Question about Insignia 2.1 Speaker System (3-Piece)
I just moved my stepson's computer and I *think* I hooked up the speakers right. It is a 3pc Insignia speaker set with the floor sub. He had headphones plugged in before. We removed the headphons, and now I can not get the sound to work on the speakers. I have tried a multitude of things. It's not muted It has a Realtek High Def Audio Sound card, I have uninstalled, rebooted and let the computer reinstall. I have tried hooking the speakers directly in and not using the sub. I have checked the plug in (also the blue light is on, sO i know they are plugged in). Any other ideas? The computer itself is an HP Pavillion a1730n, Vista operating system
  • 1 more comment
  • toddandshell Mar 08, 2009
    Ugh, I have no idea where the CD would be. I'll definitely look around!
    As for the jacks, green to green right?
    I just plugged in my old speakers from my old computer and they have an orange end. I plugged the orange end to the orange jack, no sound, plugged the orange end into the GREEN jack, and I can get SOME sound out of my speakers.
    I am sure somewhere I am messing up the Insignia speaker hookup, but now I have the problem of not being able to hear much from the speakers that do work.
    Thanks for the options! I'll get back to you. My brain needs a rest.
  • Anonymous May 09, 2009
    Where would that be located?
  • 58 Answers
If u have been supplied with a driver cd u  should probably try running the disc instead of sutomatic driver installation by vista.Or maybe u got the jacks mixed up.
check it out.
Posted on Mar 08, 2009
  • naveengopi
    naveengopi Mar 08, 2009
    Its most probably a case of mixed up jacks.and yeah the green goes in hte green but sometimes the wiring tends to get messed up during manufacture.
    yiu should try the few possible combinations.and also the driver cd.if you cant find it , gimme the model number of ur sound card and ldet me try lookin for the drivers online.
    If all else fails...CUSTOMER CARE.Ireally hope one of the above works for you.
  • naveengopi
    and if i helped u solve ur problem in any way...please help me by clicking on any of the ratings given by fixya.
    thank you.
Check the bass volume switch.  i did the same thing with my headphones and must have inadvertently turned the sub woofer volume down. hope this helps.
Posted on May 09, 2009
Problems with JBL PSW D110
The speaker level input option is designed for receivers that don't have digital output for the sub, used this way when you set to digital the speaker outputs only get the higher range outputs so won't reproduce much bass. To get the sub to work in digital mode you need to use the digital output (single RCA) from the amp to the sub
Mar 06, 2012 | Audio Players & Recorders
One speaker not working. The speaker with the controls lights up but no sound, other speaker and sub works fine.
it will be either a faulty conection to the speaker ,or a fault on the circuit board, if you think its worth having them tested or buying new
Sep 22, 2011 | Insignia Audio Players & Recorders
Right speaker won't work. If I jiggle the subwoofer plug in cord, it will temporarily go on. Is it the cord, or input jack. Headphones work both sides
The cord or plug in is damaged and needs to be replaced from end to end just get some wire and open the speaker case and redo the wires. This is an easy fix, find another cord matching and just solder a new one from end to end with a new tip. That is all you need to do? Thanks for using FixYa! John
Feb 13, 2011 | Cybernet Systems CA-3080, CYBER ACOUSTICS...
How to hookup
hi,
if u want to hook up the sub with ur av receiver the connect the sub woofer output of ur AVR to any one (left or right) input of ur sub woofer. then connect its power . set the frequency range between 90 and 120Hz. set the volume of sub woofer to 40% of its total. also check the av receives speaker setting. goto speaker setup and make ON the sub woofer out.
if want to connect the sub to a stereo amp without sub out. then connect the amps speaker line to the speaker input of sub woofer and connect the speaker out of sub to left and right speaker ( make sure to connect the red to red and black to black). set the volume and frequency as above
ok
Jan 01, 2011 | Wharfedale PowerCube PC-10 Subwoofer
No sound
If you know your speakers are working and there is nothing wrong with them go on your computer and go to sound settings in control panel and adjust treble bass and volume.
May 30, 2010 | Insignia 2.0 Speaker System (2-Piece)
I have a HK 595 sub. with no sattelite cables.
you need the the satellite speakers hooked up in order for the sub to work. its not a standalone sub the volume control knob on the satellite speaker is what powers on the sub. i have extra speakers i wish i could give you cuz my sub just blew out.
Dec 20, 2009 | Harman Kardon HK595 Computer Speakers
Why put woofer on the floor?
Because low frequency sound travels better lower to the ground. The effect if placed high up would be minimal
LF sound has more punch that regular speaker sound, it also caused more speaker movement and if placed high up could in theory pull itself from the shelf or mount.
You tube has some sub sound tests you could use to show this theory. or maybe the candle trick of putting a lighted candle in front of a sub when turned up a bit may convince you.
put a candle about 6 inch away from a sub and play some nice bass it will blow out the candle more than a regular speaker
Oct 11, 2009 | Insignia Audio Players & Recorders
Have alpine 10 r subs can insignia 500w amp hook up and how to wire subs
if the speakers are 250 watts each then yes if speakers are less you will blow them cuz of to much power if they are more then you most likely won't be able to push them
Sep 24, 2009 | Insignia 600W Bridgeable Amplifier with...
I Do Not Know How To Connect Boston Micromedia To My Computer
The Boston Micromedia speaker set comes with two speakers (right and left),a subwoofer, and a complete set of cables to connect everything up.
1.) Position the speakers. The two small speakers typically are spaced equal distance apart on a desk/table top to the benefit of the listener. The sub-woofer typically rests under the surface, on the floor for example.
.) Connect the cable sets to the back of the two small speakers along with the speaker feet.
Note: the small speaker with the volume control knob will have three cables coming from it. This will be the "right" speaker. The other speaker will have a single cable and will be the "left" speaker.
2.) The cable ends will be color coded to match the jackson the sub-woofer. Match up the color coded cables to the respective colors on the subwoofer as follows:
(a) White cable end (left speaker) to white jack on sub-woofer.
(b) Red cable end (right speaker) to red jack
(c) Purple cable end (input) to the purple jack
(d) Green cable end (computer out) to the computer's microphone output jack.
Note: if any of the cables are too short to reach their jacks for whatever reason, an extender cable with a female and male end can be purchased relatively inexpensively to make up the difference in distance.
3.) Power up the system (plug in power cables to the sub-woofer and wall), play some music, and adjust the sub-woofer sound (control knob) to suit listening pleasure.
A nice little set of speakers, I had mine for some years now and continue to enjoy them. Good luck!
May 17, 2009 | Boston Acoustics MicroMedia Computer...
Adcom GFA-5400 installation
Use the niles for more than one speaker hookup. As far as the sub hookup, use a powered sub with speaker inputs
then use the right or left speaker and tag a couple wires to the sub. Good Luck
BIGRED
Dec 28, 2007 | Adcom GFA-5400 2-Channel Amplifier
Insignia 2.1 Speaker System (3-Piece) Logo
337 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
