Question about Casio fx-300ES Calculator
How do you Factor a Polynomial on a Casio fx-300ES
I really need to know
  • Casio Master
  • 7,993 Answers
Sorry, but you cannot use this calculator to factorize a general polynomial.
1. It does not know symbolic algebra.
2. It can only manipulate numbers.
However if you have polynomials of degree 2 or 3, with numerical coefficients (no letters) you can set [MODE] to equation and use the equation solver to find the real roots of 2nd degree or 3rd degree polynomials. Assuming that your polynomials have real roots (X1, X2) for the polynomial of degree 2, or (X1, X2, X3) for the polynomial of degree 3, then it is possible to write
P2(X) =a*(X-X1)(X-X2)
P3(X)= a(X-X1)(X-X2)(X-X3)
This is an approximate factorization, except if your calculator configured in MathIO, has been able to find exact roots (fractions and radicals)
where a is the coefficient of the highest degree monomial aX^2 +...
or aX^3 +....
But I have a hunch that this is not what you wanted to hear.
Good luck.
Posted on Oct 23, 2009
2 Suggested Answers
  • 7993 Answers
SOURCE: how to factor a polynomial equation on casio fx-300es?
The Casio FX-300ES does not handle symbolic algebra. So it cannot factor a general polynomial expression. The methods can be found in any book on Algebra.
However if you are interested in approximate factorization of quadratic and cubic polynomials, you can use the calculator to do that. It can solve aX^3 +bX^2+cX+d =0 and the quadratic equations.
If you want to factor a cubic polynomial P3(X) = aX^3+bX^2+cX+d , you write the corresponding cubic equation as aX^3+bX^2+cX=d =0 , then you divide all terms of the equation by a to obtain
X^3+(b/a)X^2+(c/a)X+(d/a)=0.
You use the calculator to solve (approximately) this equation.
Suppose you find the 3 roots X1,X2,and X3. Then the polynomial X^3+(b/a)X^2+(c/a)X+(d/a) can be cast in the factored form (X-X1)(X-X2)(X-X3) and the original polynomial P3(X) can be written as
P3(X) = a*(X-X1)(X-X2)(X-X3)
You can handle the quadratic polynomial the same way.
P2(X) =a*(X-X1)(X-X2) where X1, X2 are the two real roots
Hope it helps.
Posted on Oct 17, 2009
How am i supposed to solve a quadratic equation ?
Use the quadratic formula, or factor the quadratic polynomial. Once factored into a product of two first degree binomials, the roots are obtained by setting (in TURN) each binomial factor equal to zero.
May 02, 2014 | Casio fx-300ES Calculator
How do i factor
This calculator is unable to factor a polynomial expression.
In general there are a few factoring methods
  1. Factor by grouping terms
  2. Factor by completing the square (quadratic polynomial)
  3. Factor by finding two integers such their sum is equal to the coefficient of the middle term, and their product is equal to the third (constant term). This is valid for a quadratic polynomial where the leading coefficient (of the x^2 term) is equal to 1. X^2+SX+P
A cubic equation can be solved algebraically, although two solutions may be complex. Use the Cardano formulas. A quartic equation can be solved by the formulas for the quadratic equation, if you transform the quartic equation to look like A(X^2)^2 + B(X^2) +C=0
Jul 31, 2012 | Casio FX-115ES Scientific Calculator
Can casio fx-991es factor?
No it cannot factor. It does not do symbolic manipulations.If you know a bit of theory of polynomials you can find the roots of the polynomial equation. The calculator has a Solve utility. Once you have the roots, you can use your knowledge about polynomials to carry out the factorization procedure.
Aug 31, 2011 | Casio fx-300ES Calculator
Is my fx-300 capable of factoring trinomials?
Sorry, but no! it is not capable of factoring anything. It can however solve for the roots of a polynomial equation.Write your polynomial as P(X)= a(X² +(b/a)X+c/a) =0. Use the calculator to solve the polynomial equation X² +(b/a)X+c/a =0 and find the roots X1, and X2. You will then be able to write the original polynomial as P(X)=a(X-X1)(X-X2). Beware that by using the calculator, the values of the roots are approximate.
Mar 14, 2011 | Casio fx-300ES Calculator
Can I factor a polynomial with a Casio fx-9750GII calculator
The short story is that this calculator does have a computer algebra system or CAS and thus cannot factor polynomials with arbitrary (unknown) coefficients or known coefficients.
However if the coefficients are given you can ,if you are willing to travel that way, factor approximately a polynomial P(x).
Basically, the idea is that any polynomial P(X) of degree n can be written in the factored form (X-x_1)(X-x_2)...(X-x_n), where x_1, x_2, x_3,...x_n are the roots (real or complex) of the equation P(X)=0.
The procedure ( for a 3rd degree polynomial) is as follows: (the fixYa site parser will remove the plus signs, so I am writing the whole word plus instead of the mathematical sign
If you want to factor a cubic polynomial P3(X) = aX^3 plus bX^2 plus cX plus d , you write the corresponding cubic equation as aX^3 plus bX^2 plus cX plus d =0 , then you divide all terms of the equation by a to obtain
X^3 plus (b/a)X^2 plus (c/a)X plus (d/a)=0.
Suppose you find the 3 roots X1,X2,and X3. Then the polynomial X^3 plus (b/a)X^2 plus (c/a)X plus (d/a) can be cast in the factored form (X-X1)(X-X2)(X-X3) and the original polynomial P3(X) can be written as
P2(X) =a*(X-X1)(X-X2) where X1, X2 are the two real roots.
To find the various roots you must use the solve( application.
Nov 11, 2010 | Casio FX-9750GPlus Calculator
How do you factor a trinomial on a Casio 9750Gii. Example problem: 6 + 23k + 7k2
You cannot factor a polynomial with the help of this calculator. It does not have a Computer Algebra System or CAS. You can factor it approximately.
  1. You can however rewrite the equation 7k^2+23k+6=0 in the canonical form X^2+ (23/7)X+(6/7)=0
  2. Calculate its discriminant Delta= (23/7)^2-4*(6/7), which is positive, meaning that real solutions exist.
  3. Calculate the two roots x1 and x2 (approximately).
  4. The polynomial can be factored as (X-x1)(X-x2)
May 05, 2010 | Casio FX-9750GPlus Calculator
Does Casio fx-7400G plus has a factoring polynomial option and how do you deal with it?
No it does not. Sorry. I checked their website and they do not have programs that could factor an arbitrary polynomial.
Feb 10, 2010 | Casio FX-7400G Plus Calculator
How to factor a polynomial equation on casio fx-300es?
Hope it helps.
Sep 27, 2009 | Casio fx-300ES Calculator
How i can do polynomial calculations with the casio fx 300-es
My niece exhange the calculator. txs a lot anyway.
Mar 21, 2009 | Casio fx-300ES Calculator
How to factor with this model
Sorry, but you cannot use this calculator to factor a general polynomial.
However if you have polynomials of degree 2 or 3, with numerical coefficients (no letters) you can set [MODE] to Equation and use the equation solver to find the real roots of 2nd degree or 3rd degree polynomials. Assuming that your polynomials have real roots (X1, X2) for the polynomial of degree 2, or (X1, X2, X3) for the polynomial of degree 3, then it is possible to write
or aX^3 +....
While the [MODE][5:Equation] only handles quadratic and cubic equations, the [SHIFT][SOLVE=] solver finds the roots of arbitarry expressions (not limited to polynomials). In principle you can use it to find the roots of an expression. If it is a polynomial of dgree higher that 3 you can factor it (approximately).
Hope it helps.
Dec 09, 2008 | Casio fx-300ES Calculator
Casio fx-300ES Calculator Logo
885 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
