Question about Altec Lansing 621 Computer Speakers
Altec 621 Speaker System - volume contol no up/down adjustment
I have 621 PC system (3 speakers - bought it on in 02), on/off works on contoller, but cannot adjust up or down from controller (no batteries). desktop volume control works but not the system contoller at all for up/down......any suggestions on how to determine if the problem is in the contoller itself or some other sustem failure? Thanks.
5 Suggested Answers
djnick989
  • 1067 Answers
SOURCE: no sound
see if u can get master speaker wiith cables on it that died on ebay best bet what kinda are these
Posted on Jan 09, 2008
  • 198 Answers
SOURCE: Controller for Altec Lansing XA3051
If you plug it in to your computer, a freeware program may still be able to recognize it and give you exact model numbers and IDs--worth a shot, and you'll love the program anyway--Belarc Advisor. It lists all hardware and software, model numbers, keys, etc. Hope it helps.
Posted on Apr 18, 2008
headman333
  • 82 Answers
SOURCE: Altec Lansing Altec AVS 500
If you are using windows media player check if your player is configured to have an echo. If it is configured remove it. If it is not configured to have an echo and if you are using any soundcard have that sound card check by an expert or by your vendor and let them check it out if it is still under warranty.
Posted on Jun 25, 2008
  • 3600 Answers
SOURCE: My altec lansing ATP3 right satellite speaker cannot operate...
Speaker is bad or the cable may have come loose. Has it been knocked around? If so it may have pulled the cable loose inside the speaker, try playing a song and wiggle the wire and push the wire in gently to see if it starts to play if it does you have found your problem. If not then the speaker is bad and I don't remember if you can pull it apart and buy a new speaker to install in it. Thanks for using Fix-ya and if this helps please rate this free question.
Avid101
Posted on Aug 20, 2009
I own a A/Lansing FX 6021, My right satelite speaker is not working( no sound, no buzzing at cable plug-in), are there any solution for this problem??
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Oct 05, 2011 | Altec Lansing FX6021 Computer Speakers
I am running windows xp on a desktop computer with a INT D945GNTLR motherboard which I believe has a built in audio for 5.1. The speakers are Altec Lansing VS3151. They worked fine for years but now I...
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Sep 10, 2011 | Altec Lansing VS3151 Computer Speakers
I had my harddrive reformatted on my desk top pc and now my altec lansing avs200 speakers wont work on my computer
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume adjustment you will need to right click on the volume icon depending on your operating system select adjust volume
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps you
Jul 25, 2011 | Altec Lansing Multimedia Computer Speakers
Cannot ajust volume
adjust the volume through computer audio properties
Feb 22, 2009 | Altec Lansing 621 Computer Speakers
ALTEC LANSING MULTIMEDIA COMPUTER SPEAKER SYSTEM:
the controller chip inside your altec is possibly defective. i have the acs 45.1 and the unit wont turn on.. the culprit is the main power/volume chip.
Apr 30, 2008 | Audio Players & Recorders
AVS500 altec lansing computer speaker system powered subwoofer
Its due to your speaker power supply failure or switch! get them checked your speakers will be ready!
Nov 02, 2007 | Altec Lansing 621 Computer Speakers
Can't increase & decrease the volume
Double check your connections. Still not working fine. Remove the input jack connector and try to touch or hold the tip of the connector, also adjust the volume of the speaker, you should heard loudly the 60 hertz sound of your body signal. Otherwise you have a defective amplifier in the speaker system.
Dec 05, 2006 | Dell PART NUMBER KIT SPEAKER MM ACS45...
Altec Lansing 621 Computer Speakers Logo
163 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
