Question about Acer Aspire 5610-4648 Notebook
Wireless connection I have not had any problems connecting my laptop until recently. I pick up a wireless connection on my desktop, but at the same time my laptop won't, it used to be there as soon as i turned on this computer. Now 5, 10, maybe thirty minutes later it will appear and connect. This laptop is two months old, so it's not an old junk computer or anything, what would be the reason this would be happening?
  • 2 more comments
  • benny13 Mar 08, 2009
    I still have an issue if the desktop is off. I sent this out to be serviced through HP for an monitor issue and since it has come back there has been this issue which I never had before. Could they have changed some setting on the wireless card?
  • Michael Patak May 11, 2010
    Have you tried removing the wireless connection and setting up a new one?
  • Nicholas Lussier May 11, 2010
    Hi, if your desktop it turned off does the laptop still have an issue picking up wireless? How many wireless signals can you see in your software?
  • Mark Van Skiver May 11, 2010
    Your connection come through a router?
  • 87 Answers
Try accessing it with a static IP address.
Posted on Mar 14, 2009
  • 741 Answers
Sometimes the wireless card will pick up any signal it finds, like your neighbors..go into control panel and network connections and take a look if there are other signals being picked up. If so there will be more than one connection showing. Click on your connection and that should set it to automatically always connect to yours and not someone else's...if the wirelss card was not functioning then you would not get any signal at all...finally try starting your laptop next to your router and see if that works better, there may be some interference in the house not allowing you to get a strong signal..good luck. Please rate this solution.
Posted on Mar 08, 2009
I just bought a dell laptop and the house hold has two desktops connected to ethernet cables to a dsl modem. the lap top we had connected wireless and now it wont connect unless we connect it to ethernet...
Turn on the wireless switch ON in the laptop if it has one. Check to make sure the wireless adapter appears in the Device Manager. Then check the wireless network connections on you computer - it should pick-up all surrounding wireless SSID's. Locate yours and enter the security keys for your modem when prompted. Make sure it is the correct number to get a connection. Also, check your modem settings from one of the desktop computers - there should be a web page for it by using your Internet browser, to verify that its' wireless transmitter is on.
Oct 27, 2010 | Computers & Internet
Laptop won't find wireless router until desktop pc is turned on.
Could be the problem in the definition of card or be proud of in the Router Settings
Jul 17, 2010 | HP Computers & Internet
Laptop not connectiong to wireless network
Connect the Laptop to the router with ethernet cable
Verify the wireless LAN
  • Open a browser and type http://gateway.2wire.net; the Home page opens.
  • Click the Home Network tab.
  • Verify the wireless status located on the right panel (Status at a Glance) is Disabled.
  • When the status is disabled, then enable the wireless LAN .
May 27, 2009 | 2wire 2700HG-B Router (2700HGB)
Do Desktops pick up internet connection like laptops do? Im planning on purchasing a desktop pc however im not sure if i can pick up internet like my current laptop does, U see i just moved in and dont...
Hi there.
You hit the nail right on the head!! desktops don't come wireless enabled so you will need a wireless card installed into it.
I recommend a wireless PCI card as a Dongle are not that good and can be easily broken.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | HP Computers & Internet
Laptop Cannot Find Home Wireless Network
Try logging into the router with your desktop hard-wired and find the 25-digit passcode and use that to log on to the wireless network with the laptop. If not, then check if connection is good by hard-wiring the router to the laptop. Let me know what happens or if you have solved the problem.
Mar 22, 2009 | HP Pavilion a1320n (882780261747) PC...
Acer 4730 laptop won't connect to the internet.
Your laptop should pick-up and connect to the wireless connection automatically. Go into Control Panel and click on Networking. You should see the networks that you are able to connect to. But you need to know the name that was given to your network in order to connect to the correct one. If there are two or three names then some of those are your neighbors wireless. If you do not see any Networks to connect to, then repost because that means your network card is not working.
Dec 28, 2008 | Acer Aspire 5610-4648 Notebook
No wireless signal
make sure that the wi-fi of your laptop is enabled.
Oct 23, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Router won't log into it's IP address online
It appears to me that you have everything plugged into the desktop PC. This is not the way that it should be done. Plug the cable modem into the wireless router via the Internet/WAN port. Plug your desktop PC into one of the ports numbered 1-4. Now connect to the router via the wireless connection for the router and you should be able to now connect to the internet with your laptop.
If it still does not work, power down everything in this order: Laptop, Desktop, Router, Cable Modem. Bring everthing up in the reverse order (Cable Modem, Router, Desktop, Laptop) waiting for each device to stablize before moving to the next.
Once you get everything working, turn on your wireless security (WPA not WEP) asap to keep your computers and surfing safe, and to keep intruders off your network.
Jul 20, 2008 | NetGear RangeMax WPN824 Router
Connectivity issue with our D-Link DWL-122 wireless adapter
It could be one of three problems - either the network adapter in your desktop PC has gone bad, the router or ports of the D-Link have gone bad or the cable you are using to connect the two is damaged. The wireless could continue to work if any of the three are problems.
Check that you have link lights on the back of the PC - you should see two where the network cable plugs in and one should flash when sending & receiving data. Also check that the corresponding light on the D-Link for the port you are plugged into is lit. Try different jacks on the D-Link as well.
To tell if the problem is the PC or the D-Link you need to connect another computer to the D-Link. Can you plug in the laptop (disconnect from your wireless first) and physically plug that in - if you have network connections in & out the D-Link is fine and your network card could be the problem. If no connection to the internet is available when plugged in to the D-Link your router is the problem or a setting in the network properties of the PC could be to blame (the latter unlikely if you recently reformatted).
You could continue to use the D-Link for wireless and pick up a 5-Port Switch or something similar to share the network connection - one going to your desktop PC, another line to the D-Link. This is a cheaper solution than getting a new wireless router.
I hope this helps....
Feb 09, 2008 | D-Link DWL-122 Wireless 2.4GHz (802.11b)...
Acer Aspire 5610-4648 Notebook Logo
108 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
