Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door won't open with remote
The power went off and i had to open the door manually, now the door won't open with the remote. it just goes back and forth on the thing.
  • Richard_896 Mar 09, 2009
    I don't think the attachment worked. Anyway, according to my operation booklet, to re-engage the trolly pull the manual release handle foreward toward the opener at a 45 degree angle so that the trolley release arm is horizontal. The trolly will reconnect on the next UP or Down operation either manually or by pressing the Door control push button. This works for Chamberlain Liftmaster Model 1000SDR or Moderl 2000SDR
Try the attached procedure
Posted on Mar 09, 2009
Back hatch won~t open with remote or inside door locks will open manually nothing stuck or jammed?
Found this wiring diagram for lift gate, if that is what we're talking about? Not only check the fuses, check fuse circuit for voltage. Use a testlite.
Apr 21, 2016 | 2008 Pontiac Torrent
I have an old Sears garage door opener 139.663900 that went dead this week.
you sure it has power going to it? the outlet it is plugged into is working for sure?
Jul 17, 2015 | Building Materials
My remote didn't open doors, on my1998 Saab 900S, so I used key to unlock manually. The alarm went off, and car won't start. When I open the door the anti theft alarm goes off again. This is E
Replace the battery in the remote, then reset the system.
Resetting a Vehicle Anti-Theft System
This is how you reset an anti theft system if you have the anti-theft light on, or your car is cranking, but you have no spark.
Doing a full reset of the anti-theft system.
Disconnect both battery leads for at least two hours.
Hold the negative and positive leads together for 5 minutes to fully discharge any power.
Put the key in the ignition, but not turned on. VERY IMPORTANT!
Connect the positive lead.
Connect the negative lead in one swift movement.
Wait 15 minutes for the system to fully reset.
Resetting Vehicle Anti Theft System
Mar 06, 2018 | 1998 Saab 900 S
My 2007 Scion tc won't open doors remotely has new batt in remote
YOU MAY OPEN REMOTE WHERE BATTERY GOES AND CK CONTACT WHERE BATTERY GOES MAY HAVE COME APART ON ONE SIDE NOT MAKING CONTACT
Jul 29, 2012 | 2007 Scion tC Coupe
Went to my garage to get items out of freezer and my garage door opener was down, no one handle the remote, or push any buttons at all, went back to the garage to get bottle water and the door was wide...
Anytime a door opens and/or closes randomly or doesn't work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ?½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone
Oct 30, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
Pulled red cord to open manually when power went off. How do I engage to open now that power is back on?
With your remote in your hand...operate the closer into the down position, hold the arm up so the catch is by the traveler. you may have to prop the door up on a pail or? to do this.operate the closer into the up position, as the traveler goes by it will catch the top of the rod as it goes by if you have it in the right position. if this sounds too dangerous for you, pull the plug on the opener when its midway in its travel, lift the door up and have a helper connect the traveler to the rod. you may have to pull the red cord to upen the latch with either method. Larry
Nov 11, 2009 | General Electric GE 13-438 Overhead Garage...
Craftsman Garage Door Opener won't work after storm
Check to see if the trolley (the part that slides back and forth on the rail and is connected to the door) is jammed against the bolt just in front of the motor unit. If so, remove the bolt and run the door until it is closed. On the side of the motor unit there is an 'up limit' control. Turn this 3 turns in the opposite direction of the arrow printed on the cover. Be sure to replace the bolt.
Jun 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
GARAGE DOOR OPENS AND CLOSES ON OWN LT BLINKS SEVERAL TIMES
Anytime a door opens and/or closes by itself I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
This can also interfere with remote controls
HOPE THIS HELPS
Mar 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Drivers side window power went out
I had this exact problem with my Park Avenue and it was the switch in the drivers door. I bought a switch at a junkyard for $5.00.
Nov 30, 2008 | 1998 Cadillac DeVille
Chamberlian 2280 Whisperdrive
Check the light beam safety at the door's bottom, to see if something is getting in the line of sight.
Jul 25, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
119 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
