Venta Airwasher VS370 2 Gallon Humidifier
Problem for Venta Airwasher VS370 2 Gallon Humidifier
I have a Venta VS370 humidifier which works fine
By richardandhe on Mar 08, 2009
I have a Venta VS370 humidifier which works fine immediately after I change the filter but after a few days the vapour stream diminishes significantly and it ceases to be effective: is this a malfunction?
Comments:
Mar 11, 2009
- We tried vinegar but it didn't make any difference.
The filter should last for 1000 hours but after three days the humidifier is hardly working. The vapour output is poor and the humidity reading stays at 30%.
The water here in Warsaw does contain a lot of deposits. I think we have to talk to the local Venta dealer.
Although any other suggestions would be welcome
Solution #1
posted on Mar 08, 2009
Somewhat Helpful)
Mtoddvan
Rank: Guru
Rating: 86%, 85 votes
Filters need to be changed regularly depending on environment may have to change more often.
These systems can be very troublesome. It is possible that you are having mineral buildup in your system from the water supply. You can try adding 1/4 cup vinegar to your water to help clean away deposits. See if that helps .
Was this helpful?
Yes
No
Popular Solutions for Venta Airwasher VS370 2 Gallon
Questions and Unsolved Problems for Venta Airwasher VS370 2 Gallon
Do you recommend Venta Airwasher VS370 2 Gallon Humidifier?
Answer
Answer
it is not turning on to bring water to it from the hot water heater
Answer
how do the filters fit in kenmore model 75815420 humidifier
Answer
motor has burn't up
Answer
brand new out of box display will not stop blinking this is the second unit I got from the store and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Venta Airwasher VS370 2 Gallon...:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
