Question about Electrical Supplies
Carb and voltage adjustments for Echo EG-750 portable generator .4cycle gas engine
5 Suggested Answers
SOURCE: Powermate 6250 loaps.
I took a new generator out of the box, filled it with oil and gas then started it. The govenor /carb linkage was moving violenting back and forth and the engine was backfiring.
I was able to get it to settle down by holding the linkage and closing the throttle plate a little but it would resume surging and backfiring when I let go of the linkage.
I tried again several weeks later. This time, after babying the linkage to get it to settle down, I moved the linkage about a 1/4 inch (which closed the throttle plate slightly) and lightly secured it in place with a ty-wrap. After running 10 minutes it finally settled down to where the backfiring stopped and the linkage stopped moving.
It was still okay after powering a heater motor and light.
I'm thinking that the problem with this engine is just that it needs a long warm-up time. I know very little about engines, so I could be wrong.
Bill
Posted on Dec 14, 2008
  • 63 Answers
SOURCE: generator hard to start and backfiring
Sound like you've done things in the correct order, tecumseh's are notorious for carb problems if you let as sit in them. Backfiring is timing related (flywheel key) or valve problems. I would take a closer look at the exhaust valve I don't believe it is closing all the way.
Posted on Mar 16, 2009
mydogisk
  • 50 Answers
SOURCE: Guardian generac 10kw model 5502 does not output correct voltage
the instructions says the voltage regulator is automatic/digital. when you check the voltage is there any load on the generator? if applying load to the generator doesn't help, you can manually change the motor speed where the governor connects to the carborator, but it may change the frequency, but the regulator may fix it
Posted on Apr 13, 2009
  • 4088 Answers
SOURCE: troy bilt gas portable generator not producing
First thing to check is to see if the generator is actually turning--couplers sometimes fail. You need some electrical skills and a voltmeter to trace down problems in the generator beyond checking the health of the two brushes that supply current (< 115 volts DC) into the rotor field circuit. You can find wiring and schematic drawings on the Troy-Built web site, just look for the 030248 model. Another person that I worked with had a similar unit with the same problem. It looked like the voltage regulator board was the problem, but haven't heard back if he had fixed it.
Posted on Sep 26, 2009
How to adjust output voltage on Honda 3000 generator
Hal, you may be able to adjust some what by changing engine RPM(throttle *****) and playing with the governor if need be with no load and with load.
Portable generator voltage regulator
Onan generator adjustment run speed voltage
https://mtspowerproducts.com/admin/data_sheet/SS321Manual%20II.pdf
Mar 27, 2016 | Powerboss 020309 3000 psi 2.5...
Echo pb250 blower how to adjust carb.
the new carburators do have adjustments but consumer is not allowed to adjust do to epa regulations find an echo dealer or echo repair tech with tools to do job everyones answer is carb clean carb clean damages diaphrams and seals in carb never use carb clean on lawn and garden equipment.
Jan 07, 2014 | Echo Gas Blower 135 MPH390 CFM Blower...
Briggs & Stratton Briggs Stratton 6200 Watt Portable Generator voltage adjust
Usually the cause of slightly low voltage like this is that the engine is not running at full operating RPM. Find the high speed adjusting screw on the govenor linkage and adjust the engine RPM until the output is 220V - 240V
Dec 09, 2013 | Briggs & Stratton Briggs Stratton 6200...
Echo gt200i, will shut down or boughs down when you give the gas, and dies, have cleaned exhaust,new gass lines, cleaned carb. what else can i check
Make sure the carb is adjusted properly. And make sure that ater the engine starts, that the choke is in the RUN position.
Apr 28, 2012 | Echo Garden
Generator surges even under load
Make sure all the springs that go to the carb and govenor are in place. some of them are just used to keep the linkage tight so there isn't any play. Another possibility is that the mixture on the carb is not set right. If you have an adjustment for the mixture, you can try to adjust it. With the engine running and warmed up. Turn the main jet adjustment screw (usually located at the bottom of the bowl) in till the engine RPM's start to drop. Then back it out til the engine runs smooth again. I would back it out another 1/4 turn and try it there. They tend to run better if they are set a little on the rich side.
Another possibility is bad gas.
Aug 27, 2011 | Coleman Powermate Portable Generator...
Generator starts than shuts down on under voltage
The problem is related to the engine. When a load is put on the generator, the engine's throttle will want to open to maintain RPMs. If your carburetor is misadjusted or gummed/varnished, when the throttle opens, you will get a fuel starvation and the engine will die. If the generator is used regularly and hasn't sat for a while, first check to make sure the spark plug is good since you don't want to make a carb. adjustment using a worn plug. After you adjust the carb. manuallly flick the throttle to ensure that the engine doesn't 'stutter' or die out. If it does, increase the gas in the air/gas mixture and if that doesn't solve it, remove, disassemble and clean the carburetor.
Jun 30, 2011 | Generac Electrical Supplies
5500 watt generator won't start. Runs as long as starting fluid is applied. Checked gas flow, wire connections, on switch,took carb apart and checked float valve
With starting fluid, it runs, so this means spark and compression and valves closing properly. You mention gas flow, so gasolene is getting to the carb. This would then leave the problem being in the carb if indeed fuel is present at the carb. If you take apart the carb right now, is there fuel in the bowel? Or, remove the bottom screw on the carb, does gas flow out? Does it flow continuously or does it quit? This will indicate if the float valve is indeed opening. The only thing if you have fuel in the bowel and no start, even with the choke closed, is that the main jet must be plugged. Had the unit been sitting for quite a while with gasolene in it? Gas can "varnish" after a few months and this can cause plugging of the jets and other passages. How old is the gas in the unit? Old gas won't burn in the engine and this can also be a problem. Drain the tank, and carb, put some new gas in the unit and try it. You might have to take the carb apart again and use some carb cleaner to blow the **** out of all the carb passages. This should get it going again. Now, most important, when you get it running again, you need to adjust the engine speed so that you do not burn out any electrical equipment. If you have access to a frequency meter, plug it into the 120 volt outlet on the generator and adjust the speed so that the frequency with no load is 62 - 63 hz. This will allow the generator to drop to 60 hz under load. The adjustment is a 5/16 nut, right side of the upper engine, facing you.
Jan 31, 2011 | Briggs & Stratton Power Products 5,550...
I have 5700 Mcculloch generator and when I open the fuel line it starts leaking from a hard black rubber next to the carburator
remove the filter and look down the tube if the carb is filling with fuel then the float needs adjustment or replaced from sinking the tube if it is the one that attaches to the side of a plate on the engine block then replace the oil do to your filling the case with gas this ia is vent tube that attaches from the plate to the carb just under the filter you may have to rebuild the carb about $20.00 for the kit and $6.00 for a float. hope this helps
Aug 21, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
Echo CS-440 Chainsaw. Was cutting firewood, saw running fine until I refilled the gas tank. The gas was a few months old but looked clean and smelled OK. But after I filled the tank could not get the...
unleaded fuel is notorious for going stale,and it can leave a resinous coating in the carb-try running the saw on half choke with new gas and less oil eg 50 to 1 for say ten minutes,this should clear the gunk out-if this does not work,you have two choices-strip and clean the carb,or adjust the H (high) scew on the carb anti-clockwise by a quarter turn a time till it revs out full bore-good idea to remove the chain and wear ear defenders when adjusting-and always use a chainsaw at its max rpm,or you run the risk of "kickback"
Feb 25, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
How do I adjust the carbator to get the mover to
it tells me its a generator on the top and your talking about a mower, first a generator will not be adjustable for voltage control these carbs are fixed(no adj), if its a lawn mower there are 2 screws adjust the high speed needle screw thats on the throttle linkage
Nov 09, 2009 | Briggs & Stratton Power Products 5,550...
Electrical Supplies Logo
134 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
