Question about Canon PIXMA MP980 All-In-One InkJet Printer
Can't print from my mac to my canon mp980 wireless printer
I was printing successfully over the network until I added a windows xp computer to the print network.  I have a verizon router that is directing traffic.
Now when I try to print from my mac I get the message that the printer is offline and some indication that the print server is not connected or at least not communicating with the mac.
  • rose_russ Mar 09, 2009
    Thanks.  I actually ended up setting up the printer connection again and dropping one of the listed printers.  Fortunately, I was able to print from Windows and then to also print from the Mac.
    Thanks for your help.
    rose_russ
    Scholar:
  • 124 Answers
Sounds like when you added xp you inadvertently installed new print driver on server.
Try rolling back driver. But may drop xp from printing.
Best solution network printer to router bypass server. Will require hard wire from printer to router. disconnect from server may need network card for printer.
Posted on Mar 08, 2009
  • Mark Van Skiver Mar 09, 2009
    Your welcome! Glad you got it working.
Can you do macs? how do i print duplex with this printer, duplex is suported by my mac
The Canon-supplied MP530 driver doesn't have duplex printing as a print option. Mac OS 10.5 has Gutenprint drivers built-in for a number of popular printers, including the Canon MP500 which is a near match for the MP530 and includes the two-sided option for printing.
With the MP530 plugged into your Mac (or, presumably, available over the network) go to the Add Printer wizard ( System Preferences > Print & Fax > + ). Pick MP530, name the printer something like "MP530 Gutenprint" and under "Print Using:" choose "Select a driver to use...", select "Canon PIXMA MP500 - Gutenprint v5.1.3" and then Add the printer.
The MP500 Gutenprint driver isn't a perfect substitute for the MP530 one, however, so you should do this in addition to installing the proper MP530 driver from the Canon website and adding the printer using that driver with a name like just "MP530" or "MP530 Canon". In a year or two of using the Gutenprint driver I've only once had a print job that wouldn't render correctly (some missing lines on the printout), and for that one time I had to switch to the Canon-supplied driver to get it to work. All the other times I find it very convenient to have two-sided printing available as an option.
The two sided printing isn't particularly fast, but it's a whole lot more convenient than manually printing the odd pages and then the even pages.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Mar 28, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Tip
Drivers and Manuals for PIXMA MP980 Windows and MAC OS
Here I will show you where to find drivers and manuals for the Canon Pixma MP980 Wireless photo all in one printer.
Drivers for this printer are available for Windows 98, windows ME, windows Xp, Windows Vista, windows vista 64bit editions, windows 7 and windows 7 64bit editions.
On the Mac side drivers are available for Mac OS X 10.3/10.4/10.5/10.6
A full on screen manual, quick start guide and other instructions are also available.
To download these drivers and or documentation for your printer please visit
THIS PAGE
Note that the picture below reads mp730 but the actual page linked will be for mp980
1. Click on Drivers & downloads
2. Select your OS ( Operating system, windows, mac etc )
3. All available drivers, documents etc will be available below.
For some of the documents a PDF reader may be required to open and read / print them.
To obtain a PDF reader, read this page
PDF Documents. Pdf reader(s)
Thank you for reading and I hope your printer is up and running again.
-Ekse
on Mar 11, 2010 | Canon PIXMA MP980 All-In-One InkJet...
How do I hook my canon 480 printer directly to my wireless router to make it a network printer so both of our laptops can print. 1 mac & 1 pc ???
First, plug your printer into your router and turn on both the router and the printer. Second, on your mac open System Preferences>Print and Fax>click the plus sign below the list of printers, you will be guided through the process to set up your network printer. Now to set up a printer on Windows XP click here, Windows Vista click here. Windows 7 and vista are pretty much the same set up.
Jan 01, 2010 | Canon Pixma MP480 All-In-One InkJet...
Can't connect Xp laptop to 64Bit Vista PC to be able to print across wireless network
yes easy to fix, just share your print driver give it a share name like canonmp780 on the pc it is connected to
then get on your laptop asuming its on your wireless network and in the start bar run this command. \\ your computer name one printer is connected to \ canonmp780.
so if your computer name is windows and your printer name is canonmp780 the run command will be: \\windows\canonmp780 hope this helps and really easiest way to connect to it.
Canon tech
Apr 12, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Color photo printing
On the menu tab for 4X6 ,under effects ,you have selected black and white or grayscale
Apr 02, 2009 | Canon PIXMA MP980 All-In-One InkJet...
I have a canon Pixma MP610. It is installed on a PC running windows XP, and working fine. I have a PC Laptop running Vista. Our computers share a network fine. I would like to be able to print from my...
if your pc has wireless connectivity and your printer has wireless conncectivity you can print them directly without any trouble, but if your printer doesnt have wireless pls go this website and download this great software and use this and share your printer amongst your pc's
www.printeranywhere.com
cheers dont forget to mark my solutions pls
Nov 08, 2008 | Office Equipment & Supplies
Wireless printing
The MP830 does not include the ability to do Wireless Network printing. You can however, connect this printer to one of your Windows or Mac PCs and share it on the network, which is wireless, therefore accomplishing the same thing.
1) Install the Drivers and Software that came with your Printer.
2) Go to the Control Panel > Printers & Faxes
3) Right-click your printer and click "Sharing"
4) Choose Share this Printer, and give it a name.
5) You can then on, use the Add Printer Wizard on any other Windows PC and install it by searching for network printers.
Step 1 is the same for Mac
2) Go to System Preferences > Sharing
3) Check the box for Printer Sharing
4) Any Mac on the network can see it!!
5) Added treat: go to http://apple.com/bonjour to install bonjour for Windows, using this software you can print using any Mac printer on any PC
Jan 08, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon LBP-800 don't print on a network
I have tried to print with Canon LBP-800 with 2 different print servers and no success. It seems this printer cannot be used with a print server... only with a direct connection to a computer... it supports printer sharing from windows... hope this helps...
Jan 01, 2008 | Canon LBP 800 Laser Printer
Canon PIXMA MP980 All-In-One InkJet Printer Logo
1,849 people viewed this question
old marine
old marine
