Question about Mountain Bicycle Chain Press Fit 42 In Bike Part 40
I have a pacific usa mountain bike and the chain broke an i bought a chain and I cant figer out how to put it back together
    Problem Solver:
  • 11 Answers
Go buy a link connecter. Youv'e got to make sure you have the right link removed. Save the inside link on both ends of your chain. you'll have to pound the pins out on each end of the chain. it's kind of hard to do, i don't know what kind of tools you have. You could take it to a bike shop i don't think they would charge you much.
Posted on May 03, 2009
  • 62 Answers
Well usually all chains have a link that comes off. if you get that to come apart, then you put the chain on the teeth were the teeth come through between the links. then you link back together the two chain links. it might be a little hard though
Posted on Apr 01, 2009
How do I adjust the chain of a 29" pacific mens mountain bike?
Loose the 2 bolts from the rear tire and pull the tire back until the chain tensioned then adjust the bolt again.
Jan 05, 2015 | Mountain Cycling
Brand new bike gears won't engage. The gear shift is on 6 and the chain is on the smallest cranks.
the derailleur cable is too loose. Shift the shifter into the smallest cog, make sure the chain is on the smallest cog. The derailleur cable will most likely be very slack now. At the rear derailleur, there will be a nut or a allen bolt pinching the cable to the derailleur. loosen this, pull the cable finger tight, tighten the nut or bolt again and then try shifting again. You can dial it in using the barrel adjuster on the derailleur or the shifter.
Oct 15, 2011 | Pacific International Pacific Evolution...
I want to replace my Pacific Bicycle derailleur parts.The parts that are on there are td-one and the bicycle is a mountain bike. the model number is R4446WMUT.Later on I would like to replace possibly the...
Are you in love with TD-One parts or would an upgrade to almost anything Shimano be a possibility? Look on eBay. A Pacific Bicycle or any bike sold by a department store isn't really what one would consider an upgrade-worthy project. A new bike better might be cheaper considering labor costs. Replacement of parts for failure might be worthwhile.
Sep 16, 2011 | Mountain Td-one Bicycle Front Derailleur...
The chain is broken off the bike We bought a new one but need a diagram of how to weave the chain through Thanks
The chain goes from the top of the front sprocket to the top of the rear sprockets, between the rear sprocket and the top derailleur wheel and then between the upper and lower derailleur wheels. It then goes forward toward the front sprocket. The text sketch below shows the rear sprocket, chain and derailleur.I hope this helps.
(O
o)
(o
Aug 15, 2011 | Pacific International Pacific Evolution...
Height of front derailuer and set up
It sounds like something amiss in the shifter. Start here and look around. It may get you to a solution.
http://parktool.com/repair/readhowto.asp?id=75
May 08, 2010 | Shimano Deore LX Mountain Bike Front...
Mongoose tactic mountain bike / loose crank on chain side. How to tighten.Chain ring moves with it. Makes clicking noise.
The crank has to be removed to tighten the nut that holds the gear on. I assume that is your problem is with the chain gear on the sproket that is loose
Apr 21, 2010 | Pacific International Mongoose 26 in. Mens...
Mountain Bicycle Chain Press Fit 42 In  Bike Part 40 Logo
155 people viewed this question
Top Mountain Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Mountain Cycling Expert? Answer questions, earn points and help others
