pentax and experienced the same problem.I threw away the previous film and loaded it with a new one,it worked fine.
Thank You.
Feb 22, 2011 | Minolta Maxxum 7000 35mm SLR Camera
The first time i got my film developed the pictures came out nicely. the second time the film came out off colored, it was more pink then normal. the third time the film came out off colored, the color...
Either the development house you took it to is not reliable, you're shooting out of date film, or in bad light.
Remember that film is designed only to look good in sunlight outside. They sell colored filters you can place on the front of your camera if you need to shoot inside without the colors looking off.
Feb 17, 2011 | Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
Im the one with the Maxxum 3xi iso problem ... Our teacher gave us film with 400iso but we have to change the iso to 100 to shoot the roll..
If you use DX-coded film between 25-5000, the camera sets the ISO automatically to match the film. If you use non-DX-coded film, the ISO is automatically set to 100 ISO.
Jan 13, 2011 | Cameras
Blinking circle with black dot - 400si
If its on the top panel, its telling you that there is a film cartridge in the camera, already rewound and ready to come out.
Dec 26, 2009 | Minolta Maxxum 400si 35mm SLR Camera
Blinking 0 on my minolta maxxum 5 after I loaded the film. I cant take any pics.
It did not load your film. open the back, be sure you have the film pulled across the opening to the far side of the take-up spool, and close the back again. It should make noise as it winds the film, then number 1 should appear in the top window. If it does not make noise and advance film, you likely need the film advance motor replaced. Every time you close the back, it will try to advance film.
The motor itself can die and those plastic gears can break teeth. If repositioning the film does not work, your maxxum needs a trip to the repair shop.
Dec 06, 2009 | Photography
Setting date on Canon elph Jr.
To set the date:
1. Press the Date button (rear left button on top of the camera)
2. Press the Select button (small round button up and to right of date button, may need pen point to press), display may show 97 1 1, with the 97 blinking.
3. Press the Set button (below the Select button) to change the value of the blinking character.
4. Press the Select button again to change to the next character. Use Set again to change. Repeat until date is set.
5. Press the Select button when all characters are set.
To set time, press the Date button again and the display should change to time (24 hour mode). Use the Select and Set buttons as above to set the correct time.
C, H, and P indicate the type of picture you want to take. C stands for Classic, and the picture will be in a standard aspect ratio. H is the wide angle setting, and the printed picture will be printed wide angle. P is panoramic, and the printed picture will be even wider angle than H. All this depends on the processor who develops your pictures for you. Ask if their equipment can read and process according to the instructions your camera will automatically put on each exposure on your film.
The three buttons on the left side are:
Top -- Flash setting. On (lightning bolt) or Off (lightning bolt with line through it).
Middle -- Film rewind button. Film should rewind automatically when fully exposed, but you can rewind before the film is fully exposed by using this button.
Bottom -- Self timer. Pressing this button puts a clock symbol on the display. When this is set, the shutter will delay 10 seconds after the shutter button is pressed. Press this button a second time to turn off the self timer.
Mar 17, 2009 | Canon Elph Jr. APS Point and Shoot Camera
Minolta maxxum 5 film camera shows blinking battery
It could be a problem of bad conductivity. Try cleaning contacts with spray oxide remover.
Onofrio
Mar 13, 2009 | Konica Minolta Maxxum 5 Date with 28-80...
Will not load film
Is the lithium positive side down?
Jun 19, 2008 | Minolta Maxxum 7000 35mm SLR Camera
My minolta sightseen camera wont take pictures?
The blinking zero would indicate that the film has not loaded but the cartridge is in place. The camera won't do anything when this occurs. Try opening the film door and load the roll again
Jan 14, 2008 | Photography
Minolta Maxxum 5 / Dynax 5 35mm SLR Camera Logo
285 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
