Question about Graco Quattro Tour Deluxe Travel System 7B00GRM3 Graham
Attaching rain cover to Graco 'I Love My Bear' travel system
We are unable to find the instructions as to how to attach the rain cover to our 'I Love My Bear' travel system. Please explain how this works if possible
5 Suggested Answers
  • 32 Answers
SOURCE: how does one attach the baby carrier to the pushchair
Usually there is a spring loaded bar in the stroller handle that you move down to the strollers seat that allows you to attach the baby carrier.
You can get your instructions at their webiste:
http://www.gracobaby.com/customerservice/instructions_category.aspx?catID=2
Just pick out your specific stroller (need more info than you provided) and you will also need Adobe Reader installed on your computer to read the instructions. Adobe Reader is avaliable at:
http://www.adobe.com/products/acrobat/readstep2.html
Posted on Nov 18, 2008
SOURCE: Reassemble Stroller
Perhaps if you go to the www.gracobaby.com replacement parts/toys section @ http://www.gracobaby.com/ReplacementParts/Pages/ReplacementParts.aspx# they have the manuals listed which may help you get it back together. In my manual for my travel system, it tells you how to remove the seat cover, and then I guess you just reverse the steps to put it back on. Hope you find the info you need.
Posted on May 07, 2009
SOURCE: Graco Quattro Tour de luxe rain cover - instructions?
Hi, we have the same pushchair and it took me ages to work it too! The easiest way is to put the handle bit on first, then at least you know its the right way round! The flaps that come from the handles fix around the front legs of the pram and then the bit that covers the front fix onto the back legs from what I can remember. So you end up with 2 layers at the sides. It sounds more complicated than it is and I don't have it with me to look and explain any better but I hope this helps!
Posted on May 14, 2009
SOURCE: I've taken the seating off of the Graco stroller
Not sure which model you have, but we just took ours apart. I unscrewed the rain cover (two screws on each side) and the cover slides off. I immediately put the two metal bars back in (with screws) so as not to lose the parts.
Our basket has several snaps to undo, then the basket pops off at the hinge point (toward the front wheels). There was a little button to press in on either side and it just pulled back and slid out. Then the basket slid off so we could clean it.
Hope this helps you out. Good luck!
Posted on May 25, 2009
  • 14 Answers
SOURCE: need instructions for installing carrier in
Recline the stroller seat. There are probably little plastic handles on each side of the stroller seat that you push in while you stand behind the stroller, to recline that seat. Then, you put the carrier into the stroller, facing the back of the stroller. The little notches in the bottom of the carseat fit right onto the edge of the stroller tray. You can test that you've done it right by pulling upward on the carseat. It should not come up and out of the stroller unless you pull the red handle on the back of the carseat as you life the handle of the carrier. I hope this helps!
Posted on Sep 29, 2009
Testimonial: "Looks like a slightly different system as FixYa would not let me enter the correct name. Carrier feet in tray was the key fix. Thanks."
I have a Safety 1st Acella Sport Travel System how do i put the infant carrier into the stroller
Hi
This model Safety 1st stroller is not available in the UK so we're unable to help.
Which country are you in?
May 23, 2012 | Safety 1st 01929PAC Travel System Stroller
I need instructions for a quinny buzz, dreemi, travel system. I don't know how to attach the different seats, travel cot etc
The Dreami Carrycot will attach using the adapters which usually come inside the Buzz Box (Black bag that is clipped onto the back of the chassis). These adapters also are to be used to attach the Cabrio Carseat.
Alternatively, you can visit www.quinny.com where you find the user manual.
I hope this helps.
Nov 20, 2009 | Quinny Buzz Jogger
I've taken the seating off of the Graco stroller but am unable to take off the back basket and the rain cover. Please help.
May 16, 2009 | Graco Quattro Tour Travel System
May 11, 2009 | Baby Gear
How does one attach the baby carrier to the pushchair
Nov 15, 2008 | Graco Quattro Tour Travel System
Silver cross 3d pram system in jet sport
i have a silver cross travel system and can only seem to fit the rain cover on properly when its in pram mode how do you do it when the car seat is attached
May 01, 2008 | Silver Cross 3D Stroller
EXTRA BASE
babies r us has the bases they are genric and work for a cuople different travel systems the sales person was super helpful and we love having the second base so there is no installing of the seat from my car to my husbands it just clips right in.
Jan 10, 2008 | Eddie Bauer Lightweight Travel System...
Graco Quattro Tour Deluxe Travel System 7B00GRM3 Graham Logo
459 people viewed this question
Top Graco Baby Gear Experts
Iron
Iron
Dennis Crouse
kenneth njonjo
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
