Washer basket throws out in spin mode
I have a whirlpool top load (direct drive?) washer model 110.25842400 and it worked fine at point A....got it to point B via a trailer, hooked her up and as I stated, the basket keeps throwing out and crashes into the sides in spin mode....I checked underneath and found these plastic cups with around 2'' pins resting inside them and wonder if that is or is part of the problem....please help
  • 6,784 Answers
Yes, the clutch assembly may be destroyed. i would disassemble and remove the drive and gear case to inspect all clutch assembly parts. they may be stripped.
Posted on Mar 08, 2009
My husband just replaced the motor coupling for the second time in the last 5 years. My machine agitates and spins just fine now, but at the end of the spin cycle it makes a loud clunking noise and the...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
KENMORE top load, direct drive, neutral drain washers are made by Whirlpool.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Assuming that the springs are OK and that the vibration pads are in place and not worn, (See the Sears diagram or the following Whirlpool Service manual)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
the problem points to the brake.
The washer uses a brake system to stop the basket at the end of the spin cycle.
Just like a brake on a car, it's designed to slip a bit so that the basket / car doesn't come to an abrupt halt.
Over time, the brake shoes can jam against the brake drum and bring the basket to a halt too quickly with a lot of noise.
A way to solve this (that I tried and it works) is to pull the basket tube / brake assembly and if the brake shoes look OK, spray a small amount of silicone spray on the inside of the brake drum.
Following is a description of how to remove the cabinet, pump, motor, transmission and basket drive tube on Whirlpool / Kenmore / Roper direct drive washers.
As an aside, you don't need a special spanner wrench to remove the spanner nut. I've found that a short (10") pipe wrench hooked over one of the spanner nut tabs and tapped with a hammer will usually loosen the nut. Also, rather than hitting the Drive block directly with a hammer, put a short piece of wood under it first to protect it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Following are the Whirlpool Service manual for this type of washer and the Whirlpool parts list for their commercial washers although the consumer models are basically the same. Whirlpool (and Sears) have replacement brake pad / spring sets.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Feb 15, 2011 | Kenmore 15864/15862 Top Load Washer
Kenmore Top load Washer machine, Model# 110.22902100 is making making loud noise (rubbing perhaps) at the end of spin cycle. What could be possible cause of this....?
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11022902100/0582/0153200?pathTaken=
A way to solve this (that I tried and it works) is to pull the basket tube / brake assembly and if the brake shoes look OK, spray a small amount of silicone spray on the inside of the brake drum. If you have a spray can of silicone spray with a long nozell (Like on a can of WD-40) you may not need to pull the motor, pump etc.
Jan 04, 2011 | Kenmore 22422 Top Load Washer
My kenmore 80 series washer at the end of the spin cycle or when the lid is lifted it will lurch from side to side.
This assumes that you have a KENMORE top load, direct drive, neutral drain washers are made Whirlpool.
The problem points to the brake.
The washer uses a brake system to stop the basket at the end of the spin cycle OR when the lid is raised during the spin.
May 31, 2010 | Kenmore 24032\24036 Top Load Washer
Top load 80 when spin is complete and drum noise
May 12, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore series 60 shaking house win spin cycle comes to a stop
Feb 12, 2010 | Kenmore 23012 Top Load Washer
When the spin cycle stops, the barrel keeps spinning for approx. 30 seconds and makes a loud "clicking" sound. Everything else seems to work ok.
Following is the Whirlpool / Kenmore service manual for top load direct drive washers.
Over time, the brake shoes can wear out so that the tub won't stop.
Jan 12, 2010 | Kenmore 24902 Top Load Washer
We have an 80 Series Washer. Everything works
Jan 10, 2010 | Kenmore 15864/15862 Top Load Washer
Direct Drive Kenmore Washing Machine will not spin a full load of clothes during rinse or spin but will spin a small load. Agitates fine. Replaced drive coupler, clutch and basket drive...no luck. What...
its possible the ears on the top of the drive tube have worn alowing the basket drive block to slip and not turn the clothes basket with authority, or the basket drive block has just worn from overloading and needs replacing.. is easy to verify by looking..
best of luck,
ttfn
Oct 25, 2009 | Whirlpool LSR7333 Top Load Washer
I own a whirlpool top loading washer - under 2 years old. it stopped draining water and spinning. replaced the timer and now it works fine, but now when the washer finishes spinning, the agitator stops...
depending on your exact mode;
sounds like a brake, or a clutch
those are really only two parts it could be
on the whirlpool the brake is part of the transmission on the direct drive
Oct 15, 2009 | Washing Machines
Whirlpool won't spin at high speed
Sounds like you may have lost your basket drive and clutch assembly. This is a pretty involved job to replace for sure, and requires you to remove the inner basket, drop the transmission, etc. Does the unit make any wierd noises, like popping or grinding? Does it agitate ok in wash? I would bet almost for sure that its that basket drive and attached sub-pack thats went bad. If you want to try and tackle this yourself, let me know, and will get you directions to do so. Good Luck!!!!
Feb 02, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
