Question about Brother GX-6750 Typewriter
Correction doesn't work
When you use the correct key it backs up to the previous letter and strikes it like normal but do not remove the letter.  I tried to change the correction ribbon but that didn't help.
  • 125 Answers
Hi:
Make sure that you are using a fresh correction tape, not one that has been sitting in a box for years. Also make sure that the correction tape is installed correctly and that the "sticky" side is facing the printed paper.
Good Luck
Andrew
Posted on Mar 14, 2009
Is there an auto correction feature
The key to the right of the spacebar with the "X" printed on it is the correction button. You just place the carrier on the character to the right of the wrong one and hit the corr. button. The carrier should automatically back up and and remove the incorrect character and if you hold the key down it will continue to back up and remove characters. then you just type in the right one(s). Of course you have to have good "correctable" ribbon and correction tape cartridges installed. If the tapes are old you may have to advance them by typing and correcting or by manually advancing them before they will work. If the correction doesn't remove all the ink from the paper you may have a bad ribbon and/or correction tape.
Sep 17, 2015 | IBM Wheelwriter 3500 By Lexmark Electric...
I have replaced the ribbon cartridge and for some reason the entire cartridge will not sit back down in place. In other words, the letter wheel strikes the "erase" cartridge. I have tried and...
When the T/W is turned on does the ribbon go up and down or does it just stay in one place? Try it without the correction tape attached if it works then the correction tape is installed wrong. If it doesn't check the plug on the ribbon motor and give it a shot of WD40 on the upper and lower bearings (it is located under the ribbon deck at thr R. front.
DickyO
Sep 07, 2011 | Lexmark Wheelwriter 1500 Typewriter
For a Swintec 8014 typewriter: the bottom portion of the letters are not tranferring to the paper when the keys are striked. although the ribbon shows the full letter being striked, only the top portion...
Check to be sure the ribbon dosen't have a fold in it and is fully seated in place, be sure the platen is fully seated in the side frames, check the correction tape for proper imstallation it can rob the print if to high.
DickyO
Dec 03, 2010 | Swintec Office Equipment & Supplies
Hi
Many brother type writers have two cam assemblies under ribbon holder. One operates the print hammer and the other operates the correction ribbon lift. sometimes they gets stuck or lock themselves up. turning on and off a few times will take care of it, but sometimes it needs to be worked on by a tech. If you look when you type a character, most likely the print hammer is not firing or it is striking the correction ribbon instead of the black ribbon.
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting Fixya.com
Apr 08, 2010 | Brother EM-530 Typewriter
Everything works except for spacebar & key advance
The T/W is probably just gummy. Will it tab? If so the correction mech. is probably the trouble, if not try some WD40 on the silver shaft that the s
carrier slides on.
DickyO
Jun 18, 2009 | IBM Office Equipment & Supplies
My typewriter doesn't type..won't display letters, but keys work.
alot of the brother t/w's have 2 cam assemblies under ribbon holder. 1 operates the print hammer and 1 operates the correction ribbon lift. sometimes these will hang or lockup. sometimes turning on and off a few times will take care of it, but sometimes it needs to be worked on by a t/w tech. if you look when you type a character, most likely the print hammer is not firing or it is striking the correction ribbon instead of the black ribbon.
hth,
razors
Feb 27, 2009 | Brother Office Equipment & Supplies
Correct key
Two possibilities, one the correction tape is twisted and the wrong side is .facing the paper. The shinny side should be facing you, the dull side facing the paper. Second possibility you must make sure the ribbon is compatible with the correction tape. There are 2 types of ribbons. A correctable one (orange or yellow knob) and a multi strike (blue or purple knob on ribbon cartridge). The lift off correction tape (orange or yellow spools) only works with the correctable ribbon and the cover up correction tape (blue) works with the multistrike ribbon.
Jul 07, 2008 | Brother ML-100 Typewriter
Typewritter won't correct!
After you press the corr. key you must retype the wrong letter then type the correct letter.
DickyO
May 15, 2008 | Office Equipment & Supplies
Not typing correct letters
Send it back for repairs if under warranty. This is not an office machine it is designed for very light home use.
Mar 09, 2008 | Brother ML-100 Typewriter
Correction Tape
Check the way the correct tape is installed. I have seen people twist them around the guide backwards and the correction material is facing away from the paper. Also can you see the correction tape lifting up?
Aug 13, 2007 | Brother GX-6750 Typewriter
Brother GX-6750 Typewriter Logo
115 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
