Question about Car Audio & Video
I need the color code for speakers on duraband db1200
  • andydevilbis Mar 08, 2009
    i need to hook up speakers on a db1200 car stero i have no manual any more
  • 64 Answers
Hello, the most common generic wiring code would be:
Red - Switch Power source
Yellow - Constant Power source
Black - Ground
gray (w/black) - front left positive and negative
white (w/black) - front right positive and negative
purple (w/black) - rear left positive and negative
green (w/black) - rear right positive and negative
orange - illumination
blue - power antenna
blue (w/white) - amp remote wire
If you have different colors you will need a manual.
Posted on Mar 08, 2009
  • 154 Answers
There are some steps to do--
Step
Understand the basics of all car stereo systems. A car stereo system consists of 4 main components and the wiring that connects them. These are the head unit, the main speakers, optional amplifiers and the subwoofers, which are also optional but generally considered a necessary part of any good system.
Step
Know that the core of any car stereo is the head unit, which is the cassette or CD player that goes in the dash. All the other components are connected to the head unit by at least one pair of wires.
Step
Know about car speakers. The main speakers are usually 2 in the front and 2 in the back, although with what are known as component speakers, each speaker is broken down into two speakers: one for the highs and one for the bass. Each speaker or speaker set (known as a channel) connects to the head unit via a pair of wires. Generally if you are installing a new head unit you want to install new speakers.
Step
Know about amplifiers mplifiers provide extra power to your speakers and/or extra channels of power for additional speakers. The most common use for an amplifier (amp) is to power subwoofers. The amp connects to your head unit via an RCA cable and often a "remote on" wire, and also connects directly to your car battery through a fused "hot" wire and to the car's chassis with a short ground wire. This article assumes the use of a single amplifier connected to a pair of subwoofers. If you do not have these components simply ignore the steps specific to the amp, doing so will not affect the rest of your installation.
Step
5
Know about subwoofers. Subwoofers are part of any good stereo system. They provide the deep bass that small speakers cannot achieve. Subwoofers are connected to the amplifier which can usually be mounted right to the subwoofer box. If you do not have subwoofers you can simply ignore the steps specific to them.
Preparing for the Installation
Step
Be properly prepared. This is extremely important since you do not want to realize you're missing something in the middle of the installation.
Step
Purchase the following: A car stereo wire harness which connects the existing wiring for your old head unit to your new one (this will be specific to BOTH the model and year of your car AND to the make of your new head unit); an amplifier wiring kit which will contain all the wires to get power and signal to your amplifier; six feet of 14-gauge speaker wire for the subwoofers. Your speakers should have come with their own speaker wires.
Step
Obrtain a guide to removing the dash, doors panels (or whatever compartment the speakers are in), and floor molding of your car. You may be able to find a guide for this online. If not, you can get a repair manual for your car at most automotive stores and online).
Step
Gather the following tools: Screwdrivers to fit the job, pliers, wire cutters, wire strippers, a utility knife, sand paper or a file, electrical tape, a 9-volt battery, and any other tools that the instructions for installing the head unit and your car guides specify.
The Installation
Step
Disconnect the ground (negative) cable from your battery first and foremost. NEVER work on the electrical system of your car with this connected.
Step
Install your new speakers. Start by removing the paneling of the speaker enclosure. Unscrew and disconnect the old speaker.
Ideally the speaker wire will be connected to the old speakers with a metal clip that can then slide right on to your new ones. If not, cut the wire off the old speakers, strip about half an inch of it, then cut the last 6 inches or so off the speaker wire that came with your speakers so you have the proper connectors with a little wire attached, strip a half inch of those wires and twist connect them to the existing speaker wire. Bend the twists so they are in-line with the wire and wrap each connection in electrical tape so no wire is showing to protect them.
Attach the connectors to your new speaker. Make sure to connect the negative wire (-/black) to the negative terminal on the speaker and the positive wire (+/red or white) to the positive one. Screw the speaker in place. If you have component speakers, and therefore a crossover, make sure the crossover is secured in the speaker compartment so that it does not bounce around while you drive.
Wait to put the speaker enclosures back together until you have installed the head unit.
Step
Follow the instructions you got for removing whatever part of the dash covers it and take out your existing head unit. Connect the car stereo wire harness to the connector that was attached to your old radio and attach the other end to your new one. Connect the antenna cable (the single wire with the big plug at the end) to your new head unit as well.
If the speaker wires are separate from the harness connect them using the method of stripping, twisting, and taping described above. Do this one at a time or use masking tape to label the wire to avoid confusion. If you are having trouble figuring out which wires go to which speaker or which is positive and negative read the tip at the bottom of this section.
Do not put your new head unit into the dash yet-you still need to connect the amplifier to it. Put the speaker enclosures back together now.
Step
Attach the thick positive (+/red) power cable for your amplifier to the connector on positive terminal of your battery. The kit you purchased should have come with an o-ring on one end of the wire (you may have to crimp it on yourself, if so do it on the end with the fuse), this ring can be sandwiched in the bolt on the connector that connects your car to the battery.
Step
5
Put the fuse in the fuse holder.
Step
6
Run the power cable through the firewall of your car (there is usually an opening on the drivers side) and along to the back of the car where your amp is. It is usually best to run this wire under the plastic molding that goes along the bottom edge of your car, you never want the power cable to come near any speaker wires. At the same time run the remote on wire (a really thin wire from the amplifier wiring kit), through the dash where the head unit will sit, along with the power cable to the amp.
Step
7
On the other side of the car run the RCA signal cable through the dash from the head unit to the amp (it's a pair of wires together with connectors on each end).
Step
8
In the back of the car pick exactly where your amp and subwoofers are going to go. Part of choosing this is that the thick black ground cable (negative) needs to have a place to connect to the metal frame of your car. This should be as short as possible, you never want the ground cable to be longer than 3 feet.
Step
9
Find a good screw or bolt, take if off and sandpaper the metal surface that the o-ring will make contact with, then screw it down tightly.
Step
10
Attach the RCA signal cable and the remote on cable to your head unit and attach the power, ground, RCA signal, and remote on wires to your amp.
Step
11
If you have not already done so, place your subwoofer box in the trunk and attach your amplifier to it if that is what you are doing. If you are not going to screw your amp to the subwoofer box then it must be secured to something else.
Step
12
Attach the 14-gauge speaker wires to the left and right channels of the amplifier and to the speaker connectors of the subwoofer box.
Step
13
Mount your head unit into the dash. Double check all of the connections on the back of it to make sure they are secure. Then slide your head unit into its slot in the dash and screw it securely in place. Before you re-attach the dash, reconnect the ground (negative) cable to your car battery and turn the stereo on and move around the car listening to each speaker to make sure everything is working properly. Then put the dash back on. You are all done!
the all part taken from a link(site)
thanks
  • 13,433 Answers
Offhand, check your manual and other documents that came with it, optionally there are unlocking services like this available
http://www.radio-code.com/
  • Ekse Mar 08, 2009
    I'm sorry, You need a color code. I completely misread the problem.
I need to know how the wires plug into my radio cause i dont have the right plug for it it is an durabrand db1200 an/fm/cd reciever
red-power(keyed), yellow-power(constant), Black-ground, Blue-remote(usually to amp), this is the basics to get power to the radio. The rest(white/white-black, green/green-black, gray/gray-black...are for speakers)
Sep 05, 2009 | Durabrand Car CD Player and AM/FM...
No wiring color codes on the unit
I found a sticker in the documentation. It came with my RV, and was hidden under a drawer.
Jul 28, 2009 | Durabrand DB1200 CD Player
I have looked everywhere for the users manual. I am trying to hook up the Duraband surround system to no avail. Could use some assistance
There should be the receiver box on the back are color coded wire plug-ins for the different speaks. Each speaker should be labeled on them somewhere BL, BR, FL, BL, Center, Sub each of the speakers have color coded wires that match those on the back of the receiver. plug them all up accordingly. Then your VCR or TV you would plug the component cables up to the Auxiliary IN jacks.Turn it on and set to Aux to listen to your tv or movies threw your surround sound system.
Feb 18, 2009 | Audio Players & Recorders
Wiring color codes /
I have the original manual, but no place to host it. If you email me at desertwolf02@yahoo.com with subject "manual request" i will email it to you.
Aug 31, 2008 | Durabrand DB1200 CD Player
Cut wires
Go to duraband.com they have the user manual in pdf format and it shows you the wiring scheme.
Jan 22, 2008 | Durabrand DB1200 CD Player
No wireing harness
Ok everyone,
If your looking for an answer for this I hope this helps.
The connector on the back of the Duraband receiver is the same design as the connector used on
most computer power supply connectors for the motherboard.
You can cut off the old connector for the PC power supply, and then cut off as many extra pins as
needed so it will fit into the back of the receiver.
Only thing is you will need to re-label each wire according to your old harness that may be damaged.
If ANYONE has the existing harness, and would like to tell us which pin goes to which color, this would be great. Most of the receivers have a color code on the case bottom, but it doesn't identify which color corresponds to which pin... please help...
Randy
Jan 04, 2008 | Durabrand DB1200 CD Player
Dishnetwork Remote Code
Dish Network does not support duraband. Some thing are made by another company so their code might work. But Duraband is one that doesn't work.
Dec 19, 2007 | Durabrand HT-3915 System
Durabrand Db1200 installation
As per our chat session I said I would be back while I search out your product...so here is your information; http://dbproducts.net/i/product/manual/DB1200_OM.pdf
Aug 24, 2007 | Durabrand DB1200 CD Player
Car Audio & Video Logo
32 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
