Question about RTO Spur Sprocket For Stihl 017, 021 Chainsaws
Stihl saw ts 500 wont tick over when sat on ground
  • obwhon May 11, 2010
    What is "tick over".
    President:
  • 2,220 Answers
Delete this... It has been answered and there is no response to clarification requests.
Posted on Sep 16, 2009
  • 28 Answers
Your idle screw needs to be turned clockwise to bring up the rpm.....and clean or replace your airfilters
Posted on Aug 06, 2009
FUEL LINE FOR THE TS 500
You will need to contact a Stihl dealer. Here is a link to the site where you can locate a dealer near you.
Stihl dealers
Jul 10, 2012 | Stihl Saws
Not getting spark when starting stihl ts 400cut off saw plug is wet.
fromsnor38@gmail.com HI GRYDERT your problem could be your on, off switch. This might sound funny, but switch the on off switch real fast several times, then see if you havee fire. If not check your spark plug. If you have a n
ew one try it. If that don't work check the connection at the plug to be sure it is makiong contact with the plug. If all this does't work you will have to go inside to the coil. They don't usually go ba d but it could. But first check to be sure it isn't grounded at the small wire from the switch. Good Luck.
Jun 07, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
TS 350 I have spark to the on/off switch, but no spark to the spark plug
The Short Circuit wires need to be looked at. Take off the cover over the flywheel. The two thin wires coming off of the coil need to be checked to see if there is a spot that has rubbed off and if there is a bare wire grounding out against the housing of the Cut Off Saw. May also check the coil wire going to the spark plug. This can also develop a spot that can ground out on the housing.
Sep 17, 2010 | Stihl Concrete Cutoff Chop Saw Clutch...
Stihl 410 wont start put new spark plug but no spark
Try a new coil.Hope this helps and Thank You for asking!!!
Jul 19, 2010 | Stihl Ts 700 Cut Off Saw Model Name Plate...
My stihl demo saw ran out of gas an i filled it back up with the proper mixture an now it wont start
Remove plug and clean/replace. also check in the tank for a filter on the end of the fuel line.
Ground the plug of the body of the saw and stry to start to see if you are getting a nice healty spark. If you tank ran dry then you may have contaminated your plug.
Jun 20, 2010 | Stihl Ts 700 Cut Off Saw Model Name Plate...
Hi there; my stihl ts 420 does not start easily
replace the decompression valve. also check for carbon buildup on top of piston. usually when a saw stops on its own after 5 min or so.... the piston and jug are scored and need to be replaced.
Jun 16, 2010 | Stihl Ts 410 420 Cut Off Saw...
RTO Spur Sprocket For Stihl 017, 021 Chainsaws Logo
480 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
