Question about GE J Series 18.2 cu. ft. Top Freezer No-Frost Refrigerator TBX18AABWW
Finding the condensation tray
I was told the condensation tray leaks. i'm not sure where it is i looked underneath and pulled the front tray off but nothing looks removable there. Im hoping this will be an easy fix please tell where it is and how to remove it. thankyou.
  • 30 Answers
Somtimes they are mounted to the top of the compressor,you will have to pull the fridge out and take the panel off of the back at the bottom.
Posted on Mar 08, 2009
Condensation water build up inside refrigerator
The tray underneath your fridge is probably clogged, and overflowing. There is an evap tray underneath, and if it does not get adequate airflow, it will overflow, and leak out.
Clean the bottom front vents, and underneath the fridge to ensure adequate airflow.
Mar 31, 2014 | Sub-Zero Refrigerators
It's leaking water from underneath the unit
Hi there, I know that most units have a drip tray at the back or under the unit itself. well the older ones anyway, not sure with really new ones, but they shoukd. these trays hod water condensation and any drainage from the fridge itself. These trays sometimes have a coil in them which heats and help to evaporate the waterso that it does not overfill and spill out. these trays can become overfilled, the heating elemet can stopworking or
Jun 01, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I came home to find water underneath my frigde.is that a clogged drain?
Under your fridge you have a pan that will catch condensation created. This pan usually has a sponge or a device to obsorb the condensation as well as this pan must stay cleaned. Second item to look at is if you have an icemaker you could possibly have a leaking line. Or to go back to your tray, be sure it is in the possition it is suppose to be in.
Aug 27, 2011 | Kenmore Top Freezer Refrigerator
Condensation is forming on the glass door and dripping onto floor boards. How do we stop the condensation. It does say to empty drain tray but we cannot find it and instruction manual does not tell you...
The drain tray is under the fridge often times set back a little bit. Remove the kick plate by pulling from one side then the other side, strait forward till it pops off. The kick plate is a plate as close to the floor as you can get on the front side of the fridge going the entire width of the bottom of the fridge. Now get eye level with the underneath of the fridge. Center your view on the underneath of the fridge. The drain tray is right there. Pull it out, carefully as it is probably full of water, and dump the water out of it. Replace the drain tray and then replace the kick plate. Check the drain pan once a week or so and you should have no more water leaking on your floor. Hope this helps.
Mar 22, 2011 | Refrigerators
My hotpoint future fza34 is leaking from underneath
you need to get to the back of fridge and ul notice a tray full of water ontop of the compressor. remove tray and empty water out. when replacing v important to make sure it is sitting level on compressor again.
there is also an underlaying prob here, maybe alot of condensation on shelves also??
ensure doors are closing properly and saels are in good shape, also avoid putting warm food in fridge and make sure liquids are covered. this should stop tray filling with water and leaking
Sep 23, 2010 | Hotpoint Freezers
I have an Amana side by side refrigerator model SXD225SW and the other day water began leaking from underneath the refrigerator. As the couple of days have worn on, it seems as though the amount of water...
Move the refrigerator out from the wall and look for the location of the leak.
Step 2
Check the side panels and the seals around the door for beads of "sweat." This could indicate a condensation problem.
Step 3
Check the floor. A puddle there could indicate a missing or cracked drip pan, or a leak in the water line that feeds your ice maker.
Step 4
Check for water seeping from the front of the freezer or the refrigerator. This could indicate your defrost drain is plugged or your ice maker is leaking.
Fixing a condensation problem
Step 1
Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely.
Step 2
Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets (see How to Fix a Refrigerator That Cools Poorly).
Step 3
If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls
Hope this helpout......
Aug 15, 2010 | Amana SXD524VW Side by Side Refrigerator
Water is leaking onto the floor from underneath the refrigerator.
There is a condensor tray located underneath. It catches water and then the water evporates. Sometimes the tube gets plugged and causes a mess. Check the tube and the condensation tray. You can access the tray by just taking off the grille under the door on the front of the refrigerator.
Nov 17, 2009 | Whirlpool EL7ATRRKS Refrigerator
I think my Whirlpool French door (freezer on bottom) is leaking underneath. I have checked the water lines on the outside and looked underneath and nothing. When I moved the fridge there was a film of...
check to make sure that the condensation pan is in its correct position,, somtimes when the unit is moved up steps it causes the pan to sit in there cocked or unlevel and will drain out excessively. or it may be a crack on the fill valve solinod where the water line connects to the fridge.. there will be a blue plasitc cover right where the water line connects to the frig and somtimes they crack and will only leak when the ice maker calls for water... pull out the frig and empty the ice tray and when you here it start to fill up the icemaker check around that solinoed be sure to use a bright flash light because sometimes the leak will be a little stream of water that is really hard to see sometimes you can only feel it with your fingers...I hope this helps......
Nov 11, 2009 | Whirlpool GX5FHDXT French Door...
Kenmore model 88892 sxs refrigerator started to leak water on the bottom underneath of refrigerator. I cleaned all lint and debri underneath, but still water coming out on floor. Dont their suppose to be a...
There is a tray that is in the bottom, remove the cover thats located just under the doors in front. You will see it most of time black in color and it will be easy to pull out be careful for it will be full. Its from condensation most the time in the summer this happens really no problem. if thats not it check the ice maker water supply line that could be it also.
Aug 09, 2009 | Refrigerators
Refrigerators Logo
121 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
