Question about Dell W4200 42 in. HD-Ready Plasma Television
My Dell w4200hd will not turn on. The color on the little light by the power on/off switch will change from what I think is standby color to a different color when I try and turn it on, and I hear something "click" in the tv, but it doesn't turn on. If I unplug the tv and plug it back in, the light color returns to the standby color. I was told by a technician that I need a new power supply. However, I don't know where to find one. Any help either confirming that I do in fact need a new power supply, and if I do, where I can find one would be appreciated. Thanks in advance for the help.
  • 35 Answers
I do have the power supply at my shop. but i don't think the power supply is the problem. i already replaced the power supply on this set with this symtom and no help. you can find parts at discountmerchants.com J.D.W.
Posted on Jun 18, 2009
If you decide that it is not fixable, are you willing to sell the stand?
Andy
Posted on Jun 24, 2009
  • jwg5968 Jul 12, 2011
    I thought you were supposed to help cuct fix tv, not to try and get a stand from him when he cant fix!!!
    New Friend:
  • 90 Answers
If the light is orange for 15 secs then turns blue, with no video, its def the power bd. its sending low voltage to the main bd. it does need replaced
Posted on Apr 13, 2009
Dell W4200HD plasma only turns on with the x-main unplugged
The sustain boards need to be replaced in pairs. I replaced just the bad one before and ended up burning out the other old one and the new one aswell
Feb 04, 2018 | Dell Televison & Video
Green light blinking on logic board
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Oct 26, 2016 | Dell Televison & Video
I have a 36'olevia HDTV.......it has a detachable power cord and it also has a power switch in back. When I plugged it into the wall,turned on the power switch, and pressed the power button, I got no
The light is likely the standby light if it is on when set is off and goes out when set turned on or changes color when set comes on.
The fact the light is on should rule OUT the main fuse for the set, most likely the problem is the power supply itself inside the set
The Standby supply is part of the main power supply and when set is plugged in and off it runs 7/24.
Have you had problems where the set was "hard to turn on" or you had to try to turn it on several times before it would stay on?
Dec 07, 2012 | Televison & Video
I have a Dell Dimension E510 and have had this problem in the past. My dell has been shut down for a few weeks and wouldn't power on. maybe a month later, i randomly checked it after being unplugged the...
Some power supplies have an independent switch to turn on the power supply before you can power up the computer from the front. Does yours have a switch on the back?
Nov 01, 2010 | Dell Computers & Internet
Dell Dimension 4550 will not power on but standby light on.
In all my years of fixing computers, 98% of the time it is the power supply, 2% the motherboard and 0% the switch. Just because the standby light is on does not indicate that the power supply is functioning correctly. The power supply puts out many different voltages....5v, 12v, 1.3v, and 3.3v. If the 3.3 is working then the standby light will come on but if any of the others are not working correctly then the computer won't turn on at all. You can check the switch by checking the resistance of the two wires that the switch are attached to using a multimeter. When the button is depressed, it should go to 0 and when it is not depressed it should be at 1. I would suggest swapping out with a known working power supply to verify the issue.
Jun 25, 2009 | Dell Dimension 4550 PC Desktop
TV won't turn on
have a repairman check this the tech infor for repair is:
In rush Limiting Resistor location R8010 its comen for this model to open the resistor
its on the power supply module value is 6.8ohms at 7 watt standup cement Style resistor.
I think this will do it.
thanks,
daniel.
Jan 13, 2009 | Samsung HCL4715W 47" Rear Projection...
No Picture
Hello. It looks like I have the same problem that you had with your Dell W4200HD.
Where did you find the new power supply for yours?
Also, did you determine that you didn't really need a new power supply and that it was just a connection problem? If yes, could you please give me some help with what you did to get yours working.
Also, do you still have the power supply you took out of your TV? If yes, would you be willing to sell it to me?
Thanks in advance for your assistance.
Rocky Pruitt
rjpruitt@rjpruitt.com
Dec 26, 2008 | Dell W4201C 42 in. Plasma HDTV
Is Dell W4200HD Y-Main board and Dell W4201C HD Y-Main board compatible
The port locations do not seem to line up the same so I'm pretty sure they are not interchangeable
http://support.dell.com/support/edocs/systems/w4201c/om/OM.pdf
http://support.dell.com/support/edocs/systems/W4200/W4200UG.pdf
It can be worked on by a local TV repair, then TV was made for Dell by Philips
Jun 12, 2008 | Dell W4201C 42 in. Plasma HDTV
Dell W4200 42 in. HD-Ready Plasma Television Logo
1,005 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
