Question about Refrigerators
Freezer stays cold but fridge is warm - Refrigerators
  • 1 more comment
  • onlythe2ofus Mar 08, 2009
    I have the same problem in a JennAir side by side
    mode JCD2389GES.
  • glojane123 Mar 09, 2009
    I unplugged the fridge for 24hrs, soaked up 3 towels of water and plugged it in again. That lasted 2 weeks until the fridge would not cool past 42 deg (although the freezer is working fine). I noticed no frost build up anywhere, but the flap for the ice maker was sticking open. I took the freezer door apart, fixed the flap, tested the heater which was ok, and replugged the fridge back in. Two weeks later same results, however the flap for the ice machine is still functioning properly. Could it be the defrost timer or the defrost thermostat?
  • Joey Terry May 11, 2010
    Is there major ice build up in the freezer?If there is, does the fan inside run?
  • 30 Answers
Yes it could bea bad defrost timer, or the thermostat, even possibly the defrost element. The element and thermostat are easily checked by testing continuity across each of the terminals.If both the element and the defrost limit thermstat check good then the defrost timer more that likely needs replaced. if the heator or limit thermostat are bad i recomend replacing both of them at the same time while you have the cover off. Be sure to unplug the unit before taking the panel off and testing.
Posted on Mar 10, 2009
  • 400 Answers
If this is a standard refrigerator it could indicate that the unit is short of refrigerant.
Posted on Mar 09, 2009
  • 878 Answers
SOURCE: fridge not staying cold
Solo, firt make sure you do not have a build up of frost on the freezer inside panel. This would indicate a defrost problem. Your post states that the cooling problem is intermitant which leads me to believe that the automatic damper is at fault. It could have a build up of ice on it which is causing it to bind, or it could just be going bad. Your model does have the manual defrost timer which could be sticking at times, that is why I suggest checking the back freezer panel for frost buildup. back.
Posted on Dec 01, 2006
  • 125 Answers
SOURCE: Admiral Side by Side Fridge is warm at top, cold at bottom
Posted on Feb 07, 2008
  • 531 Answers
SOURCE: fridge warm freezer cold
you may have a defrost problem check to see if you have frost up in the freezer
Posted on Apr 13, 2009
  • 97 Answers
SOURCE: have a diplomat fridge/freezer - the freezer is
check the air damper from the freezer to the fridge. most likely blocked with ice.
Posted on Jun 08, 2009
Sea Breeze
  • 4655 Answers
SOURCE: freezer cold, not fridge
8 to 10 hours depending on how much warm items you placed inside to cool down. Make sure your fresh food section settings are set for medium. I'm not sure from what country you are from but a standard setting for both freezer and refrigerator should be set both mid way. For example (not that you need help here) 1 being the warm being the warmest and 10 being the coldest. Now some companies go like 1 being the coldest and 10 being the warmest. But 5 should be set up for first time start ups no matter where you are from. Thanks, Sea Breeze
Posted on Aug 05, 2009
Top section of my side by side kitchen aid frodge stop cooling bottom is still cooling and freezer still working
send the model number?if the freezer is cold but in fridge the top is warm and the bottom is cold it sounds like you have a bad evaporator fan motor,all it does is cold starts in the freezer at the evaporator coil,and the evap fan blows the cold air into the fridge section,warm air rises so if the fan isn't working the cold air will stay down low and the warm air will stay up on top,open the freezer door,if you don't hear the fan blowing in the freezer i would have to say the evap fan motor is bad,if the fan is working one of the doors could have been left open and the air ducts froze up or you could have a damper in your model,it's just a door that opens and closes to let the air blow in but send the model number so whoever helps you can look up your fridge,usually the model number for a sxs is in the fridge section open the fridge door look up on the right hand wall up near the ceiling or in the middle of ceiling and there should be a tag with model and serial numbers just send the model number,
Jan 07, 2018 | Refrigerators
Fridge started working again after I cleaned the grill, then freezer stoppped, unplugged and waited now freezer is good but fridge won't stay cold. The temp says 56. Ugh! Model # is PLHS67EGSB4.
My Freezer is Cold But My Fridge is Not! - YouTube
? 1:51
Nov 5, 2013 - Uploaded by Appliance Princess What to do if your refrigerator is warm, but your freezer is stillcold. ... Cleaning them is a good idea, even if it isn't the cause, because it will improve the fridge's efficiency. ... How does thefreezer fan's failure cause a fridge not to stay cold? .... How To Fix Your Fridgidaire Refrigerator (if the compressor won't ..
Sep 23, 2015 | Refrigerators
Fridge not staying cold and build up of ice on back piping
One of you fans is not running and causing the compressor to eventually making your compressor overheat and eventually shut off
Apr 14, 2013 | Refrigerators
Msd3756aew fridge won't stay warm, freezer cold but not keeping frozen. Cioils not frozen, fan working
the ptc overload/relay on the compressor is bad and not starting the compressor,remove back cover unplug the ptc off the compressor and replace it with a new exact replacement part
Feb 01, 2013 | Refrigerators
I have a dometic rm2820 up right fridge on bottom freezer on top. the freezer gets really cold but the fridge part stays warm.
Did you by chance recieve a recall from the manufacturer .? we got one about two years ago we had the same problem, they fixed it because there was danger of fire, i would contact them
Jan 19, 2012 | Dometic Refrigerators
Freezer works fridg dosent stay cold
When plugging it back in, check to see if you can feel air circulation (from vents in the top-rear) on the refrigeration side.
Check again after the fridge starts to warm.
There is a fan which is supposed to distribute the cooled air from the freezer to the fridge; this may be failing after the fan has warmed from operation. The bearings in these is primitive and can get sticky impeding the fan's rotation. Replacement of that fan is not covered by the (longer) compressor warranty.
Jul 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer very cold fridge warm.
does the fan come on if not then the fan delay is bad
May 25, 2009 | Refrigerators
Fridge not cooling down stays at 68 degrees
you may be low on freon..thats one thing about fridges if you are low one side will still stay cold while the other side gets warm
Jan 12, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Warm Fridge Section
sounds like the evaporator fan in the freezer is not moving the air. also there is an air damper door at the top center of the fridge that controls air flow from the freezer to the fridge. check those two components and you will find your problem.
Sep 26, 2007 | Maytag MFD2560HES Bottom Freezer French...
Freezer works but refridgerator warm
you could find ice behind the back panel - worth a check. however the problem is probably ice in the return vent from fridge to freezer and the only way to cure is to switch off and leave for a day with doors open. if im right and you try this, if it re-occurs you may have a problem with the defrost system
Apr 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
290 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
