Question about Dreamline SHCM-2358-00 Aluminum Five Handle Shower Panel With Rainshower H
Im installing a shower panel in my shower
Its a 22ov/15 amp
i know it needs dedicated circut but does it need to be on a gfci breaker?
  • 10,865 Answers
You must have gfci protection since the power is going to the shower and you don't want anyone to get electrocuted. You can either use a gfci breaker or you can install a regular gfci outlet between the panel and the shower. The outlet will be a cheaper solution to the issue.
please mark this answer as a fixya!
Posted on Mar 08, 2009
  • Joe Hogan Mar 08, 2009
Dedicated 20 amp outlet
Ideally you should run the line straight from the circuit breaker out to your hot tub, but if the line running from your circuit breaker to the box you're using now is 20amp. you can absolutely connected to that. to be up to code it cannot be an open box it needs to be closed After you wire in your 70ft connection. (that's assuming the box that you're using is dedicated already to your hot tub) then the only difference would be is your using extra line and costing you tenths of a penny extra and electricity per hour.
Jul 27, 2013 | Electrical Supplies
Installation: Electrical Requirements
13Mb product manual is a big download ... electrical info page 13:
Recommended both water heaters require dedicated single-phase 15 amp 120Volt line with correct polarity. This is 14 gauge wire and 15 amp breaker for each unit.
I would put both water heaters on surge protection and GFCI. Most water heaters are not protected from surge, and manual says line noise can affect operation of water heater.
Your local code would say if GFCI is required. Install GFCI breaker in main panel if required.
Install inline surge protector: Or add main breaker box protection.
AO Smith service handbooks:
Add a comment and say what you discover
May 17, 2013 | A.O. Smith BTH-199 BTH-199 100 Gallon...
Installing arc fault interrupter with ground fault
Question is vague. Arc fault and ground fault are slightly different.
Are you installing arc fault breaker?
Code says Maximum 12 boxes per circuit breaker.
Arc fault breaker and GFCI outlet in bathroom?
>>> do not connect this way.
Do not install 2 fault protections on same circuit.
Install the arc fault circuit breaker, and then remove bathroom GFCI, and replace with ordinary outlet, or switch-outlet.
How many outlets can be connected to a bathroom GFCI?
It depends on total boxes on circuit.
Count the boxes. Max 12 boxes per circuit breaker.
How many amps can be connected to 15 amp device?
15 x 80% = 12 amps
Electricians use 80% rule to calculate safe maximum
Add a comment
Apr 21, 2013 | Siemens Seimens Arc Fault Breaker
I am getting a new spa that will have a converter so I can use 110 and 220 if I ever want. The 15 foot cord has a gfi built in. the run of wire will be 75-90 feet. I know that I need a dedicated line to...
1) Subpanel will let you add additional breakers:
2) Stress test main panel if needed
3) Do not use 2 gfci's on same line.
This can cause errant tripping.
4) Separate disconnect is required for all outdoor electrical installations.
This is to prevent somebody from working on live electricity outside because they cannot access circuit breaker panel, or because they turned off wrong breaker.
Simple pull-out disconnect is all that's needed.
Feb 20, 2013 | Electrical Supplies
Why would two adjacent circuit breakers in a panel trip for no apparent reason? We reset them and everything seems normal.
My first thought is that even though it's only feeding that single outlet in the room; many times the neutral wires are made together in a panel (neutral/ground bar),which tries to carry the load of the initial tripped gfci. and tripping itself. Was there a decent amount of power plugged in to either the 'dedicated' outlet or the series of outlets that go to the 2nd breaker?
Jan 24, 2013 | Electrical Supplies
I have a 15 amp air conditioner, with afci plug on a dedicated line, on a 20 amp breaker. Why does it nuisance trip, and not allow me to reset it, is it because of the 20 amp breaker? DRJ
It's definitely not related to the 20 Amp breaker. You do mean GFCI, right? The kind built into the end of the cord on the air conditioner, right? The GFCI is either detecting a ground fault (which means it's doing it's job and there is something wrong with the cord or the unit) or you have a bad GFCI. If the GFCI is in the wall receptacle, that could be a different story.
Jun 24, 2010 | Solar 15 Amp Murray Afci Circuit Breaker
LG Washer trips dedicated breaker
That to me seems like an electrical problem. Every now and again you can get a bad GFCI receptacle that will constantly keep tripping. I would also see that the GFCI is properly sized for the circuit. It needs to be a 20 AMP circuit (just dedicated to the washer) and a 20AMP GFCI receptacle. The way to tell is the 1 of the three prongs of the 20AMP GFCI will be in the shape of a "T" while a 15 AMP will have 2 straight prongs and the ground prong. Hope this ws helpful, don't go spilling any money into your washer without getting that fixed first, because it doesn't seem like a washer problem.
Apr 30, 2010 | LG WM2016C
I just tested the breaker and it won't reset. I have other gfci breakers in the panel and they test and reset fine. Is there anything that can prevent the gfci breaker from resetting?
yes. If you still have the fault it will not reset. Disconnect the out going wire to isolate the breaker and try again. If it still doesn't reset then the GFCI breaker is bad and needs to be replaced. Hope this helps you, Jeepfxr
Jan 28, 2010 | Cutler Hammer 1 Pole 15 Amp Ground Fault
Pls what is the power supply for kenmore washer
I think I understand your question. If you're in the U.S., washers should have a dedicated 110-120 volt, AC, 15-Amp circuit with a GFCI (Ground Fault Circuit Interrupt) in the circuit (either at the outlet or in the breaker box).
Is this the answer you need? If not, let me know.
Sep 02, 2009 | Kenmore Washing Machines
Ariel 701 wiring
I have the same tub and had a similar issue. We originally connected a 12guage with 20 amp circuit breaker and breaker kept trippin. The solution was to connect 10guage wire with a 30 amp breaker. Connect that to a gfi then connect the 12 guage wire coming out of the generator to the gfi (woulda made sense to just have 10g coming out but it was made in China). Being that theres only a short lead coming out of the generator its fine to run 10gauge, just make sure there connected seperately to a gfci breaker. The pump is fine 12 guage 20 amp.
Jul 27, 2009 | Dmm WMK-A06 Pearl Steam Shower Unit,...
Dreamline SHCM-2358-00 Aluminum Five Handle Shower Panel With Rainshower H Logo
104 people viewed this question
Top Dreamline Home Experts
john h
Tom Chichester
Are you a Dreamline Home Expert? Answer questions, earn points and help others
