Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Forward rev shaft seal leaking on 1650 cub cadet
Can I remove shaft and replace seal without opening up pump and not displace something inside pump?
  • 40 Answers
I would say no. your best off to take that in to shop services riding tractors.
Posted on Mar 11, 2009
I need to know what wires hook up to my coil in a 1650 cub cadet
TRY here http://www.bing.com/videos/search?q=wires+hook+up+to+coil+in+a+1650+cub+cadet&qpvt=wires+hook+up+to++coil+in+a+1650+cub+cadet&FORM=VDRE
Dec 23, 2016 | Cub Cadet Garden
My hydraulic lift for my 149 cub cadet will not lift when the snow plow is attached.
Try checking the fluid, it may be low. Or the seals in the cylinders may be leaking and bypassing so you can't build up pressure.
Jan 31, 2015 | Cub Cadet Garden
My 42 inch rzt cub cadet left side pump is leaking
Most of these smaller residential machines are not designed so you can rebuild the pump, but if you try, you will have to pull out the pump, seperate the case, and replace the seals. Not a task for the faint of heart. You probably will not be able to find a replacement seal.
Sep 15, 2014 | Garden
Troubleshooting
It sounds like maybe you have a broken shear pin where the drive shaft connects the hydro pump. Remove the tunnel cover and you will see the drive shaft. De careful on this step: start the tractor and what that connection and see if it holds. If that is not it then you have deeper problems.
Jul 31, 2014 | Cub Cadet Garden
I have a Cub Cadet zero turn RZT 50 that when I go up a steep incline and put the driving bars all the way forward it won't move. The back tires don't even spin. When it is on even ground it
being that each wheel has its own pump and motor the common connection is the belt it must be slipping and if its slipping without making a lot of noise look for oil being on the belt if so look for the leak the bottom of the engine crank seal is a common spot
Apr 25, 2012 | Garden
Leaking #1 pump on Arctic Spas Cub hot tub.
I found out that the pump impeller can be unscrewed from the motor shaft by turning the impeller while keeping the shaft from rotating. There is a brass shaft coupling embedded in the back side of the impeller. This allowed me to remove the leaking seal assembly inside the pump by tapping it out gently. However, instead of just replacing the seal, I decided to replace the entire pump with a newer version. Cost was only about $25 more than replacing the seal and gaskets. The pump-motor assembly has been reinstalled in the spa and there are no more leaks.
Dec 03, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Hydrostat trans starting to make moaning noise stops pulling
it may be full of dirt etc and has soaked up most of the oil inside the case, if the axle seals are worn and the selector shaft seal is worn I would say that is the problem, if that is the case you may be up for a new trans as I have done a transaxle just recently and the damage inside was extensive and expensive.
you will have to remove the trans and seperate the trans case for inspection
Hope this helps
May 23, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Hydrostat pump leak,cub cadet garden tractor
One... these are pressure relif valves. There are O rings that probably need replacing is all, the valve can go bad but since both are leaking it will probably be just O rings from heat that went bad.
Remove the valves and replace O rings. Use a 'good' pipe thread dope on threads when re-installing.
Two... never use teflon tape on hydralic systems.
Three... boscia is no guro for sure.... lmao
Nov 05, 2008 | Garden
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
343 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
