Question about Garden
Broken Belt Yes my name is Darrin & I am in fla & I have a Coleman Powermate Pressure washer Model # PW0751310 Serial # 9603 00653NU 120 VOLT, 14.5 Amp 60 Hz , 1300 Psi & I need a belt & some screws to repair it, Can you help me . Thanks Mr. Hardee
  • 33 Answers
SOURCE: Coleman Pressure Washer Problem
your pressure relief valve is stuck open. i know that may sound too simple but it depends on if you use a cleaner with the water when your using it , not flushing with clean water after use can cause the housing of the aluminum housing of the relief valve to corrode. the valve can't move back and forth as it should because the o ring won't slide.
Posted on Apr 21, 2009
SOURCE: need instruction book for coleman powermate clean 1500
The hose connection I believe is for hooking a hose up and running it into a bottle of cleaner. The cleaner is mixed with the water when it is sprayed, The knob on the bottom adjusts the strenght of the solution. Most washers have the same setup.
Posted on May 26, 2009
  • 67 Answers
SOURCE: Coleman powermate wont restart spraying after release trigger
Make sure your fluid level in the pump is changed and at the right level.
Posted on Sep 24, 2009
  • 10 Answers
SOURCE: I have the Coleman powermate 2400 PSI pressure
Sounds like the valve in the handle is sticking closed. May have a broken spring, or maybe a part is stuck..
I say take it apart, and the answer will present itself.. Play with it with nozzle out too... Maybe something is stuck after storing so long and will loosen up.. Fingers crossed
Posted on Oct 26, 2009
  • 3740 Answers
SOURCE: Very simple lost the owners manual. need to know
Simple answer:
That is your manual.
Posted on Feb 20, 2010
Coleman Powermate pressure washer. Model PW0751310 A lot of water leaks out in the handle where you squeeze for the unit to work, thus the power spray is weak at best. Took handle/arm apart and didn't...
There may be orings in gun but usually not available as a repair kit. Replace the gun with a 5000 to 6000 psi. You will get a much longer life by over sizing gun. If you like to tinker, you can by orings at Lowes in the plumbing department. Lube the orings with silicone paste (also sold at lowes). Good luck
Mar 17, 2011 | Caterpillar Cat Pump Pressure Washer Pump...
Hi! Our gun trigger is not working right on Model
Lowes and home depot sell replacement guns for most smaller pressure washers.
Jul 29, 2010 | Coleman Powermate DuraBuilt 1400 PSI...
On the outlets it has 4/120volts outlets and 1/120-240volts outlet. Can you use the 120/240 outlet as a reg 120volt? And what is the reason of the 120/240 outlet. Thank you
The reason for the 120/240 volt outlet is to be able to run things like large electric heaters or even your clothes dryer as they all require 240 volts. If you use it as 240 volts you will not have maximum current output on your other outlets so you wouldn't be able to plug anything really big in. And yes you can only use is as a 120V output if you would like but you will need a special attachment or extension cord. I'm going to leave you with two reference pages I looked up that you should have a look at.
May 24, 2010 | Coleman Powermate Premium Plus 6250W...
Here is a link where you can look up your exact model and replacement parts from coleman...
Looks like your model may be out of production though so here's a generic kit that will 99% work with your washer...
Hope that helps...
Feb 09, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Checking oil in generator
I found some website help. I have this same problem.
I also found out a lot about the Powermate company via a customer service email reply: This has an elusive customer service number that i have not tried yet.
Powermate Corporation is not a part of The Coleman Company, Inc. They have been an independent company for over 10 years and we have no information on their products.
Powermate manufactured generators, pressure washers, air compressors and air powered tools. Information about those products was available from
Powermate Corp.
125 Airport Road
Kearney, NE 68848
Toll Free: 1-800-445-1805 (disconnected)
or 402-758-6303 (disconnected)
Web Page:
Earlier this year, Powermate transferred the right to sell air compressors and air powered tools to a company by the name of MAT Industries, LLC, 625 Barclay Boulevard, Lincolnshire, IL 60069, 1(800) 628-8815. This company may be able to help you with questions related to air compressors and air powered tools.
In March 2008, Powermate filed for bankruptcy protection. We understand that customer service inquiries to Powermate via emails, mail and telephone calls will not be answered. However, some information about Powermate and its products continues to be available at their website.
If the problem with your unit is with the engine, check the engine manual that came with the unit to determine whether the engine has a separate warranty from the manufacturer. When Coleman was affiliated with Powermate, they did. If so, you can contact the engine manufacturer for a listing of warranty centers in your area. The contact number should be in the engine manual.
If you are needing parts for a powerwasher, please visit the site for assistance.
Thank you,
Coleman Consumer Service
Aug 30, 2008 | Coleman Powermate Powermate 5000W...
Garden Logo
137 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
