Question about Garden
How do you change blades on troy built j609-stop from rotating so can get nut loose
    Problem Solver:
  • 6 Answers
Use a block of wood as a blocker wedge it between blade and and housing
Posted on Mar 20, 2009
How ti fix noisy troy built 26J also blade continues to turn after turned off.
Sounds like the blade brake or it's linkage, is loose, worn out, or not working properly. This would cause noise when it's running and the blade would continue to turn when you turned it off. good luck
Jul 21, 2017 | Troy Garden
I'm trying to change the blade on my Plasplugs tile wet saw, after not having used it for over three years. No matter what I do, I can't get the nut off! I've tried WD-40, graphite, hammering...
Try rotating the nut COUNTER-CLOCKWISE.
Usually, nuts and bolts are Righty-Tighty, Lefty-Loosy, but frequently saw blad nuts use a Lefty-Tighty, Righty-Loosy.
They are built so that when the blade starts to turn, it puts a momentum on the nut that tightens it, so that a loose nut won't come flying off, and get someone injured.
Jun 26, 2011 | RTO Plasplugs DWW406US Power Master Wet...
Change blades on a lawn tractor pony? troy built
just jack it up so you can get under the deck and unscrew the bolt on center of ech blade take note on how the curves of blade are angled do one at a time incase you forget but bolt back up tight and you are ready to cut if you try to resharpen the blades make sure you balance them or they will mess up the deck bearings
Nov 02, 2010 | Troy Garden
How do you keep the blade from moving while you loosen the nut to change the blade on a Troy-Built 9" lawn edger?
stick a block of wood inbetween blade and sheild or spacer behind blade may have a hole to put a punch or nail to keep from turning. hope this helps
Aug 14, 2010 | Garden
Troy Bilt 34073 mower - stripped spindle-shaft?
Bet on it- you might try adding an additional nut of the right size/thread or several washers to utilize the remaining healthy threads.
May 14, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Replacing belt on troybilt TBE515 edger . After replacing belt blade will not spin when engaged. If i remove the blade the shaft does rotate.
Use a 15/16 open end wrench an correct size allen wrench. Loosen nut (15/16) ccw while holding allen. Geez how dumb are yawl?!
Apr 24, 2010 | Troy Garden
Are the nuts holding on the blades reverse threaded?
If a blade, when viewed from above, rotates clockwise, it will have right-handed threads. This is because the shaft is turning to the right, and the resistance imparted on the blade will tend to tighten a right-handed fastener. If a blade rotates counter-clockwise it will have a left-handed fastener. I don't know this mower, but this is a universal thing.
Apr 23, 2010 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
I have a Troy Built lawn tractor, after removing
Clearly the cable either broke, came loose.
Aug 22, 2009 | Garden
Can't get the nut off.. is there a secret to blade removal
Hi these are usually the opposite way to which the blade turns but you may have to use a rattle gun to remove this. If you have a look at the thread you should be able to determine which way it comes off. Just remember to fix the blade so it wont turn and take your fingers off.
Aug 03, 2009 | Garden
The engine stalls
you may have trash in the gas tank. empty it nad wash it out real good make sure the gas you use is fresh the vibration could be the blade ; or it could be that when the rock was hit it bent the shaft and that would cause vibration also. remove the spark plug and rotate the blade with your hand, you should be able to tell ifi the shaft is bent or not if not try putting a new blade on
Jun 12, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
165 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
