Question about Freezers
Freezer attempts to start but after a few seconds trips out
The freezer is quite old, an Electrolux type TF776 upright model. This fault has been occurring for some time, but usually starts after one or two tries. Now it only manages to start occasionally. I assume there is some form of protection on the motor. if so, is this replaceable and fairly accessible.
  • 30 Answers
There is a relay and protector, these are where the wires attach to the compressor,or rather how the power wires attach to the compressor.You can purchase a 3n1 start kit which has the instructions with it. Be sure to unplug the freezer before touching the wires or attempting to install replacement parts.
Posted on Mar 08, 2009
My freezer keeps overloading our switch board, whats wrong?
The freezer has a compressor which will draw quite a lot of current in the first half-second when it starts.
Either: Your freezer has a electrical problem and needs to be fixed,
Or: there is already too much drawing on the circuit that you are trying to add the freezer to, and the freezer is more than the circuit breaker will allow.
First try powering the freezer from some other socket on a different circuit (use a long cord), or unplug a few things that are nearby (in most houses, there will be several wall sockets on the same wire in each area of the house).
If the freezer runs fine from a different socket, or when you unplug some other stuff, then the problem is you are overloading the circuit you were originally trying to add it to.
If you can't get the freezer to run on any socket without tripping the circuit breaker then probably the freezer has an electrical fault and best you get a real electrician to check it (safety first!).
Oct 02, 2012 | Freezers
After moving to a new home, the freezer keeps tripping the breaker every few days
My first instinct is to ask you, are you plugging this freezer into a GFI outlet, one which has a breaker switch as part of the outlet? If so, that is the culprit and not the freezer, as refrigerators and freezers will often trip this ground fault indicator because water can on occasion reach ground, which causes the breaker to trip on the outlet.
Test this by plugging the freezer into a non GFI outlet for longer than a few days. Nothing is broken and you dont need refrigerator repair service.
Sep 29, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
Ge upright freezer, like 1988 - model # says ca 21 dkc rwh
by the time you have fixed any faults,you might just as well buy a new(er)more effecient f/freezer.cost you less in the long run(got mine from a garage sale,owners were moving far away....)
Apr 06, 2010 | Freezers
Hi there. I have Electrolux freezer EUU 6174. The problem is that the compressor is switching on and off for 5 seconds and the temperature is to hight. I can't store any food in the freezer. can u help me?
your problem is likely the starting capacitor .. that is a metalic part (about the size of a fist) that is mounted on the compressor or near it .. it will have wires going to the compressor .. the capacitors are not very expensive and usually easy to change but make sure the unit is unplugged .. you can either write the numbers down off the capacitor or remove it and take it with you to a parts place to get a match ... take a photo or draw a diagram so you know where the wires go .(they usually just plug in) . .. you can order one from electrolux (might be higher price) .. dont allow the unit to continue running with the bad starting cap since the compressor can be damaged eventually ... if you call a repairman .. then make sure you tell him its a bad starting cap so he can bring one wiith him and avoild a second trip .. give him the model number and numbers off the capacitor if you can ... often the capacitor is actually two capacitors in one can ... one is for the compressor and the other is hooked up to the fan ... in that case replacing one would also replace the other ..
Dec 23, 2009 | Electrolux 3.53 cu. ft. / 100 liter...
The motor in my freezer makes a very loud noise and sounds like it is trying to start, it takes a few seconds before it stops the noise, then starts running the freezer.
That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Oct 27, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore upright freezer model 29238 keeps tripping switch
If the compressor actually runs for more than a second or two its likely the compressor is bad. Some models had a 5 year warranty and some ten years on the compressor only. The replacement of the compressor is likely beyond your abilities unless you are a service technician.
A typical cost for such a repair can be more than the freezer may have cost you if nothing is under warranty. Good Luck.
Aug 31, 2009 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Jun 10, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Frigidaire freezer quits running
actionsnax please remove the freezer from the GFCI. What is happening on this old unit is that if the compressor shuts off then tries to come back on before the pressure in the system equalizes, the compressor can pull 12 amps. This is normally higher than the trip point of the GFCI. I had this happen years ago with a brand new Amana SXS refrig, in that case no one knew the unit was on a GFCI. The manufactures require that this units not be on a GFCI.
Hope this helps
Feb 01, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Kenmore freezer not cold at all!
We had a Kenmore upright which worked fine but then suddenly was not keeping food frozen. Long story short, do not store anything on top of the freezer unit. It will insulate the coils that run across the top of the unit, and cause your compressor to work harder than it needs to, and eventually overheat and become ineffective. Says nothing about it in the user manual. We learned the hard way by losing food.
Jul 30, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Freezers Logo
126 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
