Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Having a water dripping from top of fridge!! p
    Guru:
  • 462 Answers
The problem could be a number of things but you have to know the top of the fridge is the bottom of the freezer (usually) and this surface must be colder than the air that's being circulated in the refg compartment. Obviously Side by Side or bottom freezer would be differant.
4 items to check :
1your air damper switch is set to give you a colder freezer and not allowing enough cooling and dehumidification in the fridge compartment (explanation below of the reason you have to have air flow unobstructed)
2 the defrost on the freezer is not taking place (Explained below)
3 the door seals are not sealing. Use a piece of paper like a $1.00 and slide between the door gasket and the frame if you can pull and push it and it not fold up the seal is open and not working.
4 some fridges have a energy saver switch which is a heater. This switch turns the heater off. It is not needed in everyone's home or locality so the switch may be set to "save energy" and thus not keeping the "dew" off the fridge (usually these heaters are only on the doors and possible on the outer sides of the fridge and not the ceiling, so I doubt this is it, but I do like to eliminate this).
One of the more common things is the defrost not taking place and this can be a verity of thing Ive seen drain lines stop up and refreeze eventually to the point where the upper part of the fridge is too cold not to drip when the humidity come up like in the spring time. A faulty defrost timer / initiator or a bad element or safety switch, bad wire can also cause non defrost.
Defrost is required because the freezer is where the coldest part of the refrigeration circuit is and it requires air from the fridge to move over the coil. When this movement stops a cold ceiling can result. It will eventually follow with warmer fridge temps as humidity and time progresses.
Hope this helps with the mystery of most common problems associated with:
having a water dripping from top of fridge!!
Please grade ma accordingly and GOOD luck!.
Posted on Mar 08, 2009
Igloo mini fridges
The question is: Are you seeing water inside the fridge where it shouldn't be? Are there water stains in the try? Some of these have no tube, the water just drips from a small hole above the tray.
Jan 05, 2018 | Igloo FR834A Stainless Steel 3.2 Cu Ft...
Water dripping into the fridge and freezing
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 18, 2010 | Kenmore 74262 / 74264 / 74269 Top Freezer...
Water dripping onto back of shelves and into drawers and bottom of "designer style" frig
There is a tube at the back of most fridges which routes freezer water to a evaporator tray at the bottom.
Usually in the fridge at the top just below the freezer is a small collection cup. If that cup or tube is blocked then it will drip water into your fridge.
Let me know if that helps.
Dec 06, 2009 | Whirlpool Refrigerators
Fridge is dripping directly onto top shelf. It is
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you have any other question. Mike
Oct 22, 2009 | Frigidaire FRT18FS6C Top Freezer...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
May 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
General Electric Fridge/Freezer, dripping water in fridge
Refrigerator/freezers often have a de-icing cycle. Moisture condenses on the evaporator coils and freezes. The deice cycle melts and the water is supposed to flow through a tube to either a pan at the bottom of the fridge or a cup attached to the top of the compressor. Sounds to me there may be a plug or obstruction causing the water to back up. Test with water to see flow through the tube.
Another possibility is the seals around the doors and the insulation in the walls could be compromised. The seals are replaceable. Accessing the insulation is a major pain. I recommend finding another fridge to avoid such pain.
Oct 12, 2017 | GE Refrigerators
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
171 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
