Question about Hamilton Beach Water Cooler with Storage Cabinet
Hamilton beach tabletop water dispenser for hot and cold.. it stop dispensing cold water..both sides are hot.. what can i do to fix it and how?
  • 400 Answers
The water selector valve is fautly and needs to either be stripped and cleaned or replaced.
Posted on Mar 09, 2009
Hamilton Beach 87330 hot water problem.
The two round "devices" on the tank are the operational thermostat, and the "safety" overtemp thermostat. It is usually the "operational" thermostat that fails, since it has to cycle a lot and arc internally. It is usually about 120-140 degrees F., and the safety thermostat significantly higher.
Feb 23, 2010 | Hamilton Beach Water Cooler with Storage...
I have a HB Water cooler Model 2312C, Type WD01,
Problem: Water is not hot
Possible Causes: Dispenser is unplugged
Solution: Push plug completely into outlet
Possible Causes: Heating switch not on
Solution: Check to be sure heating switch is turned to ON
Possible Causes: The fuse is blown/circuit
Solution: 1. Replace house fuse or reset breaker is tripped circuit breaker.
2. If too many items are plugged into a single circuit, move some items to a different circuit
Possible Causes: Temperature limiter tripped
Solution: 1. Set the hot and cold power switches to OFF
position.
2. Wait five minutes, then set switches to ON position.
3. Wait 30 minutes for water to heat or cool
Link for owners manual: http://useandcares.hamiltonbeach.com/files/840178800.pdf.
Feb 18, 2010 | Hamilton Beach Water Cooler with Storage...
Why is hot dispensing cold water
try to check the heat filament or thermostat heater, maybe it is busted that why it cannot dispense hot water, there water source is came only to one tab and it interconnected inside
Nov 04, 2009 | Hamilton Beach Water Cooler with Storage...
Tanks leaks, where can i find a replacement tank??? Hamilton beach model 47224
I called up Hamilton Beach directly and ordered a new one. Fits fine and works like new:
USA
1-800-851-8900 (all products except microwaves and water dispensers)
1-800-488-5080 (microwaves and water dispensers only)
Canada
1-800-267-2826 (all products except microwaves and water dispensers)
Mexico
01 800 71 16 100 (all products)
Send a fax:
1-800-230-4708 (toll-free within the United States)
Write a letter:
Hamilton Beach Brands, Inc.
360 Page Road
Washington, NC 27889
Have to call weekdays normal business hours....no weekends
May 10, 2009 | Hamilton Beach BrewStation 47224 Coffee...
No hot or cold water will come out of the dispenser
you may need to clean the dispenser unit thoroughly.Try vinegar and a long q-tip.
Feb 22, 2009 | Hamilton Beach Water Cooler with Storage...
Broken gear
Hamilton Beach parts are not readily available form parts suppliers. Here is contact information for Hamilton Beach.
USA
Canada
Mexico
Send a fax:
Write a letter:
360 Page Road
Email: (Please allow 3 business days for a response)
For all products except microwaves and water dispensers: Click here to send email..
Jan 17, 2009 | Food Processors
Hamilton Beach 87330 water cooler
Hello! About 2 weeks ago, the same problem began on my Hamilton Beach water dispenser.
Last week, I called the HB service support, and they told me to do the following reset procedure:
1. Dispense 3 cups from the HOT water side, and also, 3 cups from the COLD water side.
2. Turn BOTH back switches OFF (the ones on the back of the water dispenser).
3. Unplug the dispenser, and LEAVE it unplugged for 24 hours.
4. After 24 hours, turn the back switches ON and plug it in.
5. Leave it on for 4 hours WITHOUT dispensing any water.
...it's been about 12 hours since I've dispensed water again for the first time, and so far, SO GOOD! I'll update if the problems reappear.
Sep 28, 2008 | Hamilton Beach Water Cooler with Storage...
Hamilton Beach 87330 water dispenser: no auto shut off
Glen,
We purchaced this water dispencer about 2 years ago, everything was working normal, water heater works fine and the cooler would come on and go off normally,until you dispenced cold water and then the coller would cool down and shut of like it's supposed to.
Afetr a couple of years , one day it started cooling continuously and wouldn't stop, I've just shut the cooler switch off on the back of the unit until i can figure the problem out,unit #(87330).
I believe the problem is in the circuit control board, but with out further testing i can't be sure .
Sep 01, 2008 | Refrigerators
Hamilton Beach Water Cooler with Storage Cabinet Logo
560 people viewed this question
Top Hamilton Beach Water Filters & Coolers Experts
Dan Webster
Dan Webster
Jim Goldsmith
Jim Goldsmith
Are you a Hamilton Beach Water Filter and Cooler Expert? Answer questions, earn points and help others
