Question about Thermador CGB30RCU Grill
The interior of the grill where the burners are located is rusted out after only 4 years. I've store it int he garage in the winter and have been very acareful Thermador hasn't been very helpful
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
I have a jackeroo 6 burner hooded bbq and when i try to light more than 4 burners on high they all blow out, i have cleaned the burners of any rust that might be blocking flow but it is still happening,...
Try lighting them slower allowing the heat to build, you want the grill completely heated before cooking. If this does not help a couple more situations may be effecting the grill; look at your grills placement... maybe too close to major drafts (ie. as in an upper floor balcony) check to see if your regulator is giving you problems and the valve is open 100%. Assure that your tank is not almost empty. If you are in a cold weather area then prior to cooking bring your tank into a warmer area as temperature can effect performance. I use to live in South Dakota and in the Winter the tank came in the house.
Jan 13, 2013 | Grilling
I started up the barbecue for the first time to get all of the winter crud off, and when I start it only the outside burners will flame, the middle one asks like its starting but then burns out?
Probably some of the winter crud has clogged the burner and or the venturi valve. Remove the burner, clean it and check the venturi valve for spider build-up. Wouldn't hurt to check the burner orifice too.
Apr 10, 2011 | Brinkmann Charmglow Stainless Steel LP...
Burner flames don't get hot, like not enough gas.
Try this, Turn off the tank. Disconnect it. Reconnect it. Turn tank valve back on very slowly and then see if you get bigger flame size.
May 15, 2010 | Weber Genesis Silver B Grill
Inside rusted out.
If you mean the burners are rusted out, then yes. You can get replacement burners either through the manufacturer or a big box houseware store that carries Ducane Grills.
Apr 21, 2010 | Ducane Standard 1504 (LP) Grill
13 year old firemagic -- rusted burners and grid. can i get replacements?
yes you can look up Atlanta Grill Services on the internet call them they can get the parts for you.
Jul 14, 2009 | Fire Magic FireMagic (LP) 14-S000C-0 Grill
MY propane grill will not come up to the 500 plus degrees for grilling.
There are four possible ways this problem could occur.
1. The unit is old and the burner tubes are plugged, either with rust or spider eggs [yes, they like it their in the winter]. Parts are available at Home Depot and Lowes.
2. The unit is designed for either Natural Gas, and you are using Propane. Conversion can be done.
3. Your gas flow is not forceful enough from the Propane tank. Could be an old tank or a bad regulator. Replace bad parts.
4. Your unit isn't getting enough oxygen because there is too much ash and grease under the grill blocking the airflow. Clean the grill.
Jul 06, 2009 | Char-Broil Grilling
Main Burners completely rusted out; control knobs to burner...
Get replacement burners and preheat them once. Then paint them with high temp enamle paint to withstand the temps of the grill. The burners are regular untreated steel and not the stainless that one would expect. Painting them will prevent them from rusting out after 2 years. Just make sure you temper them once before you paint them as they will expand a little. Then paint them and enjoy!
Apr 26, 2009 | Frigidaire GL38LKEC (LP) Grill
Burners keep going out
Remove the burners and clean the inside of the burners with compressed air and or a small long bottle brush.
The burner holes have a rust scale buildup in them.
Mar 21, 2009 | Weber Genesis Silver B Grill
Grillpro model # 236464 owner's manual
Don't buy GrillPro grills they are junk!!!!!! I have had a GrillPro Model #236464 Stainless Steel Grill and after Three Seasons it has rusted to peices!!!! All Three burners and all Three Flavor Guards and both Channel Cross lites have rusted to a big pile of rust peices. I called GrillPro which is Manufacturered by Onward Manufacturing Company Limited in Canada and all of these pieces have been on back order for over a month and the company says they don't expect the parts anytime soon. Onward Manufactures the following brands:Broil King, Broil-mate, Sterling, Barbecue Genius and GrillPro. I have looked at several of these brands at Menards and they all use the same type of Burners and Flavor Guards that are in my grill so unless you want a big pile of Rust after three years of use I would avoid all of these Brands!!!!!! Forget the problems Take it back where bought and buy something else!! These brands will let you down! Al Gavin - 515-238-3920
Sep 17, 2008 | Brinkmann 810-2300-B Grill
Thermador CGB30RCU Grill Logo
48 people viewed this question
Top Thermador Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Thermador Grilling Expert? Answer questions, earn points and help others
