This started popping up just shortly after our warranty expired. For the price we paid for this set we shouldn't have to pay for a faulty circuit board or repairing it!
I have the same overpriced piece of junk and have the f-1 code also . It means you have a primary control failure . Also known as the computer brain module . It cost anywhere from 165.00 -400.00 depending on where you buy it . It will only gets better ,sometimes I get an f-51 code which is a motor rotor sensor failure but could be a false code because somehow this thing will **** clothing under the drum and cause drain problems as well as floods . I got the service manual offline for the repairs , but you may also complain to whirlpool because they are aware of the problem and they may send a repairmen even if its out of warranty . Best bet don`t buy anymore whirlpool junk
I have a whirlpool washer Model # WTW6200SWO (3 years old). The F1 fault code comes on and does not operate. I called 1 800 253-1301 and spoke to a very nice lady. She looked this problem up and said it is a quality issue and is sending someone out to fix at no charge.
Went thru it's wash & rinse cycles but then the load (3 T-shirts) became unbalanced...
(More)
Went thru it's wash & rinse cycles but then the load (3 T-shirts) became unbalanced & it wouldn't spin. It sat unbalanced & beeping for a time because I wasn't in the room. After correcting the balance, it still won't spin. It is barely 2 and a half years old. Tried the 'drain & spin' setting, wouldn't spin. Emptied it and while it "thumps" like it is trying to spin, it never succeeds.
My washer stops at either 20 mins or 8 mins. The first load always goes good and after that...
(More)
My washer stops at either 20 mins or 8 mins. The first load always goes good and after that problems...
Now and again light will flash and letters LD will come on. We thought load was uneven and moved it...
(More)
Now and again light will flash and letters LD will come on. We thought load was uneven and moved it around and still showed the same had to unplug washer to get it back
