Question about Brother LS-2125 Mechanical Sewing Machine
My brother sewing machine jams threads under the needle and will not go, all the thread has to be pulled out gently as not to break the machine. It will not sew at all now.
Hi there, why is it that i can't sew at all..both thread are not working instead eating each other thread under....but i have a good brother ls 2125. ty...
Posted on Mar 19, 2009
My top thread keeps catching and bunching up under the needle plate.
  • Raise presser foot when upper threading.
  • Thread normally through all guides
  • Lower presser foot
  • Thread needle, leaving a 6" thread tail
  • Raise foot and gently pull thread (no tension)
  • Lower foot & gently pull thread (you'll feel resistance)
  • Delint upper tension with Compressed Dry Canned Lint Remover ie: Computer Quality. Be sure no thread is in machine and foot is up so tension is released
Nancy Notions Trusted by sewing enthusiasts for more than 3 decades
Jul 13, 2015 | Baby Lock Ellure
Brother exedra E-40 why it alway get tangle and brake the threat?
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Aug 05, 2014 | Brother Industries, Ltd Brother Sewing...
The tread is breaking while sewing with brother ls 2125
The needle thread breaks
Nov 12, 2012 | Brother LS-2125 Mechanical Sewing Machine
Brother 700e
Try these suggestions
1. Change needle
2. Rethread the machine--top --make sure to use every thread guide
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Aug 16, 2012 | Brother SE-270D Computerized Sewing...
Thread jamming
try changing the needle-flat side goes to the back of the machine
rethread the machine top & bobbin--make sure to use every top thread guide
clean under the needle plater & in the bobbin area for lint or loose threads
make sure the thread doesn't come off the thread take up lever
Apr 03, 2012 | Brother XL-2600I
Brother 920d breaks the thread shortly after a few stiches
Mar 03, 2012 | Brother Sewing Machines
I have been trying to make a buttonhole but the top thread keeps breaking and the threads are all snarled up underneath the material. what am i doing wrong? i have a brother ls2125 machine maria
Firstly have you interfaced the material that you are buttonholing on? You will never get a good buttonhole otherwise. Also start each new project with a new needle matching the size to the weight of fabric. Good guide available here http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machine-Needles/
Top thread breaking is usually because the tension is too tight or the thread is catching somewhere in the thread path from the spool to the needle. Also check that the needle doesn't have a burr on it somewhere, or is blunt.
Thread snarls underneath the fabric is usually caused by top thread tension issues. You will need to rethread top and bottom and CHECK that the thread is in tension correctly. So lower the pressure foot and pull the top thread just before the needle - does it feel hard to pull? If not, then the thread is not in tension. Rethread top again, checking the tension dial is set to 5 and the thread is correctly pulled between the tension discs. And always hold the two thread tails at the back of the sewing area as you start each new seam to avoid these being pulled down into the bobbin area and getting jammed up.
So, rethread, test sew and get the top tension sorted, a nice straight stitch happening, then try the buttonholing sequence again.
Apr 26, 2011 | Brother LS-2125 Mechanical Sewing Machine
Top thread on my Brother Limited Edition 350 Sewing machine keeps breaking. Having used the automatic cutter, the thread pulls up and out of the needle when I want to start sewing again. Also the machine...
try a top thread tension of 3 or 4
change the needle
always keep a thread tail of 3-5 inches on top & bobbin thread & keep the thread pulled back behind needle before starting to sew
always keep the bobbin area clean of lint & loose thread
& check under the needle plate for lint also
you might consider having the machine serviced, since you said it sounds like a tractor
some needle & thread are not compatable-try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 04, 2010 | Brother Sewing Machines
I can start working withmy baby lock, the needle brokes verytime i runthe machine , and i can not sew
If this machine has a needle position adjustment and it is on the center position -
and you are sewing a zig-zag stitch and using a presser foot with a narrow opening this could break the needle
and the needle plate is a single hole, this will break the needle.
and you are sewing a straight stitch with a new needle and it breaks, the machine needs to go in for servicing.
Feb 13, 2010 | Baby Lock Sewing Machines
Brother LS-2125 Mechanical Sewing Machine Logo
259 people viewed this question
Top Brother Sewing Machines Experts
Bargain Box
Bargain Box
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
