Question about Sony Handycam CCDTRV118 Camcorder
What does C:31:22 mean?
The camcorder was working fine untill one day a code by C:31:22 appeared and then it would not record. what does this mean?
Per the manual
C means you can fix E means professional service needed.
21 is moisture condensation. icon of rain drop in a box will flash on screen unless moisture in lens Eject tape let sit 1 hour or more to acclimate
31...manual says to eject cassete and reinsert, operate OR daisconnectpower cord andremove battery, reconnect, operate.
Posted on Oct 31, 2010
Sony Handycam DCR-SR200 e:91:01 means?
From page 32 of the user manual that is available for download here: (click here)
The error message that you are seeing requires that you to take the camera in for service, since a failure has occurred that the owner cannot fix themselves:
E:20:ss / E:31:ss / E:61:ss / E:62:ss / E:91:ss / E:94:ss
A malfunction that you cannot service has occurred. Contact your Sony dealer or local authorized Sony service facility. Inform them of the 5-digit code, which starts from E
Nov 26, 2011 | Sony Handycam DCR-SR200 Camcorder
On a Panasonic DMR-EZ48V I get a U56 error message when selection drives? When I scroll down from DVD to SD then VHS. When on SD scrolling to down to choose VHS drive, U56 appears on DMR-EZ48V's screen? I...
I think it is usb, not sure why that happens though. Panasonic for some very weird reason mixes upper and lower case letters in some of their on screen bits, so you never know for sure.
I know nothing about this stuff but was having a similar problem with not being able to get the dvd recorder to record onto a dvd.
This was after I had set up the camcorder to the set the day before.
I finally went to 'input select' on the remote and changed it until it worked again, just go through each setting until everything is back to normal.
Somehow, it appears as if the dvd recorder got itself set to the camcorder and would not let go of that setting without changing the input select. I have no idea why because I never touched the input select before this, I always controlled everything with the Directv remote. Hope this helps someone.
Feb 23, 2011 | Panasonic DMR-EZ48VK DVD Recorder
Nothing but a blue screen...ugh!
buy a cleaning cassette and play three times it will work well.
Oct 12, 2008 | JVC COMPACT VHS-C CAMCORDER
I have a Sony Handycam DCR-HC27E Camcorder which was working great until a few days ago. my problem is its suddenly not showing my recorded tapes, I was watching footage only a few days ago from my recent...
The gray strips usually mean the camera has dirt video heads - if it hasn't been dropped. Get a head-cleaning tape from Radio Shack or Best Buy, and run it a few times. If that doesn't do it, it'll have to be cleaned by a repair shop. Off brand tapes sometimes can cause this.
Jul 06, 2008 | Cameras
Nothing appears in view finder or on screen when recording
I HAD THIS PROBLEM ERROR CODE C31 : 22 WOULD COME UP AND TRV 118 CAM WOULD NOT WORK. I TRIED EVERYTHING TILL ONE DAY I BANGED IT ON A CARPETED FLOOR ON THE BOTTOM OF THE CAMCORDER 5 TIMES QUITE HARD. THEN THE CAM WORKED JUST FINE! MY CAM HADN'T WORKED FOR OVER 7 MONTHS. NOW I HAVE IT BACK. HOPE THIS HELPS SOMEONE.
Jun 18, 2008 | Video Cameras
Sony Handycam CCD-FX310
Record in slow mo mode, then playback in fast forward mode ;) Problem solved. You'll see the video in normal speed.
Oct 20, 2007 | Sony Handycam CCD-TRV37 Camcorder
Canon zr100 digital video camcorder won't record or show picture on screen
PLEASE USE MINI DV HEAD CLEANING CASSETTE & TRY , MAY SOLVE YOUR PROBLEM
Oct 20, 2007 | Canon ZR100 Mini DV Digital Camcorder
Not recording clear.
Hello, please try to playback these new recordings on some other Camcorder. If you experience good picture on the borrowed Camcorder it means that the video head is (partly) damaged. In order to cure this the video head is to be replaced. Please contact the Authorized Sony Service or the technician with the best references. Best regards, Arpi
Apr 18, 2007 | Sony Handycam DCR-TRV250E Digital...
Black screen picks up only bright lights
if it is only recording bright light sources then it must be working fine outdoors in broad day light. if so, it means the auto iris of your camera has stucked to minimum opening. was the camera lying idle for long time. try pointing the camera towards low light and bright light with quick moves.some times by doing so it gives a little jerk to the mechanism and it starts working, or lightly patting the camera on the lense side may solve the problem. otherwise let the repaires earn some money.
Oct 08, 2006 | Quasar VM-L152 Camcorder
Black bars in the picture
For Models: CC4352, CC4362, CC4393. Your camcorder has a wide format recording mode that lets you make recordings compatible with the 16x9 format. When 16x9 is activated, the camcorder records black bars at the top and bottom of the picture to produce the wide-screen (movie) effect. This is also known as "letterbox" recording. Do not use this mode unless you have a compatible 16x9 TV. When played on a regular TV, black bars appear on the screen. If the 16x9 feature is activated on your camcorder and you want to turn it off, press REC/PAUSE to pause recording, and repeatedly press DIGITAL EFFECTS until no digital effects display appears.
Sep 06, 2005 | RCA CC-432 Camcorder
Sony Handycam CCDTRV118 Camcorder Logo
777 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
