Question about LG Studioworks 775N 17" CRT Monitor
Hi need some help with 17" philips crt comes on runs until windows start then switch of all power wont come back on for 15min restart pc then screen display out of frequency range, set frequency range down to lowest still does the same change graphics card still the same, screen shape is oval as well. can any one help
    Problem Solver:
  • 5 Answers
You can try starting your computer in safe mode and restore your computer to another safe point. usually this problem is caused by an update or a new driver installation/update...
Posted on Aug 11, 2009
How do I open back of Monitr?
There should be several philips screws on the back panel. (WARNING: Because you are opening a CRT, there is a extremely high voltage coil on the back of the CRT in the center. DO NOT TOUCH THIS WITH ANYTHING as it is DANGEROUS if you do.) With the exception of possibly a power supply fuze which you should be able to see next to the power transformer (where the power cord comes into the CRT case), there ARE NO USER-SERVICEABLE PARTS INSIDE. I recommend you buy a cheap LCD screen to replace it and dispose of the CRT through a recycling program. I hope this helps you.
Oct 05, 2012 | LG Flatron F700P 17" CRT Monitor
HP Pavilion dv6448se Notebook PC Won't Boot.
it restarts on booting screen or else at start up screen itself?
Jun 08, 2012 | HP Computers & Internet
Ok, i have a Hp pavilion desktop and it wont start up. Before i was just on the internet not slow or anything. But my itunes would not come on, which is normal. So i restarted it, it loads and what not....
HP has ties with Windows which is owned by Microsoft. The black screen you see is called a DOS command prompt. Microsoft Windows has major security flaws, and unless you want to buy software such as firewall, antivirus, spamware, malware, etc., then I suggest you take the easy route and check out Ubuntu. It does not get any viruses or any of that **** because the kernel sits outside the application layer unlike Windows. read about, try it, and be free from that ****. That's my honest, best answer, coming from a windows user since back in the day of Windows 95, and DOS.... just get Ubuntu, it's simple and pure freedom.www.ubuntu,com/
Jan 15, 2010 | HP Pavilion a1620n (882780664494) PC...
Randomly lost display on my pc.. and its not a faulty card.
Try to set your PCI-E card as a first one in BIOS. There also should be an option to turn off onboard video.
Mar 07, 2009 | Gateway GT4022 PC Desktop
Philips monitor
Sounds like you have a bad inverter. You will need to open up the monitor to get to the screen to access the inverter board and replace it. If you are handy you can do the job yourself but if not then you will need to take it in to a computer repair shop to have it serviced. Depending on how old this monitor is, the cost of the repair maybe prohibitive.
Mar 12, 2017 | Philips 190CW8FB LCD Monitor
Phillips Magnavox 32MT3305/17
i have a magnavox 32mt3305/17, it has no power the hv transistor is missing,can someone tell me whats that part number and where to find it.thank you..
Sep 02, 2008 | Philips Magnavox 27MS343S 27" TV
Device manager wont detect my gogear HDD1630/17 even though i recently updated the software and driver, also my device is frozen on "Please connect player to pc". I can't even get it back to the menu...
I was experiencing this similar problem, and from my research so were alot of other people, what finally worked for me was this:
  • Update all the software on your computer via Phillips site
  • Open the Philips Device Manager
  • With the device connected and the 'connected to pc' screen showing on the GoGear, do a 'soft reset' by holding the Power Off + Volume Up buttons for a few seconds
  • As soon as the device restarts itself, hold the Volume Down button, the computer should now recognize the GoGear
  • Follow the onscreen directions to Repair the device
  • Thank the intarwebs.
May 21, 2008 | Philips GoGear HDD6330 MP3 Player
SCREEN MESSAGE - MODE NOT SUPPORTED
You have set a resolution that is too high or incompatible with your monitor. I assume you are using Windows. Turn the computer on and immediately keep pressing F8 on the keyboard until the 'Windows Advanced Options Menu' appears. Use the Up and Down keys to select 'Enable VGA Mode' Press enter and your screen will work again when windows starts. Now go to the display properties and click 'Advanced' then click the 'Monitor' tab and tick 'Hide modes that this monitor cannot display' OK everthing and now you should be able to adjust the resolution without getting a blank screen again! Good luck and come back to comment soon. Regards
Sep 26, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
My philips monitor is not working so how can i get technical support?
1.How is this powered? From a separate power supply or direct into the monitor. 2.Does the power light come on when switched on. Can you see any movement in shadowy form on the screen? 3. Check the data cable both ends for bent pins. If the moniot is powering up the connect it to another computer to confirm Monitor or Computer? Do all this and answer the questions clearly then come back
Jun 01, 2007 | Philips 107E66 17" CRT Monitor
MONITOR REPAIR HELP
The mains switch is a weak link on these, check this first. Also 1 of 2 33K 2W startup resistors in PSU goes o/c, check with DVM or if you have very high volts on main primary res cap this usually indicates a 33K has gone - change both. I've also had a small TO92 transistor hanging off the UC3842 failing causing no startup. A s/c HOT normally causes a blinking LED. note that AC cap IS charged, DISCHARGE BEFORE WORKING ON IT! Did you check for shorts in the secondary side of the p/s, horiz output? If there are none , look for the switching regulator. Check the support components. I've seen these with open solder connections on the coils in the PS due to that abominable glue they use...you'll see signs of burning/arcing on the inside of the cabinet, too. Good luck
Apr 09, 2006 | AcerView 78ie 17" CRT Monitor
LG Studioworks 775N 17" CRT Monitor Logo
75 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
