TV does'nt seem to be picking up remote signal. Using RCA universal remote and replaced remote with new one to rule out remote problem. Any suggestions
  • dblavallee Mar 08, 2009
    How do I transfer codes using ir settings. (what is the ir setting ?)
    Brigadier General:
  • 8,619 Answers
Hi!
Check for any obstructions near the IR sensor on your TV. Try using this remote on another device if it is working with it then the IR sensor on your TV is bad and needs a replacement.
Posted on Mar 08, 2009
  • 13,433 Answers
The IR sensor on the tv is most likely not functioning. May need to replace the whole board that does the remote controlling.
  • 154 Answers
Try to transfer codes using ir senser.
  • crysiszone Mar 08, 2009
    if the presties, tell me the model number.
    IR means Infrared, you can copy ir codes to new universal remote using code transfer method... follow user manual to do this.
I have a Sharp tv im trying to program a lg universal remote. I have no codes and can i even do that?
Universal remotes usually have a "Learn" capability.
First you need to figure out how to get into learn mode.
Then you face the Learning Remote IR LED to the current Remote LED. You select the Key or Button one the learning remote that you want to pick up, Then click the similar button on the current remote that is Teaching. The IR signal is picked up by the learner and indicates it has been received correctly.
Then the next key is done
Good Luck
programing rca universal remote YouTube
Dec 02, 2015 | LG Televison & Video
G25819TK RCA tv (1991) aux jack problem
Without looking further you may need the Factory remote not all functions may be accessable using a "Universal" Ha,Ha,Ha remote.These Universal remotes have been problems in my line of work for years,Best idea is when you get a new tv pick up a cheap basic functions remote & use it for everday normal Vol./Channel/Power et. & keep the orig.for things the universal won't do
Jul 28, 2013 | RCA Televison & Video
Directv remote will not program to rca L42FHD37R. What is the code? I have tried all of the codes given by Directv.
"This TV utilizes new remote control signal codes and may not be compatible with your existing universal remote (e.g. satellite box remotes, cable box remotes, generic universal remotes, etc.). Over time, newer universal remote controls that become available should pick up the new TV codes."
Dec 07, 2009 | RCA L42FHD37 42 in. LCD HDTV
Can't get my dish network remote to work with my new 32 inch RCA LCD TV tried the codes in manuel for dish remote
I contacted RCA and they said that the tv won't work with most universal remotes because the IR signal used is "new technology." They said that newer universal remotes may work with it.
Personally, I think it's great to push new technologies, but not so smart to push it onto devices that are being sold at Walmart. I went to Walmart for a deal, and I don't want to spend $150 on a remote that will work with that "deal" I bought.
Nov 13, 2009 | RCA L32HD31 32 in. LCD HDTV
My tv stopped responding to the remote for some odd reason ( the remote seems fine ) how do i reset it ??
the problem is the IR Receiver in the tv needs
replacing,this is the receiver thay receives the
signal from the remote.there is no reset for
this type of problem.Also you my try new batteries in the remote and a new remote if the
IR Receiver does not repair the problem.
Sep 04, 2009 | RCA Universal Remote Control
I have installed a Digitalstream DTX9950 converter box with my TV attached to a rooftop antenna. I can turn the TV off and on with the DTX9950 remote, but I can't bring in any stations, other than the DT...
Are you using the coaxial cable to connect the converter box to the set, or have you hooked it up with rca type video cables? The latter are highly recommended if you want a better connection and have audio/video inputs on the back of your television. But you don't want both A/V & coaxial.
Also be aware that some older antennae will not pick up digital signals well. Try to use a coaxial cable all the way up to the antenna junction. Find out where most signals are broadcast from in your area and aim the antennae appropriately. (Use a compass.) See helpful link here. Your converter remote should have a signal strength button that you can use to check the various channel strengths. If you're using a coaxial link to the tv and have little signal strength, expect a poor picture. You'll also want to select the Mono option for Audio Output in the converter menu.
Finally, depending on the age of your set, if you're using rca video inputs, use the TV/Video button or the AV button on the TV or universal remote to switch the input from the channel on your TV to the video 1 setting (or whatever picks up the digital converter signal) so you'll get that clear signal. Then you can use the converter remote to change channels, adjust volume, etc.
Jun 14, 2009 | Philips Magnavox 20MT133S 20" TV
I NEED REMOTE CODES FOR THIS DVD RCA DRC200N
I finally found a code that works. Code 3144 worked. I am using the RCA universal remote control RCR412S and RCA DVD player DRC200N. The code 3144 is listed under Memorex in the code book that came with the remote control.
Oct 17, 2007 | RCA DRC200N
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
