Question about Sony Xplod XM-554ZR Car Audio Amplifier
Hi i have a 600 watt sony xplod amp model xm-554zr and it recently stopped working. when i turn my car on the amp turns on but only for a sec then the protection light comes on, on the amp and it wont play, i checked the ground connection and it is good so what is the problem? i also checked all my fuses and none were burnt. please help
  • 69 Answers
Sounds like maybe a speaker short, try unhooking your speakers and then powering up your amp, if it then powers up with the speakers unhooked try hooking up each speaker one by one untill the amp goes back into protection and then you have your bad speaker.
Posted on Mar 08, 2009
Is the sony xplod cdx-gt71w able to support a subwoofer without another amp
Sure is.
The sony is bridgable as follows:
  • 100W x 4 @ 4 Ohm
  • 100W x 2 + 250W x 1 @ at 4 Ohm
  • This will allow 2 channels to run 100 watts each @ 4ohms with an additional single channel with 250 watts @ 4 ohms.
    The single sub channel is created by bridging channels 3 & 4
    Dec 22, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
    I have a Xplod XM-554ZR Car Amp and the green light is blinking it worked just befor and now i have no sound
    The amp is in protection. Disconnect any speaker from it, then turn it back on, if it's not flashing, check your speakers with a meter and check speaker wires for shorts. If it's still flashing, you've blown the protection circuit and it needs to be replaced or repaired. Hope this helps
    Jun 11, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
    Keith
    I had the same problem as you. The problem is the wiring from your speakers to your amp TRIPLE check your wiring. Make sure that none of them got disconnected or connected to the wrong wire.
    Mar 30, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
    Cant get amp to work
    there are two nobs on the back of the amp they have to be turned inorder to ajust the woffer vol. make sher its not in power safe mode that will be a red light insted of a green one
    Sep 16, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
    Red light
    something is shorted in the circuit, or your subs. unhook the subs first and try it again, if it is still in protect then it is most likely the output transistors.
    Feb 22, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
    No response from amp
    it sounds like you have a bad ground make sure its on the froame or body and make sure any rust or paint is sanded or scraped off
    Feb 09, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
    Car amps
    important is to hav correct wires and groud cable...
    Dec 29, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
    Sony xplod xm-554zr amp
    if you are trying to run some highs with built in high-pass crossovers off of a amp that is setup for subs(amp is on low-pass) then your highs will not work. You are better off running another amp or running them off of your deck...
    Aug 18, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
    Sony Xplod amp not working (deck cought on fire)
    Hi there, please check the wiring. If there are some loose contacts the above mentioned symptoms are possibble. Best regards, Arpi If you need more info please advice.
    Jun 15, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
    Sony Xplod XM-554ZR Car Audio Amplifier Logo
    362 people viewed this question
    Top Sony Car Audio & Video Experts
    xxxxxx xxx
    Larry Stiles
    Larry Stiles
    Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
