Question about Saeco VIA Venezia
It takes a really long time to pull shots. I see that it sometimes takes a minute or two if when I stand to let it go, test, see how long it'll take. Something clogged?
  • meredithchic Apr 26, 2009
    mine does too, if your machine hasnt been used in a while, itll take some time for the water to warm up andfor everything to get going again but once the first shots have been pulled it shouldn't take as long forthe others
    President:
  • 1,618 Answers
Have you tried to adjust the grind on your coffee.
Posted on Mar 25, 2009
I bought a XENYX 1832FX and only one channel is working on the main volume.. The led's on left side don't light up.. I have tested leads,speakers,and amp with an old mixer and they all seem to work fine...
There's a button named "Stand By" this is probably the cause of your mixer issue, just take the button cover up and insert the spray cleaner pipe inside and give it 2 or 3 shots, then push it in-n-out several times and re-check the mixer outputs, let me know a bit more to improve help.
Oct 17, 2013 | Music
1990 Chevy Cavalier z24 shuts off and has trouble starting
sounds like a possble bad egr valve stcking open or then clutch in the torque converter is staying on
Aug 10, 2012 | Chevrolet Cars & Trucks
My 2002 maxima struggles coming out of first gear could this be the fluid?
The first thing to do here is have the fluid and the filter changed if it has never been done, if that fails to correct the problem then yes it is time likely for a rebuild.
Jun 12, 2012 | 2002 Nissan Maxima
How can i install a magicjack?
Magic Jack is a plug and play device, just plug the USB to the jack and to your phone, and your computer will instantly recognize the hardware connected to it.
Sometimes, it does take a bit of time for the computer to recognize the hardware, so be patient! It'll take about 1-2 minutes for it to fully recognize and load, and you'll be up and running making calls in no time!
Jun 30, 2011 | Computers & Internet
My i phone does not want to work i tryed charging it holding the buttons ugh i just dont know i really need help nd im not goin no apple store and the same thing happen before but now its diffrent :(
If you iPhone lost all of it's charge, it'll take some time after you connect it to the charger for something to come up on the screen, first it'll be a battery charging image and after a couple of minutes it'll go back to normal. However, we would need more details to help you. Is your charger working? (Test it with another Apple Device, such as an iPod) Is the power outlet you are using working?
May 02, 2011 | Apple iPhone Smartphone
Hello, while vacationing in Hawaii I my camera would not auto focus. I was using my 18-135 lens. It will go in and out of focus rapidly but never stop to focus. Upon my return home I tried another lens...
I do not think your lens is out of order.
Sometimes this happens.
If your lens is not out of order then lets think the problem is another thing according to the user.
Autofocusing is great but under some conditions such as below you may consider.
Shooting in dimly lit environments can be difficult for some cameras and lenses when it comes to focusing.
You’ll know when your camera is struggling in Auto mode when every time you go to take a shot the lens will whirl from one end of it’s focusing options to the other and back again before deciding on where to focus.
This can really lengthen your shooting process and make taking quick candid shots quite frustrating.
Switch to manual mode and you can quickly find your focusing point and get the shot you’re after.
Feb 23, 2010 | Nikon D80 Digital Camera with 18-135mm...
Blackberry storm buttons wont work
Have you tried pulling the battery? Often times my Storm has locked up and nothing worked. The only way to really do a restart, is by pulling the battery.
-Take the battery out and wait 1 minute. -Replace the blackberry and wait for Operating System to startup -Test
If this doesnt fix the problem, you may have a problem unit and you should take it in to the Verizon Wireless store.
Jun 20, 2009 | RIM BlackBerry Storm 9530 Smartphone
Microwave quit working. We
If interior light works, but you can't program the control, the main
p.c. board or the touch membrane switch has failed. If you can
program the control, but it won't start, there might be a bad
door switch. You would need some electrical experience to be
able to test each switch and find the faulty one. There are usually three switches, the primary, secondary, and the monitor
switch.
Mar 27, 2008 | Microwave Ovens
Saeco VIA Venezia Logo
117 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
