Question about Boston Acoustics BA735 Computer Speakers
My speakers will not play on my computer
I have a emachines computer with (vista). I tried connecting BA DIGITAL BA735 TO MY COMPUTER AND I CANT GET ANY SOUND!! THE COMPUTER RECONIZES THE SPEAKER BUT NO SOUND
  • 3 more comments
  • qlawministri Mar 08, 2009
    should i down load a driver device?
  • wmo2 Apr 04, 2009
    These speakers arwe years old but when they work they sound fantastic. They worked well on my win xp pro system, all i had to do was select digital output on my sound output and voila music.
  • nisbett Apr 22, 2009
    I have an realtek sound card, can that be switch from analog to digital output
  • ezozimo May 05, 2009
    My speakers are doing the same...I cannot use it with the new iMAC20 that I just bought.  SHould I not use it anymore?
  • Anonymous May 08, 2009
    I have the same problem, this sucks. I don't want to buy new speakers. I don't know what to do.
    President:
  • 2,992 Answers
Those speakers were originally supplied with Gateway computer system that had sound cards with digital outputs. While some versions had analog and digital sound inputs, most often the speakers had digital input only. The on-board sound in the eMachines is analog output only, so the speakers are most likely not compatible with your computer. If you want to use those speakers, you will need to locate a PCI sound card with digital output.
Posted on Mar 08, 2009
  • Mar 09, 2009
    It's a matter of the output from the computer's sound card (built-in) being incompatible with the speaker input. The card is sending out analog sound wile the speakers are expecting digital input. Downloading a driver won't help because that doesn't fix the root problem. You need to get speakers designed for analog input, or a sound card with digital output. As it stands now, your computer just can't use those speakers.
I have old Boston BA735 digital speakers that I am trying to get to work with a new HP PC. Do I need drivers? There are 6 places to plug in speaker cables on the back of the PC. Which ones do I use?
Many of the new sound cards and especially sound cards on OEM do not support digital speakers without buying additional connectors. (Not sure why. I have these same great speakers for years and they are wonderful.
- Check if your sound card ha an SPDIF connection option. - Check the speakers in the device manager to see if you can toggle the "digital" option. - I also have read that some versions of the BA 735 have an analog option on the back of the subwoofer if you need to bypass digital. (mine don't, so I don't know if this is accurate)
Aug 12, 2011 | Boston Acoustics BA735 Computer Speakers
How can i get the boston digital ba735 to work on my computer?
if now your computer not support this speakers,you must buy new soundcard support this speaker then build in to your computer hardware.good luck
Apr 28, 2010 | Boston Acoustics BA735 Computer Speakers
The BA 735 speakers that came with the old Gateway I have does not work with the new iMAC
The BA 735 Speakers I have are purely digital and will only work if your soundcard has a digital output, will not work through analogue connection.
May 05, 2009 | Boston Acoustics BA735 Computer Speakers
I have a Dell Inspiron 630m computer with these speakers
Assuming you are using digital BA735.
Use the dongle that came with your Inspiron. It gives you a digital output which can go into the BA735 speakers.
I use one set of BA735 with two computers. Computer A sends digital out and Computer B sends analog. BA735 plays both. I listen to music using digital while the analog from the other computer alerts me to the incoming messages in Pidgin.
I did have to change bios settings on one computer to use the on-board audio.
To enable digital output in XP, click on the speaker icon > Advanced > Select Enable SPDIF. You can leave the PC Spk Mute unchecked if you want the analog output as well. That's all.
I hope you are able to enjoy the rich sound of BA735. It's beautiful. My ears thank a lot for replacing those desktop speakers. BA735 hardly takes up any space . Two small speakers are perched on the hutch and the bass module is somewhere behind the desk, completely invisible.
Jan 11, 2009 | Boston Acoustics BA735 Computer Speakers
Boston Acoustic BA735 digital CD quality 16 bit/44.1khz speakers
Dell laptops come with a proprietery s-video dongle. It gives you a digital output which can go into the BA735 speakers.
Dec 16, 2008 | Boston Acoustics BA735 Computer Speakers
BA735 no sound but sound card works in analog mode.
this should be pretty easy to diagnose. both speakers have mini jacks right? if so, and you plug one pair of speakers in on say, port "A" and you get sound then if you plug your other speakers in on port "A" and you don't get any sound, the problem is with your speakers.
Oct 19, 2008 | Boston Acoustics BA735 Computer Speakers
No sound. Sound card or speaker failure??
These speakers only accept digital input in form of 3.5mm mini-din digital out from your source.
Nov 09, 2017 | Boston Acoustics BA735 Computer Speakers
My Boston Acoustics BA735 speakers does not fit to my new Dell VISTA PC
I wish these suggested responses were a fix for my need of the control pod that connects to the main base unit on BA MM226 model. the only one I would consider is the repairman in Beaumont... b7e3fdeb-da2e-497e-b5a9-c73017f7f98a.jpg
Sep 07, 2008 | Boston Acoustics BA735 Computer Speakers
Speakers not working
do i need a disk to dwnload these to work on my computer
Aug 09, 2008 | Boston Acoustics BA735 Computer Speakers
Boston Acoustics BA735 Computer Speakers Logo
2,000 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
