Question about LG LRSC-26922 Side by Side Refrigerator
My funnel broke too! What's LG's number?
What's the number for LG? My funnel also broke off and it is a pain cleaning up ice bits etc that go all over the floor.
  • kandice d Apr 01, 2009
    funnel snapped off, now ice goes everywhere
  • 4 Answers
If it is after warrenty, LG does not distribute those parts. Call MCM electronics, they are in ohio. their number is 800.824.9491
Posted on Apr 15, 2010
  • 30 Answers
Contact Us For Audio/Video/TV, Computer Products, Home Appliances U.S.A. Corporate Headquarters
1000 Sylvan Avenue
Englewood Cliffs, NJ 07632
Toll Free: (800) 243-0000
http://us.lgservice.com/index_b2c.jsp
Posted on Mar 08, 2009
What does the tubing from the ice maker water valve go into when you feed into the funnel of the ice maker?
There is probably Ice forming in the end of the water line. I fought this battle for a long time. Then I found the answer. The Freezer temperature is probably too cold. I have read that the temperature must be set to between 0 and 4 degrees. WRONG. It should be colder than 10 degrees and I have found best results with the freezer set to 6 or 8 degrees on the control panel. To test this. Take a blow dryer and heat up the area where the water comes into the icemaker. Use caution it is possible to melt some of the plastic in that area. Then, set the freezer temp to 6 or 8 degrees. It will probably work fine.
Jan 08, 2017 | LG Refrigerators
Where can I buy a 2005 LG refrigerator ice maker funnel?
Try your model number on Searpartdirect.com. It will bring up several schematic for you to look at. Find the part and you can order it directly from them.
Sep 25, 2014 | Refrigerators
Ice in the bottom of the freezer
Ok here is a generic response without a model number.
One of 2 things have happened. Either the inlet water valve to the icemaker has failed as noted by ice blocks in the ice bin or
Your evaporator drain is clogged.
  • Unplug the unit remove the freezer contents and do a manual defrost by directing an external fan at the freezer compartment for just over 2 hours. (Makes a water mess so be prepaired)
  • Remove the rear fiber-board compressor and condensor coil cover and locate the compartment drain tube in the drip pan. Make sure the end of the tube is NOT blocked. Clean as necessary.
  • After the 2 hour period... use vacuum forced air OUT pressure on the end of the drain hose in the drip pan. Have a 2nd person listen for airflow in the freezer compartment. This will float out any debris from the compartment drain funnel.
  • Clean the condensor coils and fan while the unit is unplugged but do NOT use anything sharp.
If you can not get air-flow up through the compartment drain funnel underneath the evaporator coils you will have to remove the access panel and remove the debris from the drain funnel.
Return the unit to normal service after cleaning. Watch for more ice build up after a week. No ice blocks after a week... no worries. Ice under the ice-maker... replace the inlet water valve due to it bypassing water when in the OFF mode.
If you need model specific information.... I need your exact make and model number in any response.
Thanks for choosing FixYa,
Kelly
Feb 19, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
How do you replace the dispenser funnel on an LG Refridgerator model LRSC-26923
funnel itself squeeze in on sides to release tabs. so many tabs broke a redesign was made 5-30-2005 , have to replace frame bracket and funnell. models after tant had new design. part number from exploded view: 3016JA2002C funnel 278d location number exp. view
3210JA0006S frame 278b location '"" '' ""
Sep 10, 2009 | LG LRSC-26922 Side by Side Refrigerator
LG refrigerator - Need help replacing a part in the door.
How to install part ac110-115v for lg refrigerator
Jul 10, 2009 | LG Refrigerators
LG LRSC26925TT ice dispensing funnel broken
Yes. But LG came out with a new frame for the funnel. So you have to order the funnel and the frame which is installed through your front control panel. Good Luck I just did it.
Jul 08, 2009 | LG Refrigerators
LG Refrigerator - I need to remove the ice disp.
The dispenser cover snaps off. Look at the bottom corners of the dispenser faceplate and you may see small slots to put a small flat bladed screwdriver inside to help pry the faceplate off. This faceplate snaps on very tightly so it may seem like there are screws holding it in place, but it only snaps in.
Once you have the faceplate off the rest will be easy as you can see what you are doing and what you have to remove.
Note, if you are replacing the funnel you need to know that this part has been updated as of OCT 2005 (stronger clips to hold it in place) and it will not snap into the older funnel frame (the part it attaches to).
If the serial number for your model starts with 510KR or lower, then you will also need the updated funnel frame part number 3210JA0006S.
Hope this helps, please rate my solution.
Jan 12, 2009 | LG LRSC-26922 Side by Side Refrigerator
Lg refrigerator water dispenser would not shut off
so two things I have learned. First if the tabs on the funnel break dont buy a new one just crazy glue back in place. Also if you take the gasket out put vaseline on the nubbins and they will slide back in place without having to take the panel apart. Fix time 7 minutes. Booyah!!!
Apr 21, 2008 | LG LRSC-26922 Side by Side Refrigerator
Non stop ice
the clear funnel is either broken or just popped out of place.
if you can get a flashlight and look at the funnel you will see two clips on both sides of the funnel that secures it to the lever just push firmly and it should go back into place. if you dont have any luck you can order the funnel and replace it fairly easily.
one thing that may help you repair this unit is remmoving the front cover of the dispenser.
on the bottom of the cover is 2 slots for a flat tip screw driver. just insert the driver and leverage outward and the snaps will release. (it takes quite a bit of force). be sure to unplug the refrig to prevent getting shocked. when you reinstall the cover you will have to hit the lower portion firmly with the palm or side of your hand to lock the cover back in place.
Dec 17, 2007 | Whirlpool GS6NBEXR Side by Side...
Lg lfx25960 Ice Dispenser
I had the exact same problem on my LG LRSC26940 and was able to fix it fairly easily. First remove the Ice Funnel by pulling down on it. Then remove the entire dispenser panel by getting your fingernails underneath and pulling out. Disconnect the electrical connecter to the front panel PCB. Remove the 4 screws attaching the bracket that the Ice Funnel connects to. This exposes the solenoid that opens the Ice Door flapper. In my case, the electrical connections to this solenoid were bad. I simply scraped the spade terminals on the solenoid off with a screwdriver and crimped the connectors with a pliers. I put it all back together and it is working fine now.
Dec 12, 2007 | LG LFX25960ST Stainless Steel French Door...
LG LRSC-26922 Side by Side Refrigerator Logo
500 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
