Question about Mackie SWA1501 Subwoofer
SWA1501 Sub blows fuses when turned on...
My sub wouldn't turn on at a recent gig, si I checked the fuse. Sure enough it was blown. I replaced the fuse(with the proper one) turned the unit on and it blown another fuse. What can cause this????
  • 336 Answers
Shorted amp or blown speaker. Other things could also cause it. But there is a short circuit in it.
Posted on Mar 08, 2009
Mackie sub swa 1501 no LED no output but light on board appears to be on
los transistores de salida estan en corto 2sa1943 y 2sc5200 reviisa los drivers tip 122 y los irf
Feb 18, 2012 | Mackie SWA1501 Subwoofer
1501 sub will not power up. i opened, inpected and replaced power fuse 250v 6.3 amps replaced with same fuse and it blew as well immediately. what to do and how. I have some technical experience.
Isolate and look for possible shorted components.
Isolate the main power transformer from the board, and see if the
fuse still blow.
If it doesnt , then the rectifier and capacitors to the regulators.
But don't forget to check for possible shorted transistor
Sep 23, 2011 | Mackie SWA1501 Subwoofer
Fuse blows, replaced the two capacitors and it still blows fuses... sub is fine and not blown...what else could it be??
If your sub is made to be used in other countries check to make sure it hasn't been switched to a different voltage.
Dec 18, 2009 | Polk Audio PSW202 Subwoofer
My speakers simply will not turn on any more. i was playing music on them and then all of the sudden the power just will not turn on in the sub. Does this mean i blew them out? I didn't really have the...
Maybe. There should be a fuse. It will prolly look like a black knob on the back of the sub. Unscrew it and check the fuse. Replace it with a good fuse.
If it keeps blowing the fuse, the problem is likely in the speaker. If the problem is inside the sub, you may need to repair/ replace the circuit board inside the unit. If you can't get one you will have to replace the speaker as it will keep blowing fuses.
Oct 15, 2009 | Cambridge Soundworks SWBL SoundWorks PC...
Volume reduction with same input ( 4 years old),
What are you using to feed the sub? Are you sure that the signal level you are presenting to the sub is the same?
Dan
Jul 31, 2009 | Mackie SWA1501 Subwoofer
Fuse blows
Both 3 or 4 amp slow blow fuses are suitable replacements for the 3.125 amp subwoofer fuse.
It could be that the subwoofer is blowing the fuse because the one you installed was not slow blow.
But, more likely is the subwoofer has a short in the power supply which is causing the fuse to blow.
May 31, 2009 | JBL PB10 Subwoofer
Bass pops
Hi There, Have you checked the 3 fuses that clip onto the main amp board? You can access them by undoing the two screws that are on the top and the bottom of the sub. They have flat large heads and you will need a hex key to unscrew them. If it is one of the fuses that has gone it will either be discoloured as in burnt or you will see the metal inside has split. Simply replace these with a new fuse and hey presto you should have eradicated the popping. If you need any parts for the sub or fuses then www.LondonSpeakerShop.com will be able to supply them (that is if you're in the UK). Hope this helps. Grant (from www.LondonSpeakerHire.com)
Feb 01, 2009 | Mackie SWA1501 Subwoofer
Klipsch ksw subwoofer wont power on
The power supply switching transistors are likely fried. Dangerous high voltages involved. I would remove the plate and send it to Klipsch for repair.
Jan 16, 2009 | Gem Sound SUB-650M Speaker
Subwoofer
Repeated fuse blowing generally indicates a blown power supply, or blown output stages or both. One thing to do is be sure that you have replaced the fuse with the correct type. A T stamped into the metal of the fuse near the rating, indicates sloblo or Time Lag fuse. A fast blo fuse, may work once, or more times, but will never replace a sloblo fuse in this type if unit. Good Luck, hope this info helps, don't hesitate to hit me back here for more help :)
regards
Graeme
Feb 13, 2008 | Harman Kardon HKTS 7 System
No sound at all
Do you get sound from your other speakers? If so, then the sub is either blown or not connected correctly. I would suggest checking all the connections.
Aug 07, 2007 | Mackie SWA1501 Subwoofer
Mackie SWA1501 Subwoofer Logo
806 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
